Diamond Bar ChoppersMotorcycle.com Classifieds!BikeBanditPowerstar Sparkplugs
Dan Vance RacingProCharger.com
Old 07-12-2009, 08:32 PM   #1 (permalink)
MaxHeadflow
Bruce Woltz is on a distinguished road
Bored G much better than an HSR48
For slide rattle anyway..
After swapping the 48 for the G the very first thing I noticed was an rear exhaust leak.. Got to tighten down the rear stud and guess what??
The absolute best way to pull a broke stud...
Bought 4 studs only used 2 on the rear head..
Go to tighten down the pipes and ..
Oh well bought 4, used 4.. Not sure with the originals came from but they were pretty easy to snap and pretty easy to drill out.. Trick on using the Snap- easy outs, drill the hole all the way through the stud..
Max
Bruce Woltz is offline   Reply With Quote
Old 07-12-2009, 08:33 PM   #2 (permalink)
MaxHeadflow
BTW,
Found and issue with the bike.. The gas cap vent don't flow enough air.. On the HSR48, it cased the lean cough. With the G, it hates not having enough fuel in the bowl. They have a real distinctive behavior when running out of gas. Mid throttle starts spittin and sputtering. On the HSR48 the only time you can tell it's out of gas is when the motor dies like someone hit the kill switch.. Did about 140 miles today on it.. Within first 3, it started behaving like it was out of gas... OK stopped at the station.. cuz it was low.. 30 miles after that same thing.. Pop the cap and it'd run fine..
May drill a hole in it and add a vent line.. Need to take it apart..
Going to upgrade the fuel filter also.. It's got one of those glass ones with brass screen.
Max
Old 07-12-2009, 08:39 PM   #3 (permalink)
Let er rip!
oh1deuce's Avatar
oh1deuce is on a distinguished road
Pingle high flow?
R&R St. V cast heads
R&R 615/585's
R&R Cam plate
R&R Roller Rockers
oh1deuce is offline   Reply With Quote
Old 07-12-2009, 10:10 PM   #4 (permalink)
MaxHeadflow
Originally Posted by oh1deuce View Post
Pingle high flow?
Yep, Just installed it.. Bruce
Old 07-12-2009, 10:30 PM   #5 (permalink)
Premium octane member
TXCHOP's Avatar
Bruce, what heads are on your 131? Just curious.
How do you think the throttle response/power will be with the G compare to the Mik?
TTS tuned by Jd's Cycleworks
Black Boarzilla
Wood's TW9FG cams
Old 07-13-2009, 01:26 AM   #6 (permalink)
pwmorris's Avatar
pwmorris is on a distinguished road
Bruce,
No matter the diameter flow, as you know it still needs a healthy venting to force feed the beast-I have had that locking style cap before. I drilled and tapped the cap Buell style, ran a line to the bars, secured it , and then to atmosphere with a tiny filter-cured.
Have you flowed the bored G vs. the 48? How big was the big G and what if any jet changes? T jets, main, modified in any other way?
Thanks!
S&S 9 SECOND CLUB MEMBER-STREET RIDDEN HARLEYS WITH NO BAR, NO BOOST, AND NO SPRAY.
8 TIME DYNO HORSEPOWER SHOOTOUT WINNER
2 TIME BEST OF SHOW
MULTIPLE HARLEY DRAG RACE WINNER
pwmorris is offline   Reply With Quote
Old 07-13-2009, 05:53 AM   #7 (permalink)
We have seen a poorly vented cap raise all sorts of hell before.
Good you nipped it in the bud.
Scott
Old 07-13-2009, 10:01 AM   #8 (permalink)
MaxHeadflow
It's got the RP cast heads.. (Ultima?) I can't tell any difference on the response.. Both work fine. The G sucked as far as response goes when there was a vacuum in the tank..
Paul,
The G is the Davinci that has been de-bomb sighted. I moved the air bleed outside and am using a keihin 140. No Tjet yet. 31 int, 78 main when I rode it but I've up it to an 84. You can still go pretty fast in the twisties with this guy and not get too far into the main..
Thanks Scott,
I think the bigest thing for me was not understanding what the 48 was complaining about before.. The G realy lets you know whats going on...
Bruce
Old 07-13-2009, 11:59 PM   #9 (permalink)
MaxHeadflow
The D manifold had a 1.8 port..
The carb right now is a 1.86 bore by davinci..without the bomb sight. I changed the air bleed to external (aka zippers).. I need to add Tjet if I plan to keep it ob the bike.. Bruce
Bruce
Old 07-14-2009, 06:08 AM   #10 (permalink)
155" R&R TwinCam
dog155's Avatar
dog155 is on a distinguished road
My 124" is sporting a modified G with Tjet,and have a 45 HSR ready to bolt on.It's hard to get motivated to do because the G works so well.Have thought about boring the G,the word is it will really wake the topend flow up.
06 RK,155" R&R TwinCam
02 RK,124" S&S Evo
dog155 is offline   Reply With Quote
Old 07-14-2009, 09:09 AM   #11 (permalink)
MaxHeadflow
Another thing to look at with SnS carbs is the air cleaner.. Going from a stock late setup with SnS paper to a +1 inch green (KnN style AC) and a slotted SnS cover, you will pick up 5-7% flow on a stock G with a 1.8 manifold.. This means that the port can get that much more air if it can take it.. Boring the G on top of that is 2 pretty cheap performance upgrades.. May give you warp 2.. Bruce
Old 07-14-2009, 07:26 PM   #12 (permalink)
TheNowhereman's Avatar
The biggest restrictor to fuel flow is the manifold.
You can talk, bore, add more jets, do anything you damn want but, if the manifold isn't developed also, your not getting what you think your getting.
That's one reason why a smaller carb will actually out fill cylinders at all but high rpm applications with HD motors.
If top end is what you want, then get a *** bike.
If you want rip snortin torque that will win you beers at your local stop light to stop light GPs, run a v twin, and stick a well jetted Mikuni on it and you will win most of your 0 to 100 drag races.
Nowhereman who else?
Old 07-14-2009, 07:54 PM   #13 (permalink)
GoFast!
skidmark316's Avatar
skidmark316 is on a distinguished road
Welcome to the forum!!
http://i5.photobucket.com/albums/y168/skidmark316/MC/sigpic3.jpg
98 FXD S&S 123.62cc
Stage 3.1416 engine work
Stage 7 exhaust
Stage 29 intake
Stage 4,386 spark plugs
skidmark316 is offline   Reply With Quote
Old 07-15-2009, 05:10 AM   #14 (permalink)
155" R&R TwinCam
dog155's Avatar
There is also a happy medium we all strive for.Granted most of our riding is done at a lot less than wot,and most street battles do not last long.It still is a joy searching for that last ounce of hp/tq combo.That search never ends,isn't that what it is all about.
02 RK,124" S&S Evo
