Fuel MotoAmerican Side Road CycleMotorcycle.comMotorcycle-CommunicationPro Pad
BikeBanditCustom DynamicsProCharger.comRRcycles.com
Old 10-23-2009, 05:52 PM   #1 (permalink)
bowtech40's Avatar
bowtech40 is on a distinguished road
Valve sizes- help me understand
Was looking at different sites today to kill some time, and noticed the different valve sizes on the high dollar heads offered by some of the better know builders. Zippers has a 2" intake and a 1.630 ex, T-man makes his stage 4 with a 2.020 amd a 1.615 etc. Am I correct to say that the bigger intake is more for top end power, or does the rest of the porting come into play to? Are heads like this only for big inch motors, or can they be used say on a 103" or smaller with good results? Just curious, as I know cylinder fill is important, but so is velocity.
2007 FLHX street glide
103" big bore
Bigboyz headwork
Andrews 31h cam
BC gerolomy big air filter
SERT tuned with twinscan
D&D fatcat w/quiet baffle
Just a few dollars more!!
bowtech40 is offline   Reply With Quote
Old 10-23-2009, 07:42 PM   #2 (permalink)
the holy grail! good question! i have been asking the same forever. got the best explanation from hillside and bean. there are others, but these guys explained it so i could understand.
Old 10-23-2009, 07:55 PM   #3 (permalink)
baggersport's Avatar
baggersport is on a distinguished road
I got more better stuff too Dennis....when you're ready......
www.bigboyzheadporting.com
Big Boyz Street Heads
207-242-8374 Cell Phone
207-621-8089 Port/Dyno Shop
baggersport is offline   Reply With Quote
Old 10-23-2009, 07:58 PM   #4 (permalink)
give me time man, im still trying to absorb what you and scott told me. im slow ya know. LOL
Old 10-23-2009, 08:15 PM   #5 (permalink)
...ahhh, yes......I 'member. It will help ya tie more of it togethah...
...we'll get you in on a conference call....feed you info till you squeeeel like a pig.....LOL
Old 10-23-2009, 08:17 PM   #6 (permalink)
Iron Will
Hillside's Avatar
Different applications, different valve sizes, but you do get limited to only so large, when needed, as valve to valve at TDC can become an issue, with some of the bigger cams. Shape of the valve is also important.
Scott
Old 10-23-2009, 08:59 PM   #7 (permalink)
OUCH! That hurt
wfolarry's Avatar
wfolarry is on a distinguished road
Food for thought:
I built 2 124's for twin brothers. Their bikes were like them - identical twins. The only difference was the heads. One had a set of Zipper's CNC heads that I tweaked & the other had B2 heads. Off the line the Zippy bike was quicker. After about 1/2 way down the B2 head started coming on. At the finish line the B2 head was way out in front. The interesting thing about it was on the dyno they both made 170 HP. Think about it.
35 years of ridin' & wrenchin'
wfolarry is offline   Reply With Quote
Old 10-23-2009, 10:16 PM   #8 (permalink)
Okla.Dave is on a distinguished road
Originally Posted by wfolarry View Post
Food for thought:
Would this be due to one making it’s H.P. and torque to early.
The other making it’s H.P. and torque later.
The later tq. and h.p. used its gears at first and later used tq. and h.p. to move the bike quicker?
Does that sound right?
Okla.Dave is offline   Reply With Quote
Old 10-24-2009, 12:27 AM   #9 (permalink)
qtrracer is on a distinguished road
Sounds like the B2 in that application is faster to the finish. I will leave all the technical jargon to those who can speak and understand it, I only understand winning and losing.
08 SG 103" SE MVA Heads SE 10.5 Pistons SE 251 Cams SE 58 mm TB RB Racing 2-1
qtrracer is offline   Reply With Quote
Old 10-24-2009, 01:28 AM   #10 (permalink)
towboattrash34 is on a distinguished road
Then look at R&R's with raised ports and Baisley's Hybrid heads they also have a raised ports.... if you go too big for your cam you kill velocity then you have to work the ports.... you can have too much velocity also..... you said something about T-Man's 4 heads.... compare the flow chart to his 3 heads and tell us what you see....
here is his flow charts if someone care to explain them.....
stage 2
stage 3
stage 4
Broke Down Money Pit....
towboattrash34 is offline   Reply With Quote
Old 10-24-2009, 01:35 AM   #11 (permalink)
if you look at stage 3 and 4 you see with a bigger intake it more flow but killed some of the exhaust flow.... both have same exhaust valve... now what would need to be done to bring up the exhaust flow???? or would you??? maby Scott or wfolarry or Bean could tell us a story ???? which would be a better head 3 or 4 ???
Old 10-24-2009, 09:03 AM   #12 (permalink)
strokerjlk's Avatar
look at the cfm numbers on the left of the chart. It didnt kill the exhaust flow. just diff scale numbers. looks like ex stayed about the same. while intake increased with the increase in valve size.
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
3 GAL. AUX FUEL CELL
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
Old 10-24-2009, 09:54 AM   #13 (permalink)
looks like ya need a biggass cam to work well.
Old 10-24-2009, 10:19 AM   #14 (permalink)
KingofCubes's Avatar
Right as far as my experience. The better heads have correct size valves for the application, the best cfm matched with velocity. This has been hashed over many times on this and other boards. Quick revving seems to come from the right blend of flow and air speed. The R&R stage 5 heads for instance will flow 295 cfm with a 1.94" intake valve at 28 inches of depression and show between 650 and 670 feet per second at 150 inches of depression throughout most of the lift range. These heads are the best choice for larger engines but not as early torque as the smaller port stage 4's with a 1.9" valve.
King Of Cubes
515-266-6381
www.kingofcubes.com
Old 10-24-2009, 10:55 AM   #15 (permalink)
Knighty-Knight is on a distinguished road
Food for thought:
The above post answers a lot of questions if you read through it.
It also raises questions though:
Both bikes were twins, but should they have been?
Wouldn't both bikes benefit from different gearing given the different manifestations of power?
I think it also goes to show that peak numbers mean diddly squat.
Knighty-Knight is offline   Reply With Quote
