10-21-2009, 08:10 PM
117" build update
I thought you folks would enjoy an update on my 117" build as I have about 3500mi. on it now. 80% of these miles were rode in the mountains of No. Az. and Co. The other 20% were put on in "the Valley of the Sun" (Phoenix area) with temps ranging from high 90's to 110-115. This thing didn't miss a lick and the "smile factor" is still there everytime I throw a leg over her. Just blip the throttle on her going up a steep grade in the mountains and you are around people in an instant. All around mileage is 40-45mpg depending on how hard you want to hammer it. Hit starter button and starts every time(hot or cold). Have forgotten comp. releases a couple times but it starts right up. Real happy with the build. Thanks again Steve and Michele!! Will have to make an apptmt soon for a new rear tire!!
03 RKC= 117" built by Steve@GMR, Axtell kit, 10.5 CR, R&R 5pc crank w/Timken conversion, R&R Stage V heads, 615/585 sticks, HPI 51mm T/B and Zippers BIG A/C, stock injectors, SE billet cam plate & hi-volume pump w/ Latus spring, Rivera Pro clutch, D&D FatCat w/big bore perf. baffle, Jagg 10 row low mount, TTS MasterTune. Dyno tuned by Steve. 124HP 139TQ
10-21-2009, 08:12 PM
Moneygreen
What rod lenth are you running?? I see you have Axtell pistons & cylinders & a R&R crank!!
Craig G.
10-22-2009, 01:44 AM
Crag the R&R is 7.690 i think....
Broke Down Money Pit....
10-22-2009, 04:13 AM
Moneygreen
So I guess You have to get Axtell to make longer cylinders? Because isn't the standard S&S rod a 7.600????Or can you run the regular Axtell cylinders with this longer rod???
Craig G.
10-22-2009, 08:59 AM
Adj the pin height.
10-22-2009, 09:59 AM
Spoke with Axtell and they said no problem extending cylinder heigth for the R&R crank.
10-22-2009, 10:35 AM
Most times with the R&R crank you still have to adjust piston TDC. Can be done on a mill or a lathe. I use a mill with a 3 jaw chuck on a rotary table ( with sine plate ) with custom made jaws that hold the piston in the oil ring groove.
10-22-2009, 10:47 AM
Bike Builder
I had Randy (King of Cubes) build me his ductile iron cylinders for my build and they were rite on the money.
R&R/Hyperformance 124" 143hp/144tq SAE
R&R billet heads
R&R 5 piece crank
R&R two piece Cam plate
Dave Makie 630G CAM
Hyperformance ductile Iron cylinders
11.53:1 comp.
55mm Max FlowHPI
D&D Borzilla
Baker OD6 tranny
Baker Plus 1 oil pan
Fueling pump
10-22-2009, 04:17 PM
Excellent news on your build....I hope I get 40-45mpg with mine!
I'll pick it up Monday and will head back to Texas
Karl
'06 Ultra Classic
GMR/Axtell 117"
R&R 5 piece crank/Timken
Woods TW8g's
HPI 51mm
SuperTrapp 2:1
SE 6 speed
TTS tuned by GMR
Momma's Bike 2008 FLHX
XIED's
10-22-2009, 04:36 PM
Moneygreen
Does anyone know if the SE billet camplate will work with the R&R crank???Or do you have to use their camplate??
Craig G.
10-22-2009, 06:17 PM
SE camplate
I am running the SE camplate in this build. See sig. The motor is super quiet although the neighbors sure don't like the D&D big bore perf. baffle. I kind of take it easy thru the neighborhood but I let it warm up 3-4 minutes before I take off and everyone knows road king 100 is going for a "putt".
10-22-2009, 08:11 PM
Moneygreen
Thanks Road,I bet that thing sounds great & runs great!!!
Craig G.
