CycleGear.comBikeBanditBub EnterprisesCustom DynamicsSportbikeTrackGear
AdvanstarMotorcycleShowsAmerican Side Road Cycle
Motorcycle-Communication
Old 06-28-2009, 10:22 AM   #1 (permalink)
Avoiding the Inept
Driven1 is on a distinguished road
Hi Flow Air Filter Recommendations
Thinking of replacing my air filter and was curious as to my options. I have used K&N in the past, but are their any others i should consider? I need one that will feed a 100+ HP T/C. Thanks
"I don't care what kind of lubrication you use in your bike, just use a synthetic!
Driven1 is offline   Reply With Quote
Old 06-28-2009, 10:26 AM   #2 (permalink)
4XLT's Avatar
4XLT is on a distinguished road
Hillside has one that is huge and free flowing give Scott a call...
98 FLHT
93" S&S Stroker kit
Mikuni 42
heads Hillside valve job port and polish.. 200 ccp
1.90 int 1.625 ex
Wood W6-H cam
DynaTech 2000 ignition
big sucker with zippers big filter
D&D Fat Cat ... fast black
4XLT is offline   Reply With Quote
Old 06-28-2009, 10:26 AM   #3 (permalink)
Audentes Fortuna Juvat
nightrob's Avatar
Google the overflow air filter element. It will give you all that you need and more
2007 FXSTB
Friedrich Nietzsche
Old 06-28-2009, 11:13 AM   #4 (permalink)
Sturge's Avatar
Sturge is on a distinguished road
Check out Deweys and Zippers - they both have a fairly inexpesive setup that uses the backing plate for the SE Stage 1 if you already have that. After completing my build, was gonna replace my SE Stage 1 intake with one of them but my dyno tuner (dynodoctor.com) told me that for my build, anything beyond the SE Stage 1 would result in little or no gain. This was based on previous dyno testing he has done with stock setup, SE setup, various other setups...and...with NO intake a/c at all. He says for a typical 95" build, as long as you get rid of the stock restrictive setup that's where the most bang for the buck is. Anything beyond that, it's splittin hairs. In general, only big inch builds will benefit from the increased air flow many of these aftermarket setups provide. Based on that I stayed with the existing SE setup.
02FXSTI
95" w/SE Cast Flat-tops
BByz Port job @ 9.8:1CR
Andrews TW37
S.E. Slip-ons
S.E. Stage 1 Intake
PCIIIr
Sturge is offline   Reply With Quote
Old 06-28-2009, 10:58 PM   #5 (permalink)
Premium octane member
TXCHOP's Avatar
Here is the Hillside Monster vs a S/e model....Nothing stopping the air filter from making power here!!!!
Axtell 117 cyls and pistons
Mikuni HSR48
S+S Super D manifold
Black Boarzilla
Old 07-02-2009, 01:45 AM   #6 (permalink)
firehog383's Avatar
firehog383 is on a distinguished road
How does hillsides flow compared to an overflow or woods KF325 or kuryaken hi-five, or the new roland sands, anybody flow test and compare.
07 FLHX, 113CI S&S 4-3/8 crank darkhorsed, timken conversion JE 20 degree pistons 10.3:1 HTCC CNC heads Jarzs modified set up for 20 deg. pistons, Wood TW-400G gear drive cams, fueling cam plate and oil pump, S/E roller rockers,Wood corrected geometry billet rocker supports, Doherty Power PACC and BC Gerolomy overflow filter, S/E 50 mm TB reworked, Fatcat 2into1 big bore baffle, riverra pro clutch, Jarz built and tuned 128TQ / 123 HP
firehog383 is offline   Reply With Quote
Old 07-02-2009, 06:46 AM   #7 (permalink)
Ghost Rider - IronButt
rodriguc
Woods KF325 air filter does the job for me!
Regards, Carlos
Once a Marine, Always a Marine
1981-2007
Retired, but still supporting Marines
rodriguc is offline   Reply With Quote
Old 07-02-2009, 07:08 AM   #8 (permalink)
Eleft36's Avatar
Eleft36 is on a distinguished road
Does your bike choke up and black smoke at Cruise speeds, if not why is an air cleaner change necessary?
Al
V&H Slip Ons W/Double quiet baffles Stock A/C Stock Heads Stock Cams Mustang Wide Touring Seat Stock Bars H.D. Oil Cooler Fat Boy Bags H-D Windshield Thunder Max A/T
SE Compensator Kit
Eleft36 is offline   Reply With Quote
Old 07-02-2009, 08:21 AM   #9 (permalink)
Thread Ender
Pikeslayer's Avatar
Anything more than the K&N that comes with the SE kit or the Ness kit is overkill. I think the Ness is cheaper. The K&N is on my 117" and provides no measurable restriction.
2007 Street Glide
Old 07-02-2009, 11:44 AM   #10 (permalink)
FXDRYDR is on a distinguished road
A while back Bill Bishop tested a number of filters and said the type Sands, Gerolamy and others use flowed best and the Wood 325 was just a whisker behind.
IMO, both will flow more than most motors need and I'm sure many others will do the same.
FXDRYDR
2003 FXD
98" Small Bore
107HP/113TQ
FXDRYDR is offline   Reply With Quote
Old 07-02-2009, 11:54 AM   #11 (permalink)
pwmorris is on a distinguished road
K&N, Hillside modded, Sands, Woods and other large surface area filters are fine for a 100 hp bike. You are nowhere near the power it takes an engine to produce to have a good filter being an issue as far as restricting air flow into your engine.
Pick one you like, that has the big surface area, and fits so that your leg can get around it, and it doesn't stick out too much.
FORMER STREET RACER
MULTIPLE HARLEY RACE WINNER
8 TIME DYNO SHOOTOUT WINNER
2 TIME BEST OF SHOW WINNER
pwmorris is offline   Reply With Quote
Old 07-02-2009, 12:01 PM   #12 (permalink)
TXCHOP's Avatar
Not always true. Might want to get on a dyno for a few runs to see. On my 98 kit years ago the s/e filter sucked almost 2hp from it. My filter on my 117 has 0HP/TQ loss. Scotts filter is about the same flow wise, but fits under a stock cover and is priced right IMO.
Mikuni HSR48
Black Boarzilla
Old 07-02-2009, 12:09 PM   #13 (permalink)
4XLT's Avatar
i had a ness big sucker on mine when i went for a tune, it actually choked the motor once it was jetted correctly..
put a big zippers filter on and made more than with no filter at all..
98 FLHT
93" S&S Stroker kit
Mikuni 42
1.90 int 1.625 ex
Wood W6-H cam
Old 07-02-2009, 03:22 PM   #14 (permalink)
Thread Ender
Pikeslayer's Avatar
Are you guys basing this on the horsepower? I hate to draw conclusions from 2-3 hp differences. Too many variables come into play. In my opinion, the best way to test air filters is to monitor the MAP sensor during a wide open throttle pull to redline. If the pressure reads the same at 2000 rpm as it does at 6200 then the filter is not restrictive.
2007 Street Glide
Old 07-02-2009, 03:32 PM   #15 (permalink)
TXCHOP's Avatar
Have you ever done a run without and air filter to see if the reading changes?
And yes mine is just based on tuning it on a dyno..2-3 hp loss is too much in my book for something soo simple and cheap.
Mikuni HSR48
Black Boarzilla
