Its time, this Friday, for final tune after break in. We will be replacing SE ignition with something?? Leaning towards S&S IST ? Would appreciate hearing others experience w/ignitions on big bore builds.
build is:
113" 4.060 bore 4 3/8 crank and wheels Wiesco 10.5 to 1 pistons
S&S .625 gear drive cams Roller rockers Mikuni 42mm carb
Rinehart true duals
Thanks for any suggestions on the ignition system.
