11-08-2012, 10:35 PM
Tw6
Is there any other cam that can give you that Great TQ, and more HP in a 95" build, at 9.5:1.Thinking of going to an s&s 585.93hp/112tq. Do I need more compression for that cam? Have a 4* gear with my tw6.Don't get me wrong,I love the tq of that cam,just want alittle more up top.
11-09-2012, 05:39 AM
do you have headwork already?
2005 Ultra classic
-1550 BB kit/Woods WT6/SE adjustable push rods/PCIII
-Mountain MAchining Heads/1.9 intake/1.6 exhaust
-4.6CC CP Pistons/zero deck hieght f/r
-10.2:1
-94hp/103Ft/lbs torque
-V&H TD head pipes/Rienhart Slips
-Baileys Spring/WB easy clutch
-Mustang seat/WW and Spokes
-34 tooth Andrews pully
-Racetech front springs and emulators
-Dyno'd by Bruce @ Dynotunes
2012 883 Superlow
-Windshield and bags
-Mustang solo seat
11-09-2012, 06:02 AM
not sober all the time
If you are only getting 93 HP with a TW6, you're leaving some on the table.
11-09-2012, 08:37 AM
Yes, I do have head work. And how am I leaving some on the table? What can I do? Is it my heads?
11-09-2012, 08:45 AM
I don't know anything about your engine, heads, etc but I get 100/100 STD using a TW6 in my 95" and I tuned it myself. Seat of the pants tuning with a SERT. I've seen where others have gotten more than with professional tuning.
11-09-2012, 08:50 AM
Easy
Take the key out, raise the compression to 10:1 and add 1.7 SE rockers. Assuming the heads are a little more than a buff and fluff and are working right you will be amazed how much better it runs.
Don Dorfman
~~Motorcycle Enthusiast~~
11-09-2012, 10:11 AM
I know this might be a hard question to answer,but can I get to 10.1 by decking my heads with flat top pistons?
11-09-2012, 10:29 AM
Same answer Easy
Mill to 77cc, mill the intakes too so the manifold still fits, use a .030 head gasket and check piston to valve clearance, fix if needed.
Don Dorfman
11-09-2012, 11:16 AM
Originally Posted by nw_guy4_fun
Same answer Easy
Ok, stay with me cause I don't know to much about this. How much would have to be taking off the heads to get 77cc ?
11-09-2012, 11:25 AM
Somewhere between .055 and .085 would depend on where they start at.
So the answer,
It depends
Don Dorfman
11-11-2012, 12:07 AM
What is in your build? Heads,compression,etc etc.
11-11-2012, 06:52 AM
Hillside ported the heads and bored the cylinders. The heads have aftermarket valves, don't remember what size they used. I bought the other parts from them, TW6, gear drive kit, Wiseco pistons, rings, S&S pushrods. They set it up at 10.2 compression with 10.5 pistons and a large combustion chamber. Scott assured me that it would be fine at 10.2 but I dropped it to 9.8 for a little insurance. D&D FatCat quiet baffle, stock lifters (bought a new set @ time of build), stock rockers and stock oil pump.
11-11-2012, 10:14 AM
Great looking TQ curve.Think I will increase compression and take a look at my heads.Thanks
11-11-2012, 10:38 AM
BTW, I tuned it so I could run lower grade gas in case I was out in the boonies and couldn't get the good stuff. I'm sure a good tuner could tweak several more ponies out of it, especially if the tune was optimized for good premium fuel.
| Sponsored Links |
