120 tuning..open loop vs closed loop - Page 3 : V-Twin Forum: Harley Davidson Forums
Old 11-11-2012, 06:11 PM   #31 (permalink)
build it
Knighty-Knight's Avatar
Knighty-Knight is on a distinguished road
Top tier engine management systems and their respective tuners, for air cooled v-twins, be it high comp on pump, nitrous, or turbo, ALL tune in closed loop. This is not now nor will it ever be up for discussion. BUT, there is a chance that the Delphi and it's respective tuning devices are not up to the task; on this point I can only speculate.
Knighty-Knight is offline   Reply With Quote
Old 11-11-2012, 07:29 PM   #32 (permalink)
Still the Same!
wurk_truk's Avatar
wurk_truk is on a distinguished road
Great to see all of you guys!
120r
wurk_truk is online now   Reply With Quote
Old 11-11-2012, 07:37 PM   #33 (permalink)
strokerjlk's Avatar
most are alpha N when you get to Nitrous,turbo applications.and your right they dont use delphi.
Brian Truesdale has a closed loop system that uses his speed density ECM, sensors,and runs offset's to the closed loop system.
3500.00 is a little steep for most guys.
07 ULTRA
SE 120Rxtra
Old 11-11-2012, 09:19 PM   #34 (permalink)
springer-'s Avatar
At what AFR?
Check out Ride of the Month
207-621-8089
Old 11-11-2012, 11:00 PM   #35 (permalink)
guydoc77's Avatar
guydoc77 is on a distinguished road
And Knighty Knight, correct me if I'm wrong, but I'll bet they are using wide band sensors.
As I implied in my other post, I can imagine how that would work, and might even be better. But I'm guessing these are fairly high maintenance engines and that collectable data is routinely analyzed after each run on the track.
2008 Road Glide
Phoenix Customs Bagger Brace
Glide Pro
Clearview windshield
107
CP flat tops
R&R Stage 3 heads, .030 gasket, 82cc chambers
Trued, welded, and balanced crank by Hyperformance
TMan 590 cams
SE AC
HPI 54mm TB
Supermeg with open cap and 15 discs
TTS tune by BVBob
2003 Indian Scout Deluxe
Aspen White (got it for my wife)
S&S "SuperStock" 88"
12" apes
Scary fast!
guydoc77 is offline   Reply With Quote
Old 11-12-2012, 08:34 AM   #36 (permalink)
lonewolf55 is on a distinguished road
Jim that's quite the difference on the 2012. How did the afr differ? Could any of that been due to resetting the adaptive knock retard also?
'07 Street Glide 107"
lonewolf55 is offline   Reply With Quote
Old 11-12-2012, 09:19 AM   #37 (permalink)
VDOP's Avatar
VDOP is on a distinguished road
When you guys are tuning in open loop, say with a super tuner or race tuner... Do you set the entire a/f table to a set value, say 13.0, tune the bike, then change it when you're done, but just don't use the O2s? I would assume you modify the a/f table to your liking, I see a whole lot of 14.7 in the factory tables. What do you usually aim for in the cruise area? When you're not using the O2s do you cap the harness with an o2 eliminator like you would with a power commander? I'm kind of a newb with open loop tuning, and I'd like to give it a shot when I build my 113 this winter. I'm thinking about doing a race gas tune for it as well and just don't want to deal with O2 sensors for many reasons. I have an old race tuner right now, not sure what I'll end up using.
Say it's a '10+ bagger with a super tuner. I can't stand the smart tune. Has anyone tuned these open loop with a super tuner? If so, what do you use for an o2 eliminator with the new style sensors?
Originally Posted by springer- View Post
In 2007 after the introduction of O2 sensors here is what we saw in the cylinders.
Note the red arrows, see the color difference? Do you know what is from? Those are heat streaks, but why are they just in those particular spots of the cylinders? And what causes them?
Here is another picture... Note the red arrows and the heat streaks coincide with the engine studs. The reason for this is there is no direct cooling to the outside fins at those locations. The heat can not dissipate quickly enough from those locations.
Also note the wider heat band at the 9 O'Clock position in the cylinder. Care to guess why that one is there? Hint, it is the location where the push rod tubes are found. There are no cylinder cooling fins at the push rod location. What causes this and why did it start showing up in 2007?
Answer CLOSED LOOP EFI.
I'm not arguing that a closed loop lean condition will generate more heat, but I have seen the heat bands you pictured in almost every tc I have taken apart, even carb bikes. In fact the last one I took apart just the other day was a well tuned carb bike and it had very noticeable heat bands. I think it's due more to the fact that the cylinder just can't dissipate heat in that area, and the conditions in which the bike is ridden. I'm sure lean conditions aren't helping, so I'm not sayin, I'm just sayin. I've ridden with people on a 95 degree day that will sit in traffic til the point the bike barely runs and the clutch barely works. I'd subject my bike to just about any kind of abuse you could imagine but I will not let it get hot.
