Custom DynamicsAdvanstarMotorcycleShowsFuel MotoMotorcycle-CommunicationMBO EnterprisesJardineProducts.comCycleGear.com
Old 10-30-2009, 09:23 AM   #1 (permalink)
TimberwolfZ28 is on a distinguished road
Let's talk final drive ratio...
Would it be advantageous to drop a tooth on the front pulley when going with a more aggressive (read as: higher rpm) cam profile?
Or would the added torque (even with a curve that's heavier to the right) create too much problem keeping the front end on the ground?
TimberwolfZ28 is offline   Reply With Quote
Old 10-30-2009, 07:03 PM   #2 (permalink)
BadWeather is on a distinguished road
I am running 3.37 have a 24T at engine and 37T on clutch basket. I love the added torque although the rpm are around 300 higher. When the kitty builds back up I will install a OD tranny. As for cams you want to pick a more mid range style with a decent lift so you do not die at the higher rpms. The higher final drive gives you this latitude to choose such a cam for a heavy bagger.
06 CVO 113 Ultra
SE MVA Heads
SE 251
SE 50mm TB
SE 10.5:1
ThunderMax ECM
Zipper A/C
AIM 92T VPC
D&D Fat CAt
3.37 Final Gearing
BadWeather is offline   Reply With Quote
