107ci Dependability question : V-Twin Forum: Harley Davidson Forums
Old 02-03-2011, 06:31 PM   #1 (permalink)
FLTRSE3CLONE's Avatar
FLTRSE3CLONE wants to know Dino or Syn?
My question is would a 107ci be a motor that you could build & run for multiple riding seasons? I know its a thin bore so what would one have to do make it less apt to create problems while riding? I'm asking because when it comes to HD performance I'm not that knowledgable. Thanks in advance.
11 SERG.
117ci
570G S&S
RB RACING 2-1
SE 58MM TB
HPI INJECTORS
WFO LARRY HEADS
COMP 10:2 CCP 190
DIRECT LINK TUNE BY STROKERJLK
SAE128.09/STD131.32 HP TQ135.89 std 139.31
RC COMPONENTS WHEELS & A/C
VPC 92 CLUTCH
FOSGATE AMP, FOCAL SPEAKERS
FLTRSE3CLONE is offline   Reply With Quote Quick reply to this message
Old 02-03-2011, 06:39 PM   #2 (permalink)
guydoc77's Avatar
guydoc77 wants to know Dino or Syn?
Oh oh. I smell ....clone getting antsy to increase the size of his 103. Didn't you just get your 103 running great last summer? Stroker are you ready? I think .....clone will be making another trip up your way. Great minds must think alike. I have been having winter fantasies about 107" myself.
In answer to your question, what I have been told is this. To avoid the theoretical problem of thin cylinder walls when boring the 3.875" HD cylinders you should get the S&S 106" kit. Having said that, I will also say that Randy at Hyperformance and others have assured me that they have had zero problems boring the HD cylinders to 107".
2008 Road Glide
Phoenix Customs Bagger Brace
Glide Pro
Clearview windshield
107
CP flat tops
R&R Stage 3 heads, .030 gasket, 82cc chambers
Trued, welded, and balanced crank by Hyperformance
TMan 590 cams
SE AC
HPI 54mm TB
Supermeg with open cap and 15 discs
TTS tune by BVBob
2003 Indian Scout Deluxe
Aspen White (got it for my wife)
S&S "SuperStock" 88"
12" apes
Scary fast!
guydoc77 is offline   Reply With Quote Quick reply to this message
Old 02-03-2011, 06:42 PM   #3 (permalink)
Still the Same!
wurk_truk's Avatar
wurk_truk wants to know Dino or Syn?
BVBob and myself answered that question by having S&S 106 cylinders bored to fit new +.010 pistons. almost 20k with no problems.
I've watched closely for almost two years and have NOT heard of a catastrophic failure. Wear failure analysis will take a bit of time, but I am looking to add another 20-25k to mine this year.
I would think by now either Scott at Hillsides or Randy at Hyperformance would have found customers with wear issues.... haven't heard of any from those guys. (Guydoc) answered while I was typing!!!
120r
wurk_truk is offline   Reply With Quote Quick reply to this message
Old 02-03-2011, 07:00 PM   #4 (permalink)
I assume your boring the s&s 106 cyl to correct the out of round bore concerns? Thats the reason I didnt go with them originally & just had my 96 cyl bored.
11 SERG.
117ci
570G S&S
RB RACING 2-1
SE 58MM TB
HPI INJECTORS
WFO LARRY HEADS
COMP 10:2 CCP 190
VPC 92 CLUTCH
Old 02-03-2011, 07:05 PM   #5 (permalink)
Bad Disposition's Avatar
Bad Disposition wants to know Dino or Syn?
107ci Dependability Q.
Wurk,
Looks like you need to be a little faster on the key board, no?
It's time for a ...happy hour in UTAH
BD
Bad Disposition is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 04:40 PM   #6 (permalink)
We have done too many of these to count now. No wear issues. But if you have a 103 leave it alone.
Old 02-04-2011, 10:21 PM   #7 (permalink)
CowboyTutt's Avatar
CowboyTutt wants to know Dino or Syn?
HDWrench +1!!! -Tutt
CowboyTutt is offline   Reply With Quote Quick reply to this message
Old 02-05-2011, 08:24 AM   #8 (permalink)
troop wants to know Dino or Syn?
I've wondered about the cylinder thickness too with a 107" bore? I went the 103" route mostly because I was cheap as I got new SE 103" flat tops for $120. I doubt I'd ever go to a 107" from a 103". Some say maybe a 5/5 gain for the expense? I think that would be the time I save some pennies and bite the 117" > route...
troop is offline   Reply With Quote Quick reply to this message
Old 02-05-2011, 10:32 AM   #9 (permalink)
hightop's Avatar
hightop wants to know Dino or Syn?
I don't think I'd pull a good running 103 down to go to 107 either. I too am concerned about the thin sleeve resulting from boring a HD cylinder this big, so I've never done it, (use the S&S cylinders) but many have with no issues, so It's probably fine.
hightop is offline   Reply With Quote Quick reply to this message
Old 02-08-2011, 12:15 AM   #10 (permalink)
evostroker's Avatar
evostroker wants to know Dino or Syn?
Just in the middle of doing one myself..did lots of research...haven't seen a bad report yet!
evostroker is offline   Reply With Quote Quick reply to this message
Old 02-08-2011, 05:34 AM   #11 (permalink)
strokerjlk's Avatar
Tim. I think you are confusing the 106 S&S cly's, with what some have seen with the SE bigger bore cly's.(4.060).
I haven't seen the out of round on either of these cly's myself. maybe they stepped up the game with the SE bigger bore cly's with the 120r program. I dont know for sure, but I can tell you they map-ed out fine.
that said. unless you have a problem with the 103, as others have said I wouldnt just swap to a 106/107.
got 30,000+ on my S&S 106 with no problems. FWIW.
07 ULTRA
AMRA
SE 218
DR 218
Old 02-08-2011, 12:03 PM   #12 (permalink)
ultraswede wants to know Dino or Syn?
And we are all talking big bore as oposed to stroker 106 S&S?
Just to avoid any confusion......
Ultra 09 HDI
107 Wössner, Dewy street pro heads, SE 263E, SE AC, S&S SPO, Fullsac DX, TTS, E85, 6.2s
ultraswede is offline   Reply With Quote Quick reply to this message
Old 02-08-2011, 03:13 PM   #13 (permalink)
Don Dorfman's Avatar
The 3.932 bore has been very reliable for my customers
"I know its a thin bore"
Nope, just the spigot, the sleeve is still stable and not thin.
Old 02-08-2011, 05:52 PM   #14 (permalink)
vmax-94's Avatar
vmax-94 wants to know Dino or Syn?
Who makes the 107 piston? I have my crank at darkhorse and have 37,000 miles on bike so instead of honing and re-ringing maybe i will just go with the 107 all bore idea.Thanks
vmax-94 is offline   Reply With Quote Quick reply to this message
Old 02-08-2011, 06:30 PM   #15 (permalink)
axtell is what ive been looking at
11 SERG.
117ci
570G S&S
RB RACING 2-1
SE 58MM TB
HPI INJECTORS
WFO LARRY HEADS
COMP 10:2 CCP 190
VPC 92 CLUTCH
