11-13-2012, 02:07 PM
TW222 cams -impression
Hi,
Had my indy pull the SE255 cams out that I have had in the bike since taking it home new from dealer. Had 10,000 miles on them, and some Ping issues.
After reading on the forums about the TW222 cam, i figured that I could enjoy a better torque curve and some more horses.
Without benefit of being able to ride a couple hundred miles on the new cams, i have to say WOW!.  Significant seat of pants feel for the torque which is great, and it definitely gets with the program with a nudge of throttle.
Cant wait until a break in the now not so hot, snowy weather allows for a ride....probably going to be March for that, to further enjoy the cams.
Cheers,
Mark
11-13-2012, 07:16 PM
That cam will likely take the place of the TW5 which has always worked well for me. They are very similar on paper.
Don Dorfman
~~Motorcycle Enthusiast~~
11-14-2012, 12:30 PM
At what RPM do these cams come on at?
Barney
11-14-2012, 06:03 PM
Cams
Barney
The TW222 comes hits 100 ft/# about 2300 rpm. Fuelmoto has a dyno sheets for this cam and also on Woods cams page
11-16-2012, 06:35 AM
Seasoned,Retired Rider
Barney
I can feel them start to pull around the 1700-1800 range not that I drive there but I'm doing a lot less downshifting.
2012 Ultra Limited,V&H VO2 Intake,Wood 222 Cams,Cobra Power Port Header,CVO Mufflers,TTS Tuner
AMSOIL DEALER SINCE 1985
11-16-2012, 07:41 AM
Would you feel much improvement over the SE203 in a 95ci ST with ported heads and 80 cc chambers?
01-03-2013, 01:51 PM
tw-222 cams are majical
We have been having such great results using these cams..
Makes bike effortless to move... the low end torque is definately there and is straight up effortless... Awseome cams--- the cool thing about these cams is they are producing big torque right off idle... that's what makes them majical--Timing is perfect!!!
Mikee's-Texas
5470 county road 100
Hutto TX 78634
512 905 1003
01-12-2013, 10:54 AM
How about noise,are these like most of Bobby's grinds or is it quiet?
01-12-2013, 11:24 AM
I used the SE Perfect fit +30 push rods and its as quiet as stock or quieter.
01-12-2013, 06:00 PM
With a 34* intake closing, my guess would be you should be feeling it around 2000 rpm.
In a 95" that's had the heads done (I'm assuming the lift was increased), I'd be looking at the Andrews 48 cams. Bolt in replacement cams for '99-'06 twin cam motors with very similar spec's. The 48's would also come on faster than the TW222's.
Andrews Parts Catalog.
"Mouse Cam on Stilts"
My Garage
01-12-2013, 06:17 PM
I know where I can feel it start to pull.
[QUOTE=Weevil;2214193]With a 34* intake closing, my guess would be you should be feeling it around 2000 rpm.
04-11-2013, 10:32 PM
How do they run besides the
S&S 551 ?
| Sponsored Links |
