The SE 255 cams, stock vs. ported heads. : V-Twin Forum: Harley Davidson Forums
Old 07-29-2009, 12:56 AM   #1 (permalink)
HATER OF THE GRAVEL!!!!!!
Jeffytune's Avatar
Jeffytune is reading this now saying WTF is this?
Hi all.
I asked this in another thread and either no one knows, or has done this so I will ask this in it's own thread.
NOTE: I am not asking what cam is better then, I am asking about the SE 255. Yes, I know there are better cams out there, that is not the point. With the looming "Smog Nazi's" waiting the pounce on us, I am asking how to get more out of a smog legal cam here.
So lets try and keep this on point. With that said.....
We all know the SE-255's run strong ion the low RPM range, and they start to fade around 4000. My question is, is this due to the cam overlap or cam timing?
Would porting the heads let the engine breath and rev longer in the powerband, or would the extra flow kill the cams down low?
Would retarding the cams 2* bring them in later, or would it just loose power across the band?
The reason for this is my plan to build me engine to raise the efficiency and the output at the same time.
I want the power to come on low in the RPM range because I have a tour bike, not a drag bike.
My plan at this time would be a Big Boys type street porting with backcut valves and the chambers CC'd to match and the compression set @ 9.5:1. I will stay with the 96 CID and replace the stock ring set with a total seal set.
The Fueling oil pump and lifters and a SE 255 cam set.
I will stay with the pro pipe, I may add a larger throttle body to the list.
I will be changing the fuelpak out for another type of fueling system, maybe the Thundermax.
I am open to comments and suggestions here, but the bottom line of what I hope to get is an engine that will pull good, 95-100 horse and still be able to go 100K with good fuel mileage.
As it sits, my bike has 80 horse ans 93 foot pounds torque, and I am ok with how it runs now.
I'm Just Sayin'...
2010 FLHTCUI
96 CID w/ the quiet 6 speed
K&N RK-3930 air filter
Harley quiet high flow 110 mufflers
Vance and Hines Fuelpak
Professional Rockat Surgen
Disclaimer.
Jeffytune is offline   Reply With Quote Quick reply to this message
Old 07-29-2009, 12:12 PM   #2 (permalink)
route66paul's Avatar
I don't know how the "smog nazis" will be able to tell. The standards for a "new" vehicle and "older" ones are much different. Engines change a lot in the first 10% of life. If you keep you bike in tune and go to a camset that will work with regular rockers and the intake close is under 50 degrees, you should be able to pass emission tests. Changing the timing is changing the cam, the lack of overlap will still cause excess heat.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
HPI bored throttle body
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
Old 07-29-2009, 01:04 PM   #3 (permalink)
Faast Ed wants to know where he is and how he got here
I think you'll be dissapointed at the high r's, even with headwork. But you will notice a gain while passing a car (mid range). Just an opinion.
Faast Ed is offline   Reply With Quote Quick reply to this message
Old 07-29-2009, 03:46 PM   #4 (permalink)
Axe Man
BVBOB's Avatar
I believe these cams run out early due to the short duration, I would have to believe a good street port with stock size valves would only help the area these cams run in best and quite possibly carry out a bit further than a stock head. As always, the pipe will have a huge influence on the total package.
1982 FXRS
80 inch
Drag pipes
SU carb
Andrews A cam
2002 Ultra Classic
127 cubic inch
Rush Wrath
custom cams
152 hp 155 tq
2016 Ultra limited.
Old 07-29-2009, 04:04 PM   #5 (permalink)
baggersport's Avatar
baggersport wants to know Dino or Syn?
A ported head will make better power even on an otherwise stock bike...with a decent exhaust and free breathing air cleaner. Top-end power (WFO), will be determined by the cam....along with other parts...... but a good ported head (for the street), will flow more air than stock....if we have more air getting to the cylinder in the time the valve is open....even with a stock cam.....we're going to make more power. Proper tuning would be needed obviously.
Big Boyz Street Heads
207-242-8374 Cell Phone
207-621-8089 Port/Dyno Shop
baggersport is offline   Reply With Quote Quick reply to this message
Old 07-29-2009, 04:09 PM   #6 (permalink)
Another question that I would be curious about if I were in his shoes,....
Will that cam still be EPA proof after letting the motor breath so much more than factory?
I'm thinking "good chance it will be okay", but I don't know for sure.
You'd think more air would dilute pollution, but the tuner will be compensating with more fuel.
Old 07-29-2009, 07:11 PM   #7 (permalink)
nutdriverss wants to know Dino or Syn?
Harley did a good job on the 96 CID heads compaired to earlier versions. I think porting them may cause a loss in torque will a mild cam like an SE255.
nutdriverss is offline   Reply With Quote Quick reply to this message
Old 07-29-2009, 07:35 PM   #8 (permalink)
Yes they did.....and to drive that home.........assuming we agree that stock for stock, the '06-up heads will outflow the '04-earlier ones (we'll skip the bastahd '05yr for this), the '06-up heads have smaller valves.....ahhhhh, the wonders of a better port design.
