t-man 625 : V-Twin Forum: Harley Davidson Forums
Old 05-11-2010, 04:56 PM   #1 (permalink)
bowtech40's Avatar
bowtech40 is on a distinguished road
t-man 625
Anyone have any long term experiance with this cam? I am considering it, but am wondering if it is noisey. I talked with TR himself, and he claims a broad torque curve and that some are running without roller rockers. I am not sure that they can be run with my R&R stage 21/2 heads though.
2007 FLHX street glide
117" big bore
R&R stage 5 cast heads
T-man 662-2 sticks
S&S dual runner air filter
Roller rockers
09 oil pan
V&H power dual head pipe, run under frame.
Crusher mufflers
Juice clutch
Axtell pistons
Thayer 3 stage oil pump
And a great BVBOB tune!
Just a few dollars more!!
bowtech40 is offline   Reply With Quote
Old 05-11-2010, 07:52 PM   #2 (permalink)
rock92's Avatar
rock92 is on a distinguished road
i have a couple thousand miles on mine now and its a great cam. once its properly tuned they are very quiet and the exhaust has a nice thump to it. i do have roller rockers with mine. my torque curve was really broad, from 2400 to 6000 as seen below:
http://www.v-twinforum.com/forums/dy...s-s-106-a.html
If you are reading this, thank a teacher.
If you are reading this in english, thank a vet.
rock92 is offline   Reply With Quote
Old 05-11-2010, 08:06 PM   #3 (permalink)
metalfab1 is on a distinguished road
I run the tman725 in my 117 and that is alot quiter than my 9b
metalfab1 is offline   Reply With Quote
Old 05-11-2010, 11:12 PM   #4 (permalink)
Black Devil's Avatar
Black Devil is on a distinguished road
I'll let your know, I'm getting the 625's installed as we speak. Hopefully it's ready to go by the end of the week.
Black Devil is offline   Reply With Quote
Old 05-12-2010, 07:49 AM   #5 (permalink)
Doof! There it is.....
'05Train's Avatar
'05Train is on a distinguished road
I'm running 625s with roller rockers. Lots & lots o' torque and nearly no valvetrain noise.
'05 Vivid Black Night Train
Lots o' black
103 by Dave at JD's
116.70/116.01 SAE
'10 Scarlet Red/Vivid Black Electra Glide Ultra Limited
Stage 1, Intiminators, 575s
'05Train is offline   Reply With Quote
Old 05-12-2010, 10:47 AM   #6 (permalink)
al704's Avatar
al704 is on a distinguished road
625 with roller rockers, very smooth and quiet cam
04 Heritage
98" cylinders and pistons by Hillside
Hillside Stage II Heads
T-Man 625
Baisley Roller Rockers
HPI 48mm TB
Zippers AC
FatCat w/Quiet Baffel
TTS Master Tune
assembled and tuned by JD's
103.9 HP SAE
106.24 TQ
al704 is offline   Reply With Quote
Old 05-12-2010, 06:29 PM   #7 (permalink)
PhilM is on a distinguished road
I've installed a couple sets of TR625's, both with & w/o roller rockers. They are SHOCKINGLY quiet cams & do make a really broad torque curve.
With quality headwork, the 625 will take advantage of a larger TB too....
PhilM is offline   Reply With Quote
Old 05-12-2010, 10:10 PM   #8 (permalink)
Ozroder's Avatar
Ozroder is on a distinguished road
I am about to run these in my 103 build.............I had a set of Woods heavy spring set which made these cams really bang on the seat when closing.............I have just changed over to vThunder 5/16" beehives that have 150 on the seat and 375 at .625 lift.
I have not installed the intake yet so I have not run these cams to see loudness with new spring set and performance.
What do you use for springs and what do you have as seat and full pressure?
Ozroder
Ozroder is offline   Reply With Quote
Old 05-12-2010, 10:31 PM   #9 (permalink)
Ozroder
The ones I have done were with TMan Stage 3 (dual coil, 180lb spring) heads and/or his new Stage 2 ProTouring heads (new 180lb beehive). I do not know the compressed tension.
There was no noticeable difference in noise, they are quiet either way. I used HD B lifters on the Stage 3 build and HQ BlackOps lifters on the Stage 2. Additionally, The Stage 3 had roller rockers & the Stage 2 used stockers.
Old 05-13-2010, 01:22 PM   #10 (permalink)
Ozroder's Avatar
Thanks for the info bro................I definiteley need a run in map for a 103, TR625`s, 52mm S&S and whatever pipes............I`m running Bassani Pro Streets but I will end up with a Supertrapp Supermeg 2:1 at a later date.
The Bassanis are way too loud for a 6am leave to work.........but thet do produce excellent numbers always........
I was not able to open the map you gave me Roderic but your help was much appreciated bro..............
Ozroder
