05-23-2012, 08:00 PM
Thread Ender
Still blowing oil out the breathers
Hopped on the bike and headed 3.5 hrs down to Kentucky. Noticed the rear brakes fading. Sure enough, got down there and I blew about 1/4 of a quart all over the right rear of the bike.
Got home from my trip and drained 4 or 5 ounces from the crank case. I checked the rubber breather valves and they are functioning properly (let air out, not in).
What's next? Leak down check?
2007 Street Glide
05-23-2012, 09:02 PM
What kind of air cleaner do you have?
05-23-2012, 09:11 PM
Axe Man
Are you running the upgraded stamped steel breathers?
2007 Ultra
114 CI
SE cases
Woods 8 cams
Reworked 110 heads by nw guy
Thayer 3 stage oil pump
V&H true duals trapp mufflers
103.. on the workbench
1982 FXRS
Scratched paint
Rotten tires
Bad brakes
Sticky clutch
Still runs like a champ
05-23-2012, 10:07 PM
Premium octane member
What breather/backing plate you running?
117ci.
05-24-2012, 06:16 AM
Thread Ender
It's a K&N element on a back plate from GMR
Bob, are you talking about the breather assemblies that mount to the rocker shaft holders/bases? If so, they are the stock 2007 model, which I think were cast aluminum.
Backing plate from GMR. I have banjo fittings and run 2 separate hoses to the ground.
2007 Street Glide
05-24-2012, 06:18 AM
Axe Man
Yep, the top breathers, swap out to the new style and you might be pleasantly surprised.
2007 Ultra
114 CI
SE cases
Woods 8 cams
1982 FXRS
Scratched paint
Rotten tires
Bad brakes
Sticky clutch
05-24-2012, 07:08 AM
Thread Ender
Found this thread:
http://www.v-twinforum.com/forums/tw...-assembly.html
I'll give em a shot.. Thanks Bob!
2007 Street Glide
05-24-2012, 07:11 AM
Thread Ender
Bob, what made you go with the Thayer pump? Were you having scavenging problems, or did you do it for the hell of it?
2007 Street Glide
05-28-2012, 11:11 AM
Thread Ender
Well I put in the new style breathers. Still blowing oil, maybe more now. One thing is that it seems it's only coming out of the rear head. Only thing I think is that the oil return in the rear head is blocked. Anyone ever encounter this?
2007 Street Glide
05-28-2012, 11:40 AM
Solution?
R&R heads, 124 inches, logged over 70,000 miles.
Breathers ran mandatory catch can at sanctioned drag strips, on the road breathers only.... the breathers would mist (ever-so-slightly).
The last 5,000 miles we ran a turbo, no oil issues....ever...
www.et-performance.com
Ray
Racer
05-28-2012, 02:01 PM
Thread Ender
Ray
Ray,
What are you suggesting I do?
2007 Street Glide
05-28-2012, 02:32 PM
vents
Contact et performance and give it a try.
They work...
Originally Posted by Pikeslayer
Ray,
Racer
05-28-2012, 06:05 PM
I think you may want to go ahead and do that leak down test now.
05-29-2012, 04:40 AM
You may be building up crankcase pressure due to cylinder leakage.
Motorcycle Poor
05-29-2012, 06:14 AM
Thread Ender
I wouldn't mind doing that leak down test. Anybody know where I can get a tester?
2007 Street Glide
| Sponsored Links |
