113" Build : V-Twin Forum: Harley Davidson Forums
Old 10-04-2009, 06:48 PM   #1 (permalink)
Coonass Extraordinaire
beaureed445's Avatar
beaureed445 is on a distinguished road
Talking 113" Build
For those of you who read multiple forums, and see this multiple times, I apologize. But, I thought I'd share with my project with all who care to read about it.
Well, it's that time of year when the leaves begin to change, and I decide to tear my bike apart again. This project is going to turn my 103" into a 113". I've already amassed a stock-pile of parts:
Heads- Baisley Super Stock (1.94 intake, 1.63 exhaust, 82.3 cc chambers)
Roller Rockers
Throttle Body- HPI 55mm
Injectors- SE 4.89
Intake- SE Heavy Breather (but may switch to HPI Eliminator)
Push Rods- GMR Adjustable
Jugs- SE 4.060 (bored to 4.065)
Pistons- HQ 4.065 (-7 cc dished)
Crank- Darkhorse
Cams- TMan 590G
Gears- S&S
Exhaust- D&D Fatcat (Std baffle, but may go big bore)
Tuning Device- PCIII (thinking about swapping to TTS Mastertune)
Clutch- Stock basket w/ SE Friction Plates and Barnett Spring (If it slips, we'll address it)
According to Bigboyz calculator, I should be at 10.7:1 compression (w/.030 head gasket). Corrected for my altitude, I'll be running 9.68:1, with 199.2 ccp. I'm going to tear the motor out (with professional help from a friend), and send the lower end to Dave at JD's Cycleworks. Dave already has my crank; jugs are at Hillside getting bored to match pistons. He will split my cases, add Timken and Darkhorse Crank. Bore cases to fit cylinders, and send back. We'll re-assemble here, heat cycle, and break it. If all goes smoothly, should be back together in the next 5 or 6 weeks.
2007 FXST
113" Science Project- Baisley Heads, T-Man Cams, HPI t/b,
CP Piston return springs, Fatcat with high flow muffler bearings,
Amsoil synthetic blinker fluid, etc, etc, etc.......
beaureed445 is offline   Reply With Quote
Old 10-04-2009, 07:13 PM   #2 (permalink)
PanHDSam's Avatar
PanHDSam is on a distinguished road
Roller Rockers
Injectors- SE 4.89
Crank- Darkhorse
Cams- TMan 590G
Gears- S&S
And you will be walking around with a S**T Eatin Grin on your face just like me.
64 FL
70 FLH
08 FLSTSB
05 FLHTC 113" Carbureted Build / 6 speed add / lots of other stuff.
PanHDSam is offline   Reply With Quote
Old 10-04-2009, 07:17 PM   #3 (permalink)
NCTURBOS's Avatar
NCTURBOS is on a distinguished road
Bad A$$... Can't wait to see the outcome!!
K.
Dr. Jekyll and Mr. Hyde: The build(s)... Coming soon!
S.B.B. BikeBooberfest Horsepower Shootout winner, 2011...
NCTURBOS is offline   Reply With Quote
Old 10-04-2009, 07:20 PM   #4 (permalink)
Premium octane member
TXCHOP's Avatar
A great bunch of parts with great guys helping along the way. It will be a hit for sure! Keep us posted.
117ci.
Old 10-04-2009, 08:41 PM   #5 (permalink)
PhilM is on a distinguished road
That sounds like a sweet combo! Should make for a scoot that's a BLAST to ride.
PhilM is offline   Reply With Quote
Old 10-04-2009, 09:59 PM   #6 (permalink)
Still the Same!
wurk_truk's Avatar
wurk_truk is on a distinguished road
Cool!
120r
wurk_truk is online now   Reply With Quote
Old 10-04-2009, 11:18 PM   #7 (permalink)
firehog383's Avatar
firehog383 is on a distinguished road
Did you already have the 113 jugs, by the time you pay for jugs and boring you might be close to getting axtell 117. That was the case with my build. I got a great price on jugs and pistons but they were out of round so I had to re bore and buy new pistons. For another 100 bucks I could have had the 117's Just something to look at.
07 FLHX, 114CI S&S 4-3/8 crank darkhorsed, timken conversion JE 20 degree pistons 10.3:1 HTCC CNC heads Jarzs modified set up for 20 deg. pistons, Wood TW-8G gear drive cams, fueling cam plate and oil pump, S/E roller rockers,Wood corrected geometry billet rocker supports,S&S tuned induction air cleaner, S/E 50 mm TB reworked, Fatcat 2into1 big bore baffle, riverra pro clutch,baker +1 and truetrak Jarz built and tuned 130TQ / 125 HP
firehog383 is offline   Reply With Quote
Old 10-05-2009, 05:53 AM   #8 (permalink)
You cylinders are almost done.
Scott
Old 10-05-2009, 07:37 AM   #9 (permalink)
The cost of jugs, hq pistons, and boring of jugs to match pistons was a pretty good savings over the Axtell kit. I did weigh this cost difference before I made a decision.
Scott
Awesome. Thanks Scott!
2007 FXST
Old 10-05-2009, 08:55 AM   #10 (permalink)
Here for the education!
hdryder is on a distinguished road
Sounds like a fun build. You pretty much covered every builder/ manufacture out there with this build didnt you.
hdryder is offline   Reply With Quote
Old 10-05-2009, 10:22 AM   #11 (permalink)
I have pretty much covered them all.....and I've learned how much easier it would be to get a "kit" from one shop (will do this on next bike).
2007 FXST
Old 10-05-2009, 11:00 AM   #12 (permalink)
BrendanGTStang is on a distinguished road
You will love it! I just got my 124" back a couple of weeks ago and it is a huge improvement over my 103" I had. I need to put a better exhaust on it over the winter and have the final tune put on it, because the BSS are choking it up badly, but it is a blast to ride none-the-less. You shouldn't be disappointed!
2007 FXSTB - Vivid Black - 124"
Rev Performance Pistons & Cylinders - 10.9:1
SE Crank Trued & Welded - SE 110 Heads Modified by Bad Boy Engineering
Vance & Hines 2-1 Comp Exhaust - TTS Mastertune
Woods TW-9F-6 Cams - SE Camplate - SE Adjustable Pushrods
SE 58mm Throttle Body - Modified Intake Manifold - Hi-Flow Injectors
SE Back Plate w. Open Zippers Air Filter - Bandit Clutch
BrendanGTStang is offline   Reply With Quote
Old 10-05-2009, 12:08 PM   #13 (permalink)
firehog383's Avatar
Enjoy your build. I'm still grinning ear to ear after putting 10k on my build. Education is expensive, sometime the ease of one shop or kit out weighs the savings and aggravation of jumping around.
Old 10-05-2009, 03:48 PM   #14 (permalink)
road king 100 is on a distinguished road
That ought to get it done. Keep us posted and good luck.
03 RKC=GMR 117" build WITH S&S CYL. KIT
124HP/139TQ
road king 100 is offline   Reply With Quote
Old 10-06-2009, 10:56 AM   #15 (permalink)
Thanks guys.....Now I'm beginning to wonder if I should swap to a chain at the same time, or wait to see if I break a couple of belts 1st.
2007 FXST
