Twin cam head bolts : V-Twin Forum: Harley Davidson Forums
Old 01-10-2010, 07:20 PM   #1 (permalink)
alhd1973 wants to know Dino or Syn?
Twin cam head bolts
Why the torque to 12to14 ft. lbs. then a 1/4 turn? why not a final torque # ? Do you need to replace studs each time?
alhd1973 is offline   Reply With Quote Quick reply to this message
Old 01-10-2010, 07:26 PM   #2 (permalink)
rob71458's Avatar
rob71458 wants to know Dino or Syn?
That technique is called "torque to yeild". It's more accurate, and sets the "stretch" of the fastener.
rob71458 is offline   Reply With Quote Quick reply to this message
Old 01-10-2010, 07:48 PM   #3 (permalink)
rbabos wants to know Dino or Syn?
This is quite often done away with and a set torque used instead. Both stretch the studs. Studs can handle a few cycles of reuse and the engine pros on this site will know better than I do and likely respond to that question.
Ron
rbabos is offline   Reply With Quote Quick reply to this message
Old 01-10-2010, 08:00 PM   #4 (permalink)
strokerjlk's Avatar
everyone has there own way. as Ron indicated.
mine is 42 ft-lbs. final reading.
tighten in sequence @5 ft lbs increments until 35 ft lbs then 7 ft lbs.
I have also screwed up my sequence and went to 40 ft lbs in 5 ft lbs increments then did a 2 ft lbs increment.
never had a head warp or blow a gasket yet.
07 ULTRA
AMRA
SE 218
DR 218
Old 01-10-2010, 09:25 PM   #5 (permalink)
Shift_Happens
HarlessR's Avatar
HarlessR wants to know Dino or Syn?
Ron
How many cycles can you reuse the studs?
2005 FLHT
88" Andrews 21N cams
HarlessR is offline   Reply With Quote Quick reply to this message
Old 01-10-2010, 09:30 PM   #6 (permalink)
route66paul's Avatar
It has to do with the way the stock gaskets are constructed. If you were to run a plain copper gasket, be sure to use the specs that come with the gasket.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
HPI bored throttle body
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
Old 01-11-2010, 08:00 AM   #7 (permalink)
Coolmaker's Avatar
Coolmaker wants to know Dino or Syn?
I do the same way, that is the way diesel heads are torqued and never have had one blow.
Coolmaker is offline   Reply With Quote Quick reply to this message
Old 01-11-2010, 08:09 AM   #8 (permalink)
Studs are usable several times. The OEM stud is a very stong item. If you have an engine that has been apart many times then a new set would not be a bad idea. Or if you are pulling the stud and for whatever reason you need to use a pipe wrench and it gets gouged then replace them. I just pulled a set out of a early engine and they where a mother to get out. Heat double nutted, JIMS stud puller nothing worked. Pipe wrench did get them out with heat but they are toast.
Old 01-11-2010, 11:30 AM   #9 (permalink)
Shift_Happens
HarlessR's Avatar
Thanks for that info
2005 FLHT
Old 01-11-2010, 12:56 PM   #10 (permalink)
HDMD88 is reading this now saying WTF is this? HDMD88 is reading this now saying WTF is this?
There are times when we have damaged threads on the studs or head bolts such as a burr or anything else that would cause extra friction or resistance as the two where be bolted together. This extra force caused by the problem threads will cause the torque wrench to give a false reading....ie....the final torque will be lighter than the wrench says it is. The 1/4 turn method eliminates the reading of the torque wrench and disregards the extra drag of the problem threads and you end up with a truer final torque.
The auto industry has been doing this method for years, Harley adopted this 1/4 turn method when the EVO was introduced.
Doc
HDMD88 is offline   Reply With Quote Quick reply to this message
Old 01-11-2010, 01:33 PM   #11 (permalink)
Doc
Damn it Doc. Why do you have to make sense all the time? I take it, this is your preferred method?
Ron
Old 01-11-2010, 02:10 PM   #12 (permalink)
Coolmaker's Avatar
I always chase the threads, and use machine oil to eliminate the drag that Doc speaks of. Was taught that many, many years ago.
Old 01-11-2010, 02:48 PM   #13 (permalink)
I check things out as well, but as you know, torquing a fastener is not always as simple as waiting for the click, to get all 4 equal. Assuming the threads are perfect, those flanges on the head nuts can create considerable variations in torque readings between them. Some stick and drag more than others, especially when sneaking the torque up in increments, even when lubed, since that gets squished out quickly. The tighter it gets the more deviation could happen. With the initial 12-14 or whatever any deviation will be negligable. This small amount, with the extra 90* will not multiply into gross amounts of unequal readings when done. Only pointing out the way I see it, but honestly havn't used the method, yet.
Obviously both methods work.
Ron
Old 01-11-2010, 03:46 PM   #14 (permalink)
Mtclassic wants to know Dino or Syn?
do the 90* method using a beam type torq wrench and unless like HDMD88 says you have a burr or something you will be at ~42-45 ft/lbs.
Mtclassic is offline   Reply With Quote Quick reply to this message
Old 01-11-2010, 04:50 PM   #15 (permalink)
strokerjlk's Avatar
I dont like the 90 deg method because to be honest I am a dumbazz and the first time I tried it I stripped a stud in the case.
90 deg that's 1/2 turn RIGHT LOL.
probably would have stripped using 5 ft lbs method also but I like knowing it's there not wondering if it's to tight or not tight enough.
just me everybody has there theories.
07 ULTRA
AMRA
SE 218
DR 218