'06 FXDXB: under construction. 95" retired, 113 in the works. DX bars, DX shocks, xb wheels.
http://youtu.be/NXhvF36wMrQ
'99 Buell X1: 11:1 1250, NRHS st3 thunderstorms, S&S 600s, Force exh, CV44, Penske shock. First bike.
'99 Hayabusa: 16:1 1543cc. 240rwhp all motor. 8.60s @ 160, street tire, no bar.
'88 Mustang LX: 11:1 331, ported TFS TW, comp 280, TFS R intake, 90mm tb, Kooks long tubes. Gutted, suspension, stick, built 8.8, slicks. Street car.
VDOP is offline   Reply With Quote
Old 11-12-2012, 10:01 AM   #38 (permalink)
Axe Man
BVBOB's Avatar
You can leave the sensors in place and shut them off in the software by setting the target to anything other than the 14.6, if you like to rid your pipe of them for the sake of looks you can install a 1 meg resistor. On the newer bikes they can be unplugged without throwing a cel, if the ecm is read it will read 02 sensors inactive.
As for the afr target table I generally set the cruise areas to 14.1 and progressively change them to 12.8 to 13.2 at wot, every bike is different and responds different to these tables as the rate of change through the target tables varies with a build's cam, power level etc.
As far as your question of changing the entire target table to one afr I have done it both ways and really see no reason to change the entire table over to the same target with the system I use.
While I am not entirely against 02 feedback I feel it's the adaptive fuel that can mess things up long term, I believe the new Power vision has the ability to shut off the adaptive fuel but retain 02 feedback. It will be interesting to see how this works out.
2007 Ultra
114 CI
SE cases
Woods 8 cams
Reworked 110 heads by nw guy
Thayer 3 stage oil pump
V&H true duals trapp mufflers
103.. on the workbench
1982 FXRS
Scratched paint
Rotten tires
Bad brakes
Sticky clutch
Still runs like a champ
Old 11-12-2012, 09:26 PM   #39 (permalink)
build it
Hello Stroker, I dunno what Mr. Truesdale uses, it might be great, or not. I was referring to Pectel, Motec, and other like ecm units. Base cost is significantly higher than the ECM Mr. Truesdale sells.
Old 11-12-2012, 09:35 PM   #40 (permalink)
build it
At what AFR?
I don't know.I do know that HD vtwins are tuned in closed loop, daily drivers, with much more compression than is thought prudent, on the forums. Individual knock sensors, individual cylinder AFR & timing, both closed loop; I'd guess that the limits are very much extended with the ECMs I've referenced, perhaps not
Old 11-12-2012, 11:19 PM   #41 (permalink)
build it
I can't correct you as I don't know . There is a spec sheet floating around for both Pectel and Motec though, and IIRC, that information is available. My logic on this one went like this "If these systems can be used to tune 1500hp Vipers for daily use, there is no way in hell a little ol'v-twin would have a problem". I've been wrong before and own that my "logic" is, well, not really logic at all.
As for high maintenance, not necessarily. Sometimes, yes, but not always. A rally car requires high maintenance, a turbo Viper requires less if built and tuned properly, a high compression n/a engine, of any sort requires less, again, if properly built. A mid level example would be a 930turbo making 750 daily wheel horsepower; we travelled to Florida and back on pump fuel; keep in mind that this was big money stuff, Motec, individual coils, plenty of dyno time, excellent parts, and pristine assembly. It was air cooled too, you can't imagine the size of the oil cooler on this rig, it was enormous. The motor has 30k or more on it, now and is an active participant in flog sessions on the track. This daily runs closed loop.
I still don't know if the Delphi system is up to par, the tuners do seem to though. Stroker tuned a monster 117 with just shy of 14:1 compression (I'd love to know the piston fit on this setup) on pump fuel; I don't know if it is a daily, but it does sound like it gets run.
Blue pill or red pill?
Old 11-13-2012, 09:31 PM   #42 (permalink)
strokerjlk's Avatar
motec is some good chit. been looking at it for a project bike.
closed loop is great if you can get it to work at whatever AFR you desire.
you didn't straddle that boxer down to Fl. did you Knight?
Russel the timing was 26 deg total with no activity on both pulls.
I didn't sample AFR, cat was in the way and time didn't permit me to install herko blocks . I had two waiting to tune, and Alans to do a stage II on. I wish I had more time to play.
07 ULTRA
SE 120Rxtra
Old 11-13-2012, 10:35 PM   #43 (permalink)
build it
you didn't straddle that boxer down to Fl. did you ?play.
I'm sorry I don't understand. I didn't drive the while way if that's what you meant.
There are more cost effective value packed efi units out there than Motec. Check out Pectel.
Old 11-14-2012, 05:10 AM   #44 (permalink)
strokerjlk's Avatar
exhaust heat
you were not sitting on top of the motor in the BMW were you.
07 ULTRA
SE 120Rxtra
Old 11-14-2012, 07:21 AM   #45 (permalink)
build it
The 930 is a Porsche. Charcoal on black recaro seats, Ruf wheels. I'd like an inconel exhaust, not sure if it can be done though, here anyway.
Back to our regular scheduled programming.
