Pro PadMBO EnterprisesBub EnterprisesMotorcycle-CommunicationFuel MotoRRcycles.com
Extreme Custom Engraving
Old 10-30-2009, 12:02 AM   #1 (permalink)
TOMCENTRAL's Avatar
TOMCENTRAL is on a distinguished road
Cams
http://www.sscycle.com/modules/feature/easystart/ Regards,Tom
TOMCENTRAL is offline   Reply With Quote
Old 10-30-2009, 01:04 AM   #2 (permalink)
aka_matt is on a distinguished road
the 583 cam has a 15 intake close... and we thought the SE255's 25 IC was early...
and the duration is 204/262... now THAT'S a big split...
Matt
FOR SALE
aka_matt is offline   Reply With Quote
Old 10-30-2009, 06:47 AM   #3 (permalink)
Iron Will
Hillside's Avatar
Probably they want to dump the heat with that exhaust duration.
Scott
Old 10-30-2009, 08:23 AM   #4 (permalink)
Premium octane member
TXCHOP's Avatar
The cranking test was kinda cool, suprized the stater didnt fry...
Would like to see it done with a 124 motor and 11.5 to 1 compression though.
Anyone know what a CCP test shows on these? Also, how would you test it?
Axtell 117 cyls and pistons
Mikuni HSR48
S+S Super D manifold
Black Boarzilla
Old 10-30-2009, 08:38 AM   #5 (permalink)
0043--Licensed to Doof!
Geezer-Glide's Avatar
Geezer-Glide is on a distinguished road
What, nobody at S&S ever heard of compression releases?
Last thing I want is some gizmo flopping around on my cam shafts.
I'll take a pass on this.
I Doof, therefore I am.
D.F.F.D
Geezer-Glide is offline   Reply With Quote
Old 10-30-2009, 09:59 AM   #6 (permalink)
deuce04's Avatar
deuce04 is on a distinguished road
[quote=Geezer-Glide;1696760]What, nobody at S&S ever heard of compression releases?
I'll take a pass on this.[/QUOTE
This is not new,the asian makers have been using them in motocross bikes for sometime now.
http://www.v-twinforum.com/forums/attachment.php?attachmentid=40225&d=1176768702
deuce04 is offline   Reply With Quote
Old 10-30-2009, 11:08 AM   #7 (permalink)
Axe Man
BVBOB's Avatar
Ive actually seen these cams in person at last years Vtwin Expo and have heard a buddy of mine's 117 Xwedge start with them, it basically cranks like the plugs are out, good question though on the ccp, I guess if you have your numbers and measurements right upon initial assembly you should know what you have. Could make troubleshooting a bit difficult though.
2007 Ultra
Woods 7H cams
Heads ported by BigBoyz
D&D Fatcat, SE/AC
1982 FXRS
Scratched paint
Rotten tires
Bad brakes
Sticky clutch
Still runs like a champ!!
Old 10-30-2009, 01:00 PM   #8 (permalink)
strokerjlk's Avatar
Bob
when I looked at these cams when they hit the market the specs were at .023 instead of .053 lift.
now I cant even find those spec's
so question is.....are the specs for the 585 easy start the same as the 585G ?
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
3 GAL. AUX FUEL CELL
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
Old 10-30-2009, 07:15 PM   #9 (permalink)
looks like the lifter roller would ride on center over the hole?? am i seeing this right? kohler and wisconsin industrial engines have had auti realeases on the cam for years, but once started, the eccentric moves out of the way,and the tappet has 100% of cam surface to ride on.
am i seeing this correctly? the lifter rolls over a hole at 0ver 6000 rpm?
Old 10-30-2009, 09:52 PM   #10 (permalink)
TXCHOP's Avatar
Yup, Dennis wonder what heavy spring pressures and high RPM use do to this over the long run? I am sure they are fine as S+S backs them, but i wont be able to try them out unless Bobby Wood starts with them.......lol
Mikuni HSR48
Black Boarzilla
Old 10-31-2009, 08:57 AM   #11 (permalink)
The V-Rod is using a similar set up, although a touch more simple since it's OHC and shim under bucket.
Old 10-31-2009, 09:11 AM   #12 (permalink)
Moneygreen
arealinvestor is on a distinguished road
Now that is funny!!!
Craig G.
