Need a measurement off Hurricane heads
I need the bolt spacing of the 4 bolt intake flange to see if a S&S B2 intake will bolt up. I talked to the guy from HP Inc. Jimmy or maybe Jerry thinking he makes the throttle bodies and he couldn't help. Anybody got a set they can take measurements from? across and diagonally?
Hyperformance 124ci. 11.5cr CP pistons Triple XXX S&S'G' Green filter
Wood lifters & rocker supports
R&R bottom end DT oil pump. S&S 640G cams
ported 110 heads
DaytonaTwinTec ignition
Baker KKK/4+1 pan
RB Racing 2" 2into1Blackhole
Smith Bros. pushrods
HUGE amount of help from Torque Inc.
