Opinions on copper head gaskets? : V-Twin Forum: Harley Davidson Forums
Old 01-09-2012, 09:30 PM   #1 (permalink)
Mother's Avatar
Mother wants to know Dino or Syn?
i have been running Cometic MLS head gaskets, but want to replace them. Pros? cons?
Hyperformance 124ci. 11.5cr CP pistons Triple XXX S&S'G' Green filter
Wood lifters & rocker supports
R&R bottom end DT oil pump. Andrews 64G cams
Torque Inc. JWPERF.com 110 heads
DaytonaTwinTec ignition
Baker KKK/4+1 pan
RB Racing 2" 2into1Blackhole
Smith Bros. pushrods
HUGE amount of help from Torque Inc.
153hp 149tq
JWPERF.COM
Mother is offline   Reply With Quote Quick reply to this message
Old 01-09-2012, 09:41 PM   #2 (permalink)
laserp's Avatar
laserp wants to know Dino or Syn?
Reusable. Different thicknesses vs. the cometic gaskets. I'm using the .026". Supposedly helps pinging, because they transfer the heat better, but that is a tuff one to prove.
Components:
02 FLSTCI 117, Darkhorsed, Baisley Pro-Street Heads & corrected geo. roller rockers, Axtell kit 20 deg. rev. dome pistons 11.5:1, HPI 55/58mm MaxFlow tb, Tman TR-662-2 & 3 stage pump, Boarzilla, Barnett Scorpion clutch, Jag 10 row oil cooler, tuned w/ Twin Scan II+/WEGO IIID
10 Ultra Limited 103, Andrews 54 cam, SEAC mod breather, Bigboyz ported heads @10.2 comp, Jackpot 2-1-2 header and Dyno tuned muffs, TTS, tuned w/ Twin Scan II+/WEGO IIID
laserp is offline   Reply With Quote Quick reply to this message
Old 01-11-2012, 08:14 AM   #3 (permalink)
Mother's Avatar
I'm sticking with MLS
Baker KKK/4+1 pan
153hp 149tq
JWPERF.COM
Old 01-11-2012, 11:25 AM   #4 (permalink)
Ozroder's Avatar
Ozroder wants to know Dino or Syn?
I run copper gaskets ..................just need to use a hi temp sealant like coppercoat or graphite grease on both sides ..... no other issues.
Hemrick gaskets are set to the exact bore diameter........
Ozroder is offline   Reply With Quote Quick reply to this message
Old 01-11-2012, 05:01 PM   #5 (permalink)
95280 is Prospecting
is Dustin selling the gaskets? I know Clark shut down his shop to deal with cancer.
95280 is offline   Reply With Quote Quick reply to this message
Old 01-11-2012, 05:30 PM   #6 (permalink)
Premium octane member
TXCHOP's Avatar
http://hemrickhid.sharepoint.com/Pag...adGaskets.aspx
S&S T124
Old 01-12-2012, 06:55 AM   #7 (permalink)
Armin's Avatar
Armin wants to know Dino or Syn?
Hi, you find some good information here:
http://www.bigboyzcycles.com/showthread.php?t=140
Armin.
Nothing can ruin a Man's Day faster than an almost Takeoff!
2001 FLSTCI
Heads ported and 95 CI BB by BigBoyz
48mm throttle body reworked by HorsePowerInc
Wood's TW6
Armin is offline   Reply With Quote Quick reply to this message
Old 01-14-2012, 10:07 AM   #8 (permalink)
nw_guy4_fun's Avatar
nw_guy4_fun wants to know Dino or Syn?
I see no reason to bother with them. The MLS and stock gaskets are reliable unless the surface is not flat, the torque is wrong, or the engine parameters cause a lack of gasket surface area, EG 4.25 bore stock bolt pattern. The Copper would not navigate those waters any better.
My question to the forum, if I was brainstorming alternatives, would be why not use the stock, James, Cometic, or Cyco composite gasket for the reason of LESS heat conductivity.
nw_guy4_fun is offline   Reply With Quote Quick reply to this message
Old 01-14-2012, 10:28 AM   #9 (permalink)
Nitram_b4's Avatar
after using cometic gaskets there would have to be some major benefit to get me to change, I have their head gaskets in now, but what sold me on them is their rocker box gaskets, Had nothing but issues trying to get james gaskets to seal, switched them with Cometic and sealed no problem. Both my front and rear leaked and I tried several times to get them to seal before I switched them out to Cometic and they sealed without issue first time
Nitram_b4 is online now   Reply With Quote Quick reply to this message
Old 01-14-2012, 01:46 PM   #10 (permalink)
I must be odd man out, I have not had any issues with James or the other stock style gaskets, even on some very healthy compression motors except is there was a mechanical reason why. EVOs did blow gaskets for example but the studs were pulling.
Old 01-14-2012, 03:41 PM   #11 (permalink)
porksword's Avatar
porksword wants to know Dino or Syn?
.028- .032 is ideal squish for 'normal' motors {9 - 1 to 10.5 -1 comp.} Cometic stocks a .027 head gasket for most twin cam bores = 3 3/4 - 3 7/8 - 4 - 4 1/8 etc. Remember , that your cyl. 'stretch' ! The EVO's were stretching as much as .060+ {Jerry Branch test} and that was one of the reasons they had so much trouble with base and head gaskets. NOW, the twin cam is different , BUT, not that much ! I have yet to see a test on them, but I will bet you a doughnut, that they stretch .040+ ,so if you have a stock hg {.052} and your cyl. stretchs .040 , you have a .090+ 'gap' in your combustion chamber and the air-fuel hides in there and BINGO. Ping,Ping,Ping. I have personally 'fixed' the pinging on a stock 2000 FLHT , by switching to Cometic .030 hg. Its ALL about the burn baby. Heres a test for you= Park a shovel -pan in a small shop and fire it up. 30 seconds and you can not breath from gas fumes. NOW, clear the air and park a twin cam in there with a .030 hg. You can be in there for 30 MINUTES ! Stench
porksword is offline   Reply With Quote Quick reply to this message
Old 01-14-2012, 04:27 PM   #12 (permalink)
You Ol Devil you..
The TC grows about .018
Old 01-15-2012, 07:20 AM   #13 (permalink)
msocko3's Avatar
I'm right with you, no issues with James or the stock style gaskets.
2012 GL1800 Hannigan.
