AdvanstarMotorcycleShows
Motorcycle-CommunicationBub Enterprises
Custom DynamicsJardineProducts.comMotorcycle.comMBO EnterprisesCycleGear.comLeslie Kay's
Old 10-30-2009, 08:51 PM   #1 (permalink)
jam65's Avatar
jam65 is on a distinguished road
Diagnose sumping
What do you look for to determine if sumping is being a problem?Also how many ounces of residual oil left in engine is a determining factor?
jam65 is online now   Reply With Quote
Old 10-30-2009, 09:48 PM   #2 (permalink)
Premium octane member
TXCHOP's Avatar
Get the motor good and warm. I like to take a short trip of at least a few miles.
Get home and pull the pipe plug on the bottom of the cases. Let the oil drain into a measuring cup to see how many oz's are in there. Usually 4-6-8ish in there which should be o.k.
Usually when a motor is sumping it will run hotter and feel really sluggish and may even sound different. It can clear up and go away though.Usually repeat roll ons will tell ya..
Careful with the plug and do not over tighten...
Axtell 117 cyls and pistons
Mikuni HSR48
S+S Super D manifold
Black Boarzilla
TXCHOP is online now   Reply With Quote
Old 10-30-2009, 10:42 PM   #3 (permalink)
jam65's Avatar
Thanks Chop,I still need a couple more heat cycles before road test.Does a higher lift cam make more left over oil more acceptable?
Old 10-31-2009, 08:08 AM   #4 (permalink)
I had a brand new 07 FXSTC come in for a 1k. Checked the charging system and I'll be damned, something didn't feel right. It came down of the rev's VERY fast, sluggish like TXChop said. Hold it wide open in neutral and it couldn't pass 4k. Pulled it all apart to find that the factory never drilled the oil pump passage that scavenges the flywheel compartment
They guy got his bike bike and couldn't believe how much better it ran
Old 10-31-2009, 08:29 AM   #5 (permalink)
TXCHOP's Avatar
Holy $hit aharp, QC at its best. Good find though..
And no, Jam, cams don't change the amount allowed.
Mikuni HSR48
Black Boarzilla
Old 10-31-2009, 08:36 AM   #6 (permalink)
Yes, tricky one indeed
It didn't make me feel any better when my rep from the moco said "oh yeah, guys find stuff like that all the time"
Old 10-31-2009, 12:35 PM   #7 (permalink)
TXCHOP's Avatar
Jam are you concerned about sumping? Unless you are, dont worry about it. As long as you got the assembly down, you should be fine.
Mikuni HSR48
Black Boarzilla
Old 10-31-2009, 12:53 PM   #8 (permalink)
01fxdx's Avatar
01fxdx is on a distinguished road
for what it's worth, when i ran into sump issues, the oil temp got rediculous.
107" axtel terrorist
thundertek cylinder heads
cams= not woods....
super "D"
loud d&d
01fxdx is offline   Reply With Quote
Old 10-31-2009, 01:11 PM   #9 (permalink)
Coolmaker's Avatar
Originally Posted by 01fxdx View Post
for what it's worth, when i ran into sump issues, the oil temp got ridiculous.
That is because it aerated, mine did the same thing..
06FLHRCI
Coolmaker is online now   Reply With Quote
Old 10-31-2009, 04:00 PM   #10 (permalink)
Bigtwin101's Avatar
Bigtwin101 is on a distinguished road
what causes sumping? sometimes my bike is sluggish between 2500 and 3000 rpm. I have 248 degree oil on a 58 degree day
02 Ultra (Dirty Pearl)
couple 4.125 AXTELL Cylinders
couple worked over heads
worked over crank
Pair Woods cams
Baker 6 speed
Rineharts
TMAX
Bigtwin101 is offline   Reply With Quote
Old 11-01-2009, 06:01 AM   #11 (permalink)
DRG
DRG's Avatar
DRG is on a distinguished road
Had a bad piston oiler. I was dumping 20 oz. out the crankcase.
DRG is offline   Reply With Quote
Old 11-01-2009, 06:25 AM   #12 (permalink)
kemo is on a distinguished road
If you had the cams changed and you suspect sumping was the oil pump aligned when they put it back together.
kemo
kemo is online now   Reply With Quote
Old 11-01-2009, 06:55 AM   #13 (permalink)
reg26's Avatar
reg26 is on a distinguished road
What is the "pipe plug" on the bottom of the cases and what is it used for besides checking for sumping. Been wondering about all this sumping talk.
2009 FLHX, Engine built by Rosas Cycle in NY
reg26 is offline   Reply With Quote
Old 11-01-2009, 01:20 PM   #14 (permalink)
ultraplusrotax's Avatar
ultraplusrotax is on a distinguished road
The pipeplug is a plug at the lowest part of a rubber hose coming down from the seperate oiltank, as seen on Sportsters and Softails.
When changing oil you have to remove the plug so that the oiltank is drained, and of course, after the tank is empty, replace the plug in the hose before filling up the tank.
Touring models , not having a seperate oiltank, do not have that pipeplug: their oil is contained behind the transmission, and can be drained by removing a hexagon steelbolt.
"Sumping" is the accumulation of oil in the crankcase, where it shouldn't stay in a DRY SUMP system like in H-D engines.
ultraplusrotax is offline   Reply With Quote
Old 11-02-2009, 06:43 AM   #15 (permalink)
HugoBetz's Avatar
HugoBetz is on a distinguished road
The pipe plug is at the bottom of the case half just below the cranks shaft. I checked mine for sumping and got about 3 ounces of oil. If you were anal about changing oil you could drain the little bit of oil from there at normal change intervals. It's not necessary as only a few ounces are there normally.
Opinions are like belle buttons, ever one has one.
Hugo
HugoBetz is offline   Reply With Quote
