JardineProducts.comLeslie Kay'sMotorcycle-CommunicationDan Vance RacingJekillandHyde.eu
Motorcycle.com Classifieds!
RRcycles.com
Custom Dynamics
Old 06-30-2009, 09:47 PM   #1 (permalink)
d1hojo's Avatar
d1hojo is on a distinguished road
cam gear problem
I finally got my motor back. 107 with R & R crank. I go to put the cams in and check the gear alignment and with the biggest spacer 150, The cam gear is still 17 thou too far back. WTF I tried my old cam plate and was about the same. I really need some suggestions on how to fix this. I can't believe after all the money I spent on this that something like this would come up. Just my friggin luck I guess
2007 FXDWG
GMR 107
R&R CRANK
ANDREWS 37H
D&D FATCAT 2-1
ZIPPERS AC
SE COMP
SE AC BACK PLATE
[SIGPIC]
d1hojo is offline   Reply With Quote
Old 06-30-2009, 09:55 PM   #2 (permalink)
cam gear too far back, or timken spacer not correct----pinion too far out? not saying anything, but you need to identify the problem. if situation two happened to be correct, the pistons will side load.
Old 06-30-2009, 10:24 PM   #3 (permalink)
Premium octane member
TXCHOP's Avatar
Snap some pics so we can see...Is this a 5 piece crank? Were there any special instructions about fitment?
Hillside Cycle custom head work~S/E 4.375 forged crank Darkhorsed~Axtell 117 cyls and pistons~Mikuni HSR48~S+S Super D manifold~Black Boarzilla~Woods TW9BG cams and KF325 filter
Integrity....is doing the right thing, even if no one is watching.
Old 06-30-2009, 10:54 PM   #4 (permalink)
d1hojo's Avatar
My guess would be that the pinion is too far out since it lined up before. The comp is also too far in to get the front sprocket lined up with the clutch. So, how can it be fixed?
2007 FXDWG
GMR 107
R&R CRANK
ANDREWS 37H
D&D FATCAT 2-1
ZIPPERS AC
SE COMP
SE AC BACK PLATE
[SIGPIC]
Old 06-30-2009, 11:02 PM   #5 (permalink)
d1hojo's Avatar
Yes it's the 5 piece crank and it's the same cam support plate and cams. I didn't see the other two posts. I hade the 107 kit done with stage three heads. I need to move everything over about .010 and it would all be good but not sure how. also had the timkin done.
2007 FXDWG
GMR 107
R&R CRANK
ANDREWS 37H
D&D FATCAT 2-1
ZIPPERS AC
SE COMP
SE AC BACK PLATE
[SIGPIC]
Old 07-01-2009, 07:13 AM   #6 (permalink)
Is this to align chain drive sprockets for the cams I assume? For the old spring loaded tensioners?
Old 07-01-2009, 09:56 AM   #7 (permalink)
d1hojo, a thought, have you torqued the sprocket bolt yet? if not, that could be the problem, .010 aint much and may resolve itself when tightening the motor sprocket and loading the timkens.
Old 07-01-2009, 11:17 AM   #8 (permalink)
SLPER's Avatar
SLPER is on a distinguished road
End Play
[quote=claydbal;1629245]d1hojo, a thought, have you torqued the sprocket bolt yet? if not, that could be the problem, .010 aint much and may resolve itself when tightening the motor sprocket and loading the timkens.[/QUOTE
Dennis,
I thought he had said he used the thickest washer he had and still had 0.010 left??
Cheers
Feel free to stand in front!
SLPER is offline   Reply With Quote
Old 07-01-2009, 06:57 PM   #9 (permalink)
DAMADMAN's Avatar
DAMADMAN is on a distinguished road
Interesting... so tell us about it who did the crank install?? what timken was used??
2007 Street Bob
124" 11.7:1
Aftermarket Crank, S&S 640's
Zippers Timken
R&R Stage 4 Heads, Done Right by H!llSide
HPI 58mm TB
marren fuel injectors
Rivera Pro clutch, T Max A/T
DAMADMAN is offline   Reply With Quote
Old 07-01-2009, 07:03 PM   #10 (permalink)
d1hojo, is that an american pitt bull terrier?
Old 07-01-2009, 08:45 PM   #11 (permalink)
d1hojo's Avatar
That's my baby. She's a red nosed pit, no papers just spoiled rotten I got a hold of Steve and then he got a hold of reggie at R&R. I guess the R&R cranks are built with longer pinion snouts for gear drive cams Reggie is cutting some spacers and sending them to me tommarow to get the gears lined up. I'm not real happy about it but he says there will be no problem doing this. I havn't read about this anywhere and it kind of pisses me off. It took 8 weeks to get my motor back and now this.
2007 FXDWG
GMR 107
R&R CRANK
ANDREWS 37H
D&D FATCAT 2-1
ZIPPERS AC
SE COMP
SE AC BACK PLATE
[SIGPIC]
Old 07-01-2009, 09:02 PM   #12 (permalink)
SLPER's Avatar
Pinion
I believe FlyingCasCan had the same issue with is 5pc.
Cheers
Old 07-01-2009, 09:02 PM   #13 (permalink)
Don't blame you for being pissed.
Ron
Old 07-01-2009, 09:03 PM   #14 (permalink)
no difference in pinion ength for gears, if that was so, thousands of stock cranks would have to be lengthened. cutting spacers? shims to correct too long pinion? say it aint so.
Old 07-01-2009, 09:09 PM   #15 (permalink)
DAMADMAN's Avatar
so if its too longer what are spacers gonna do for u? Hmm sounds fishy
2007 Street Bob
124" 11.7:1
Zippers Timken
HPI 58mm TB
