calling all 124 owners : V-Twin Forum: Harley Davidson Forums
Old 11-07-2012, 09:30 AM   #1 (permalink)
Mother's Avatar
Mother is on a distinguished road
Reliability issues? Ride-ability? Is there something you would different if you could do it over again?
Hyperformance 124ci. 11.5cr CP pistons Triple XXX S&S'G' Wimmer MiniMax
Wood lifters & rocker supports
R&R bottom end DT oil pump. S&S 640G cams
ported SE Hurricane heads
DaytonaTwinTec ignition
Baker KKK/4+1 pan
RB Racing 2" 2into1Blackhole
Smith Bros. pushrods
HUGE amount of help from Torque Inc.
Mother is offline   Reply With Quote
Old 11-07-2012, 10:38 AM   #2 (permalink)
Bad Disposition's Avatar
Bad Disposition is on a distinguished road
Mother,
What type of riding are you going to be doing, bar hopping, long distance?????
BD
08 ULTRA /120R Designed and Built by GMR
4.060" big-bore cylinders.
4-5/8" stroke premium forged flywheels worked by R&R
11:1 Compression
SE-266E high-lift cams.
R&R Roller Rockers
Woods lifters.
R&R 88 CC Cast heads Manual Compression releases.
HPI 55 mm TB
Evolution Diamond Terminator Clutch Basket
Bandit Sportsmen Clutch
Diamond Cuts
Other Goodies.
STD 134.65 Hp 130.57 Tq
SAE 135.50 Hp 131.39 Tq
Bad Disposition is offline   Reply With Quote
Old 11-07-2012, 12:37 PM   #3 (permalink)
Mother's Avatar
A lil of both erroring on the side of distance.
Baker KKK/4+1 pan
Old 11-07-2012, 12:41 PM   #4 (permalink)
Mother's Avatar
That's the reason I am going with Feuling 630's with S&S 640g's as a back up....easy on the valve train AND capable of big power!
Baker KKK/4+1 pan
Old 11-07-2012, 01:04 PM   #5 (permalink)
frankie_b is on a distinguished road
The motor won't be the problem. Big power will break stuff, motor mounts, swingarm bushings, bag mounts, bag supports etc, i would suggest alittle stash on the side for those type of upgrades. I would also suggest getting ride of the bag pins and using bolts drilled for a cotter pin. I have had them pass me up going down the road.
06 Road King, S&S 126 ci, D&D Boarzilla Exhaust, SA Racing Modified Super G carb, Primo Open Primary, Pro Clutch
frankie_b is offline   Reply With Quote
Old 11-07-2012, 01:56 PM   #6 (permalink)
Calling all 124 owners
Not just a little stash on the side, a substantial one. I've emptied the piggy bank once or twice now. I removed the bag pins and went to bolts along time ago. It not a good feeling when one sees a custon painted bag fall off at 70 miles per.
Drilled for a cotter pin....hmmm that's a great idea, thanks.
Mother, it sounds as though you are heading in the right direction, I would have loved my 124 if it was built right. It was fun while it lasted.
BD
11:1 Compression
R&R Roller Rockers
Woods lifters.
HPI 55 mm TB
Diamond Cuts
Other Goodies.
Old 11-07-2012, 02:09 PM   #7 (permalink)
Premium octane member
TXCHOP's Avatar
You will learn after you build and break in the motor where the weak points are.
Invest in a glide pro motor mount at the least.
Oil and primary oil changes every 2k(or less miles)
Poly riser bushings
rear tires dont last as long even with out abuse
batteries dont last as long
my saddlebag mounts snap constantly.
etc...etc...Every bike is a bit different, but you will figure out what it needs when you get going.
117ci.
Old 11-07-2012, 02:20 PM   #8 (permalink)
No Cents's Avatar
No Cents is on a distinguished road
wheelie bars...and parachutes are optional !
No Cents
No Cents is offline   Reply With Quote
Old 11-07-2012, 02:39 PM   #9 (permalink)
Mother's Avatar
haha Ray! Thanks guys...definitely do the bolts for the saddlebags being they are being painted by Kustom Flames(member on here)
Baker KKK/4+1 pan
Old 11-07-2012, 04:45 PM   #10 (permalink)
No Cents's Avatar
Just havin a little fun with ya Mother.
I'm sure you will find all the gremlins on the bike in the first month of riding it. The not so tight bolts will show their faces quickly with your new found power you will have.
Just make damn sure your rear pulley is loctited on and torqued down good!!!
It took me about a week before I found a bolt 1/2 way backed out on my pulley and the other four finger loose. The extra hp/torque shows these things quickly.
Keep us posted on the progress of the 124"er.
No Cents
Old 11-07-2012, 05:48 PM   #11 (permalink)
Mother's Avatar
Ray, all good here and thank you for the heads up!!!
Just got off the phone with Randy@Hyperformance. pistons(CP) and cylinders(new style S&S)are ordered...I'm going with the R&R wheels, randy assures me they are solid and I am confident in him. he will be boring the cases and setting up the 'long block'
Baker KKK/4+1 pan
Old 11-07-2012, 07:02 PM   #12 (permalink)
Burch753 is on a distinguished road
I ride mine very hard and demand it to run back to back tank fulls consistently... 11hrs to the dragons tail, blistered the front and rear tires for two days, then 11hrs home only stoppng for fuel and parking the cruise on 90mph when on the freeways.... I bar hop, two-up wheelies are my niche (not my wifes) without her on the back it just spins in the first three gears. I love it!
If I had to do it over.... Err emm... well I am, but thats just because I am antsy and addicted to power. Just build it "right" the first time! If I have learned one thing in always building my own race motors/bikes its spend the money the first time. Any corners cut are inches cut off of your smile down the road.
Seriously, my 124 even with noisy cams, is more "rideable" than you think. Sure it will have quirks, but thats half the fun.... one of my push button decomps got sludged up on a long ride and stuck open upon start up.... you would have thoght someone had a 19/19 going off inside your eardrum.... lol.
All good affter 5000 relatively trouble three miles, going through one rear tire, I am just going bigger/faster because I can and I will never be satisfied.
-Aaron-
2009 RK "black betty"
124"
S&S parts
Under revision
Burch753 is offline   Reply With Quote
Old 11-07-2012, 07:03 PM   #13 (permalink)
No Cents's Avatar
Smart move Mother...Randy will give you a 1st class long block back to sink your teeth into. He is the man.
I've got two aluminium plates I made for bolting on top of the cylinders for shipping a motor with the cylinders and pistons installed. They keep everything nice and stable using two head bolts on each cylinder...especially with the base gaskets installed. Oh...Aviation sealant is excellent for coating the base gaskets...it never hardens and seals it bone tight...never have to worry about them weeping.
Let me know if you want to borrow the plates...I can send them to you.
No Cents
Old 11-09-2012, 04:55 AM   #14 (permalink)
155" R&R TwinCam
dog155's Avatar
dog155 is on a distinguished road
Too bad to hear of all the problems, our 124" has been problemless except for muffler hangers off the bottom of saddlebags.Finally found the permanent cure for that.we are running Police bags on both bikes zero problems.
06 RK,155" R&R TwinCam
00 Boss Hoss, 427" SB2 sbc/w Nos
05 RK project bike
Whizzer motorbike
dog155 is offline   Reply With Quote
