Carburetor rebuild and Stage 1 kit : V-Twin Forum: Harley Davidson Forums
Old 04-21-2011, 12:46 AM   #1 (permalink)
ryukyu1 wants to know Dino or Syn?
Ok, I am looking to rebuild the CV carb from a 2000 Duece and then put in a Stage 1 kit, but the Stage 1 parts and rebuild kit have some similar gaskets etc, but not all the same. Also, i have been told that i should replace the float, but i can't seem to find a kit with a float.
Any thoughts on the stage 1 and rebuild and also about whether or not i need the float.
p.s. Iam in Okinawa Japan and don't have good access to parts.
Regards.
ryukyu1 is offline   Reply With Quote Quick reply to this message
Old 04-21-2011, 04:28 AM   #2 (permalink)
Derrick's Avatar
Derrick wants to know Dino or Syn?
I believe Honda and Kawasaki use that same carb on some of their models if that helps.
There's parts to be had everywhere all over the net too.
Derrick is offline   Reply With Quote Quick reply to this message
Old 04-21-2011, 05:21 AM   #3 (permalink)
HugoBetz's Avatar
HugoBetz wants to know Dino or Syn?
You don't need to replace the float unless the one you have is damaged. Main jet, slow jet and needle is all you should need. Take the plug out of the idle mixture screw, if it hasn't been done already and adjust it out about two turns. then turn it in untill it begins to stumble and then back it out until the idle is at it's highest point then give it another half turn. Reset your idle to about 900 rpm's and your good to go.
2000 FXSTB-98"-Dan Vance heads-Andrews 37G and S&S gears-R&R cam plate-HD HV oil pump-Baisley pushrods-Mikuni 42MM HRS-Dynatek Ignition module-Python exhaust-TP Pro Vent rocker box-Hillside tune
2007 Electra Glide Ultra Classic
Two tours in Afghanistan
Army Corp Of Engineers
HugoBetz is offline   Reply With Quote Quick reply to this message
Old 04-21-2011, 08:29 AM   #4 (permalink)
Ed Y's Avatar
Good advice from the others. If you're talking about putting in some kind of kit from Harley like the Dynojet kit, I'd hold off on that.
If the engine is basically stock other than exhaust and air cleaner, all you really need to do is adjust the air/fuel mixture screw and either replace the needle with a better one or shim it. Stock CV carbs are generally good at the slow jet and main jet and only need help in the transition/mid-range area.
Ed Y
Retired Navy, MCPO
Old 04-21-2011, 05:37 PM   #5 (permalink)
All, thanks for the input. The engine is stock except for Khrome werks 3hp slipons, and Screaming eagle air filter. I thought i would throw in a Stage 1 kit for the carb, and just wanted some input.
Regards,
Old 04-21-2011, 05:52 PM   #6 (permalink)
CuMoFo's Avatar
CuMoFo wants to know Dino or Syn?
You can enlarge the air bleed holes in the slide to .125 for better throttle response. you can also cut three coils off the spring too.
Support the Saints M/C!
CuMoFo is offline   Reply With Quote Quick reply to this message
Old 04-21-2011, 08:30 PM   #7 (permalink)
2000FiveOh wants to know where he is and how he got here
Well he was getting good advice.....
2000FiveOh is offline   Reply With Quote Quick reply to this message
Old 04-21-2011, 08:46 PM   #8 (permalink)
93Horse's Avatar
93Horse wants to know Dino or Syn?
I would recommend replacing the intake seals.
"Our lives begin to end the day we become silent about things that matter"
93Horse is offline   Reply With Quote Quick reply to this message
Old 04-22-2011, 03:22 PM   #9 (permalink)
Kokomo wants to know Dino or Syn?
I just did this and the throttle response is great. Easy mod that really perks things up.
Kokomo is offline   Reply With Quote Quick reply to this message
Old 04-22-2011, 09:10 PM   #10 (permalink)
I read on another forum about something called a V-ductor ??
Any thoughts on this??
Regards,
Old 04-22-2011, 09:14 PM   #11 (permalink)
Canx my last!!! I actually found some info on V-ductor on this forum.
Regards,
Old 04-28-2011, 07:42 PM   #12 (permalink)
Stage 1 vs Sportster Needle
Have a 2000 Deuce with Khromeworks 3hp slipons, SE breather kit, and Sportster needle from a 1988 or '89 1200 Sportster (HD part #27094-88).
I just purchased a CV Stage 1 kit for the carb, and would like to know the difference in the needle from the kit, and Sportster needle, also do i need to install the entire CV kit and other jets or just keep the sportster needle and install some of the other jets etc etc. I've been reading that the slow jet is mostly ok for most applications. Most of my riding is around town with some touring. I am not looking for a rocket, just better performance. I know i should have asked this before ordering the kit, but !!!!
Old 04-29-2011, 11:18 AM   #13 (permalink)
CuMoFo's Avatar
You should use the entire kit with their jets, or none of the kit and the sportster needle. I'm pretty sure you have a dyno jet kit which replaces the emulsion tube and the jets are not compatable with H-D's.
Please let me know who's stage one kit you bought because it makes a difference on what you should do next.
Old 04-29-2011, 12:31 PM   #14 (permalink)
Ed Y's Avatar
I agree. If you start mixing and matching, you'd better know exactly what your doing.
Ed Y
Retired Navy, MCPO
Old 04-29-2011, 09:19 PM   #15 (permalink)
CuMoFo, I bought the Stage 1 Carb tuner kit from www.harley-performance.com
The kit contains: The Complete Stage 1 Modification Kit includes:
CVP Performance Slide Needle for Improved Midrange
• Exclusively designed and sold by CV Performance.
• Improves midrange and throttle response.
• CNC Machined from Aerospace quality billet aluminum
• Mil-Spec Hard Anodized for durability.
New Custom Light Weight Slide Spring
• Custom designed specifically by CV Performance
• Faster throttle response
• Eliminates slide "float"
CVP Velocity Emulsion Tube
• Designed to deliver a vortex spray pattern for optimal fuel atomization.
• Precision CNC Machined
• Exclusive design, only available from CV Performance.
• Accepts both CVP and OEM main jets..
Assortment of 2 CVP American Made Main Jets
Assortment of 2 CVP American Made Idle Jets
2 Stainless Steel Fuel Line Clamps
Drill Bit for mixture plug removal and optional modifications
New front airbox gasket
