Bub EnterprisesMotorcycle-CommunicationAmerican Side Road CycleFuel MotoCustom DynamicsProCharger.comSportbikeTrackGearBikeBanditJekillandHyde.eu
Old 07-02-2009, 03:48 PM   #16 (permalink)
ain't no Geezer Glide
NitroBerserker's Avatar
NitroBerserker is on a distinguished road
Horsepower Inc for me.
Fits under the stock cover, if you like the sleeper look (I do) and when Scott at Hillside dynoed it there was no difference with /without.
If Some is Good, More is Better and TOO Much is Just Right.
NitroBerserker is offline   Reply With Quote
Old 07-02-2009, 06:11 PM   #17 (permalink)
Ghost Rider - IronButt
rodriguc
Originally Posted by TXCHOP View Post
Have you ever done a run without and air filter to see if the reading changes?
And yes mine is just based on tuning it on a dyno..2-3 hp loss is too much in my book for something soo simple and cheap.
Regards, Carlos
Once a Marine, Always a Marine
1981-2007
Retired, but still supporting Marines
rodriguc is offline   Reply With Quote
Old 07-02-2009, 08:15 PM   #18 (permalink)
firehog383's Avatar
firehog383 is on a distinguished road
When I used the dorghtey power pacc air filter on my 113 it cost me almost 10 HP on top compared to no air filter. I then went to a gerolomy overflow and was back to the same HP as no filter. Thats why I was asking if anyone had flowed the new open front or the larger elements to see what the flow differences were. I personally don't like the look of the overflow but that is the cheapest 10 HP I have ever bought. This is just my experience on my 113 build
07 FLHX, 113CI S&S 4-3/8 crank darkhorsed, timken conversion JE 20 degree pistons 10.3:1 HTCC CNC heads Jarzs modified set up for 20 deg. pistons, Wood TW-400G gear drive cams, fueling cam plate and oil pump, S/E roller rockers,Wood corrected geometry billet rocker supports, Doherty Power PACC and BC Gerolomy overflow filter, S/E 50 mm TB reworked, Fatcat 2into1 big bore baffle, riverra pro clutch, Jarz built and tuned 128TQ / 123 HP
firehog383 is offline   Reply With Quote
Old 07-02-2009, 10:59 PM   #19 (permalink)
midnight sporty's Avatar
midnight sporty is on a distinguished road
Not always true. Might want to get on a dyno for a few runs to see. On my 98 kit years ago the s/e filter sucked almost 2hp from it. My filter on my 117 has 0HP/TQ loss. Scotts filter is about the same flow wise, but fits under a stock cover and is priced right IMO.
im with you on this dan. joe tuned my fathers 98 bagger. he could not pull any numbers outta the kandn so we put a zippers in it. and it still was a lil shy.. so whoever says its over kill has not sat and actually watched what a air filter can do to your power.
call up scott at hillside and get your self one of his filters. nuff said.
midnight sporty is offline   Reply With Quote
Old 07-03-2009, 04:26 PM   #20 (permalink)
Thread Ender
Pikeslayer's Avatar
No, I have not done a run without it. If it were a restriction, the amount of restriction (pressure drop across the filter) would increase with rpm (flow). Might be worth a try just for giggles.
What I'm inferring is that the 2-3hp had nothing to do with air filter. During my dyno days it was common to see 2hp differences from pull to pull even when nothing was changed. And that was an engine dyno, so no tire, tranny, belt, etc. variables to come into play.
2007 Street Glide
Old 07-03-2009, 09:50 PM   #21 (permalink)
FXDRYDR is on a distinguished road
Have seen he same thing several times with some of the racers I ride with.
FXDRYDR
2003 FXD
98" Small Bore
107HP/113TQ
FXDRYDR is offline   Reply With Quote
Old 07-04-2009, 06:38 AM   #22 (permalink)
It's never fast enough...
DLRVelocity1's Avatar
DLRVelocity1 is on a distinguished road
Originally Posted by 4XLT View Post
i had a ness big sucker on mine when i went for a tune, it actually choked the motor once it was jetted correctly..
put a big zippers filter on and made more than with no filter at all..
+1 for the Ness Big Sucker and the Zippers element.
V1
I'm less afraid of dieing, than I am of not having lived...
'02 FX"C"ST
95 Screamin' ci.
SBC Heads
Andrew's 37G's 2deg. Adv.
Crane Easy Adjust Rods / Hydro-solids
Bob Wood Performance 415 Carb
SE 2/1 Pro Pipe "V&H" Custom Billet End Cap
Daytona Twin Tec Ignition
Baker 3.48:1 Gearing
SE / Barnett CF Clutch
Avon 200 x 55 x 18 Rear Tire
Weld Recluse Wheels, Rotors and Pulley
Ness / Cycle Visions Custom 5" Fwd Controls
V1 Engineered 200mm Tire Retrofit
DLRVelocity1 is offline   Reply With Quote