I think porting them may cause a loss in torque with a mild cam like an SE255.
well....stop doing that.....
Old 07-29-2009, 10:51 PM   #9 (permalink)
Jeffytune's Avatar
Interesting point Ed, but I think once a cam get through the certification process, it is good to go.
Wile true porting the head will add more air, it's not the same as a cam that adds duration and or lift.
I'm Just Sayin'...
2010 FLHTCUI
Disclaimer.
Old 07-29-2009, 10:54 PM   #10 (permalink)
Jeffytune's Avatar
Good point as well, I guess then a street porting would be the way to go.
This way the port are evened up and the cylinder chambers matched to smooth out the power balance between the cylinders.
I'm Just Sayin'...
2010 FLHTCUI
Disclaimer.
Old 07-30-2009, 09:13 AM   #11 (permalink)
ndmp40 wants to know Dino or Syn?
That cam closes the intake at 25 degrees. That is earlier than a stock cam, and the stock cam doesnt have "smog" problems! Why would anyone want to use it is beyond me, its a band aid to pump up TQ in engines with stock type parts.
I have seen mild andrews and woods cams (5) put out more low end TQ than the 255, and provide a much better overall performing engine.
And yes, working the heads in the proper fashion will greatly help, even when using the band aid 255 cam, and help extend your rpm range, but only a small amount. Its a huge myth that properly ported stock harley heads are not worthwhile when using "small" cams.
ndmp40 is offline   Reply With Quote Quick reply to this message
Old 07-30-2009, 11:50 AM   #12 (permalink)
Still the Same!
wurk_truk's Avatar
wurk_truk wants to know Dino or Syn?
What's life in Oregon like? Do they already certify parts like Cali been doin forever? I think the tailpipe nazis and carbon traders will be a phased in kinda deal. In Ohio... we got to KICK THEM OUT when the EPA cerified most of the State! (we export pollution, not keep it in state). They were doing a visual and tailpipe sniff. Bikes were really given a 'pass' during this era. In the future, maybe our weedeaters won't even get a break... who knows. But the older a bike the better chances of a break. Nothing is passed into law yet, and an 07 bike should be smooth sailing even if it were to pass next year... a year before enactment and then you are 5 years old... the make or break point.
I'm curious more than anything... I would THINK (that makes my head hurt) that if you were willing to do porting, you just might consider a different cam set is all. You seem pretty adamant, and I am wondering why? (If I can ask).
Me??? I would ask Big Boyz what they might recommend for your build and expectations... CCing heads should always be a good bet for tuning purposes. I think a good port is good too. I pretty much agree with everything your doing except the cams? Go with the most popular tuner... TTS, I would imagine... that can get the most outta your newly ported heads!
120r
wurk_truk is offline   Reply With Quote Quick reply to this message
Old 07-30-2009, 12:56 PM   #13 (permalink)
nw_guy4_fun's Avatar
nw_guy4_fun wants to know Dino or Syn?
With 06 up heads you could easily go backwards with ported heads. The whole concept of zero overlap cams is to pump low RPM torque and keep HC emission numbers down. It works. The cams are the traffic cop giving instructions to the motor so to speak. The heads just need to follow and the stockers can. I would not get carried away and just Blueprint them. In other words fix the lousy valve job, install improved seals, equalize the CCs and call it a day. Do not add compression but do improve the squish with a .030 HG and grooving the heads with Singh grooves would be wise considering these cams can be ping prone. I would be careful, assuming the SE255 is the cam of choice.
nw_guy4_fun is offline   Reply With Quote Quick reply to this message
Old 07-30-2009, 01:43 PM   #14 (permalink)
Porting heads is just as illegal as running another camset, you are just splitting hairs here. They are not going to tear down the motor looking, unless you are street racing. What the EPA requires on new engines has nothing to do with what your state will allow as far as emissions, it can always be tuned out.
43%er
HQ575 cams
.030 head gasket
"43" points cover
TRW rear mount
Old 07-30-2009, 02:17 PM   #15 (permalink)
FlyingGasCan's Avatar
FlyingGasCan wants to know Dino or Syn?
A buddy of mine just installed the 103 piston/cylinder kit on his bike along with 255 cams and had a good street port done to his stock 07 heads. Needless to say I was suprised how this carried the torque line across quite well. Instead of it dropping off sharply at 4000-4500 it carried it well towards 6K dropping from 104tq to about 92tq at max rpm. The headwork and compression bump really helped that cam along. His bike dyno'd at 85/104 and he used a Rinehart 2 into 1.
Hope that info helps.
FlyingGasCan is offline   Reply With Quote Quick reply to this message
