Motorcycle.comDiamond Bar ChoppersBikeBandit
ProCharger.comPowerstar SparkplugsCustom DynamicsMotorcycle.com Classifieds!
Fuel Moto
Old 05-19-2009, 05:57 PM   #1 (permalink)
Eggbert is on a distinguished road
Which cams best for 103ci
Looking for knowledgable advise on which cams to run in my 96 RKC that has the big bore to 103.
SE compresson pistons 10:5-1, SERT, thunderheaders.
Running SE251 cams right now, lot of noise......not really inpressed with torque until 3000rpm.
good advise appreciated...thanks.
Eggbert is offline   Reply With Quote
Old 05-19-2009, 08:16 PM   #2 (permalink)
I'd suggest the Wood 7H.
Old 05-20-2009, 11:20 AM   #3 (permalink)
I've been called abrasive
DBChoppers's Avatar
DBChoppers is on a distinguished road
What type of cylinder heads are you using? Do you have comp. releases?
What is your cranking cylinder pressure? Those are the most important questions to ask before anybody can start to recommend a cam
SCREAMIN' EAGLE
Tastes just like chicken
www.Diamondbarchoppers.com
DBChoppers is offline   Reply With Quote
Old 05-20-2009, 12:44 PM   #4 (permalink)
Bike Builder
syco's Avatar
syco is on a distinguished road
Probably has alot to do with the thunderheader. Has your tuner done any tweaking to the baffle?
R&R/Hyperformance 124" 143hp/144tq SAE
R&R billet heads
R&R 5 piece crank
R&R two piece Cam plate
Dave Makie 630G CAM
Hyperformance ductile Iron cylinders
11.53:1 comp.
55mm Max FlowHPI
D&D Borzilla
Baker OD6 tranny
Baker Plus 1 oil pan
Fueling pump
syco is offline   Reply With Quote
Old 05-20-2009, 12:48 PM   #5 (permalink)
KingofCubes's Avatar
Cams
Is that compression actual or assumed? We have had very good luck with the Andrews 54 if chain or even better the RR525G. Even better with our stage 2-1/2 head work with an actual compression of 10.2:1 compression and .030" to .035" squish.
King Of Cubes
515-266-6381
www.kingofcubes.com
Old 05-20-2009, 02:06 PM   #6 (permalink)
Running stock heads with auto compression release.
Old 05-20-2009, 02:15 PM   #7 (permalink)
cardshark is an unknown quantity at this point
with a tad bit more compression a wood 8 would be nice.
Also--double check your compression, with the stock set-up it may be less than you think--at which point a wood 6 would also be nice. Hillside seems to be the king of wood cams....so i woul defer to scott
cardshark is offline   Reply With Quote
Old 05-20-2009, 02:24 PM   #8 (permalink)
Calcs
It looks like in the picture in the SE book that that piston has a 3 or 4 cc dome, that would probably not come to 10.5 to 1, more like 10.2 to 1.
King Of Cubes
515-266-6381
www.kingofcubes.com
Old 05-20-2009, 02:25 PM   #9 (permalink)
aka_matt is on a distinguished road
stock heads don't have auto comp releases... and like others said, check the compression, as u may not really have the stated 10.5... the 251 cam should work great with a 'real' 10.5 comp...
Matt
FOR SALE
aka_matt is offline   Reply With Quote
Old 05-20-2009, 03:22 PM   #10 (permalink)
"Jane you ignorant slut!"
ceraaa42's Avatar
The SE251 cams do make noise. I wouldn't count on the Woods be any different.
If you want to keep the money under control, have your heads set up for 251 cams you have. They have a great power band.
Chris
Candy red sunglow
103"
SE255 cams
SE Air cleaner
Fatcat Quiet baffle
Bagger brace
43 member
Old 05-20-2009, 03:30 PM   #11 (permalink)
HDWRENCH's Avatar
Well in fact there are stock heads with auto release's . They are standard for the police bikes and I have been seeing a ton of them come through for porting in the last few months. Nothing special about the head other than they are set up for auto comp release.
GMR PERFORMANCE
928-445-3473
TTS TUNING CENTER AND SALES
WWW.GMRPERFORMANCE.COM
Old 05-20-2009, 04:04 PM   #12 (permalink)
ryanl's Avatar
ryanl is on a distinguished road
Originally Posted by ceraaa42 View Post
The SE251 cams do make noise. I wouldn't count on the Woods and different.
Chris
Running the Tw6-g's in my 98in build. The difference in noise levels between my fathers valve train on his stock 96 and mine is negligeable at best. Have heard lots of people complain about noisey cams, guess I got lucky.
Hillside 98" Small Bore Kit
Stage III Heads
Stock Throttle Body Bored to 46.5mm
Hillside Air Filter
Woods TW-6G cams
S&S Adjustable Pushrods
D&D Fatcat (standard baffle)
Barnett Clutch Spring
ryanl is offline   Reply With Quote
Old 05-20-2009, 04:33 PM   #13 (permalink)
If we can assume(without actually cc'ing the heads, and actually measuring/cc'ing the dome volume of the pistons) somewhere between 10.2 and 10.5, then the 7H is still your man.
Scott
Old 05-20-2009, 06:58 PM   #14 (permalink)
Lance03's Avatar
Lance03 is on a distinguished road
S&S 570's, but head work is a MUST.
Lance03 is offline   Reply With Quote
Old 05-21-2009, 11:33 AM   #15 (permalink)
mooooving out!
route66paul's Avatar
HQ575s come to mind.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
HPI bored throttle body
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
