255 Cam : V-Twin Forum: Harley Davidson Forums
Old 02-03-2010, 12:03 PM   #1 (permalink)
nodiggit719 wants to know Dino or Syn?
255 Cam
Is the SE255 cam a plug n play part for an 07 RK? I have the cam, bearings and adjustable pushrods. . . is there anything else i need to make this swap happen? Thanks in advance.
nodiggit719 is offline   Reply With Quote Quick reply to this message
Old 02-03-2010, 01:14 PM   #2 (permalink)
strokerjlk's Avatar
maybe a shim.
every stock to aftermarket swap I have done needed a diff one .
07 ULTRA
AMRA
SE 218
DR 218
Old 02-04-2010, 01:05 PM   #3 (permalink)
"Jane you ignorant slut!"
ceraaa42's Avatar
ceraaa42 wants to know Dino or Syn?
You don't need the push rods FWIW. The push rod in the SE bikes that use that cam have the same part numbers as the non-SE bikes.
What are you planning to do for a tune after installation?
Chris
Candy red sunglow
103"
SE255 cams
SE Air cleaner
Fatcat Quiet baffle
Bagger brace
43 member
ceraaa42 is offline   Reply With Quote Quick reply to this message
Old 02-04-2010, 05:57 PM   #4 (permalink)
BDChopper wants to know Dino or Syn?
Yea, you need to refill your motor oil after you change the cams. I'm sure you already knew that though.
BDChopper is offline   Reply With Quote Quick reply to this message
Old 02-04-2010, 09:10 PM   #5 (permalink)
Nuckin Futs's Avatar
Nuckin Futs wants to know Dino or Syn?
255 in a 103?
I have a 103 in my 07 Nighttrain with no after market cam. Will the 255 go in my 103? I'm not planning any head work. If not the 255 what cam would work? Sorry about the hijack of the thread.
Nuckin Futs is offline   Reply With Quote Quick reply to this message
Old 02-04-2010, 09:23 PM   #6 (permalink)
thanks
after the swap I will have:
103ci
arlen ness big sucker
supertrapp se slip ons
255 cam
PCIII
Financially restricted at the moment. Any other mods that aren't gunna cost me a full paycheck? Fire departments don't pay.. .
Old 02-05-2010, 06:10 AM   #7 (permalink)
:. Bones Surgeon :.
ItalianGlide wants to know Dino or Syn?
Smile Similar build
That is pretty much the same build I have.
FATCAT w quiet baffle and street ported heads (not that expensive) plus TMAX (expensive) are the main differences: I am very happy right now.
In the beginning I was experiencing a kind of short breath ot these cams past 4K rpms. After 1K miles I've seen some autotuning in the higher rpm range that somehow made it better... or maybe I just got used to it.
What really matters is where u mostly play the throttle: I love lower rpms pull these cams deliver, and I can live with some lazyness in higher occasional revving.
Just my .02.
ItalianGlide now proudly rides:
2008 CrossBones,
103' SE, BigBoyz heads, 255 SE cams, SE A/C,
D&D FatCat, Thundermax (map 552)
ItalianGlide is offline   Reply With Quote Quick reply to this message
