Cometic head gasket for 120? : V-Twin Forum: Harley Davidson Forums
Old 11-14-2012, 03:18 PM   #1 (permalink)
cruzmisl's Avatar
cruzmisl is on a distinguished road
Anyone have a part number for a .030" Cometic head gasket for a 120? Just want to bump the compression a bit and want to be sure I order the right one. Any suggestions for a good vendor?
Thanks,
Joe
cruzmisl is offline   Reply With Quote
Old 11-14-2012, 06:38 PM   #2 (permalink)
No Cents's Avatar
No Cents is on a distinguished road
If it's a 120R with a standard 4.060 bore...the .030 Cometic head gasket part# is:
C9070-030
Listed $44.99 a set.
Cometic is right below you in Ohio...and will sell direct.
Their phone number is:
(800)752-9850
.030 milled off them MVA heads and a .030 Cometic gasket will wake that 120R up!!!
Just my 2 cents...from No Cents
No Cents is offline   Reply With Quote
Old 11-14-2012, 07:12 PM   #3 (permalink)
aubeagle is on a distinguished road
Cents, With .030 being milled and the .030 head gasket what kind of increase in compression could be had. I must be reading to much since it get the brain rolling in warp speed.
S.
04 FXDLI
SE113
Dan Vance
Ported MVA's
Crane 296-2
Woods lifters
SE Roller Rockers
HPI 55 tb
Marren 5.3
Injectors
VH Propipe
T/max
aubeagle is offline   Reply With Quote
Old 11-14-2012, 08:22 PM   #4 (permalink)
cruzmisl's Avatar
thats perfect. Thanks brother.
Old 11-15-2012, 04:43 AM   #5 (permalink)
No Cents's Avatar
It puts the static compression right at 11.0:1 with a .030 cut on the heads and a .030 head gasket. Gives the 120R a lot better bottom end pull...the stock 266 cams love the added compression.
It produces pretty much the same results as running the domed piston that GMR offers for the 120R.
No Cents
Old 11-15-2012, 03:35 PM   #6 (permalink)
JohnCA58 is on a distinguished road
When I call Cometic for my 120, I ask for a .027 Head Gasket at 4.090 and a week later it is on my porch.
2000 RKC
HTT 120
Darkhorse prepped crank
Dragula 2:1 w/ ghost pipe
Tman 662-2 w/ Gatermans 1023
HG .027 10.8:1 c.r. using ACR's
110 Heads prepped by Dewey's Heads
Baisely corrected geometry roller rockers
HPi 55mm TB w/ HPi 6.2 injectors
HPi air cleaner vented to atmosphere breathers
Fueling pump and cam plate
SERT and PCIII
Bandit clutch
Baker Plus One oil pan
1.7kw All Balls starter w/ 66t ring 9t pinion
Wardspartswerks FCS Cooling Fans
RC Cycle tuned 151 h.p. 146 ft.tq.
JohnCA58 is offline   Reply With Quote
Old 11-16-2012, 07:57 AM   #7 (permalink)
Tribal is on a distinguished road
While you have the heads off, check piston height. You can fine tune deck height with a thinner or thicker base gasket. From memory Cometic base gaskets are $20.00. If front to rear cylinder height is not the same, get one thickness for the rear cylinder, and a different thickness for the front.
Tribal is offline   Reply With Quote
Old 11-16-2012, 08:01 AM   #8 (permalink)
cruzmisl's Avatar
Is there a tutorial on how to check the deck height? I'd like to be certain I'm doing it properly.
Old 11-16-2012, 08:10 AM   #9 (permalink)
At one of the site sponsors, Big Boyz. Here's the link.
http://www.bigboyzcycles.com/showthread.php?t=92
Old 11-16-2012, 12:35 PM   #10 (permalink)
splitting_lanes is on a distinguished road
I find that the solder method is the easier way to check squish, as you can do it before disassembly - here's one example:
http://hammerperf.com/ttcheckingsquish.shtml
I prefer to just leave the motor assembled and use a long peice of solder with a 90 degree bend in it inserted through the spark plug hole and held against the cylinder wall directly above the piston pin.
I check it on each side of the piston, and shoot for .030-.035 squish -- and if it's higher, get a thinner base gasket to correct.
If your squish is set nice and tight you'll notice a snappier midrange and less pinging (my compression is much higher than stock, running the same cam, but getting less pinging than before -- and I attribute it to having the squish set correctly)
2007 Dyna
117" Hillside
splitting_lanes is offline   Reply With Quote
Old 11-16-2012, 02:32 PM   #11 (permalink)
nw_guy4_fun's Avatar
Use this bridge and a dial travel indicator
Don Dorfman
~~Motorcycle Enthusiast~~
Old 11-17-2012, 06:56 PM   #12 (permalink)
build it
Knighty-Knight's Avatar
Knighty-Knight is on a distinguished road
This device measures squish clearance?
Knighty-Knight is offline   Reply With Quote
Old 11-18-2012, 10:16 AM   #13 (permalink)
Add a travel indicator and then read the actual TDC piston depth, then an intelligent head gasket decision can be made. I know typical on the 120r but you never know for sure until it is measured and straight edges and a feeler gauge is a recipe for problems in the hands of most.
Don Dorfman
Old 11-18-2012, 10:50 PM   #14 (permalink)
mike jesse is on a distinguished road
Randy's vid. will walk you through the measurements.
Watch the vid. at the top of the page.
http://kingofcubes.com/?page_id=148
mike jesse is offline   Reply With Quote
