S&S Crank issues : V-Twin Forum: Harley Davidson Forums
Old 04-15-2009, 09:45 PM   #1 (permalink)
TEEMAN wants to know Dino or Syn?
S&S Crank issues
I want to hear some issues and correct fix of some S&S crank failures. I just had my 4 5/8 crank go with runout of 0.042. It was balanced and welded. Now I'm at the point of do I have the pinion shaft replaced and rebalanced. Go for an oversized crank pin if possible or what. I would like to hear some suggestions. I talked with Darkhorse and can get the Jims crank for about $1600 in which is still a option, is the S&S crank worth maybe going with an oversized crank pin. And also could someone help with some options for my parts list of cam plate, oil pump,pushrods, and major gasket set (cometic). The engine is a 131 so now I'm looking at everything apart and wondering at this time should I be changing from belt to chain drive.
TEEMAN is offline   Reply With Quote Quick reply to this message
Old 04-15-2009, 09:51 PM   #2 (permalink)
Let er rip!
oh1deuce's Avatar
oh1deuce wants to know Dino or Syn?
If you're considering a new crank, the R&R 5 piece is a no brainer.
R&R St. V cast heads
R&R 615/585's
R&R Cam plate
R&R Roller Rockers
oh1deuce is offline   Reply With Quote Quick reply to this message
Old 04-15-2009, 09:55 PM   #3 (permalink)
Axe Man
BVBOB's Avatar
What is this crank going in, Twincam, Evo? is it a press together unit or a bolt together? What is the bike? You state, "some S&S crank failures" do you know of other similar problems or have an idea what created yours?
1982 FXRS
80 inch
Drag pipes
SU carb
Andrews A cam
2002 Ultra Classic
127 cubic inch
Rush Wrath
custom cams
152 hp 155 tq
2016 Ultra limited.
Old 04-15-2009, 09:58 PM   #4 (permalink)
Moneygreen
arealinvestor's Avatar
Wow this thread is going to be interesting!!! That R&R crank would be looking nice in that 131ci!!!!I can't remember if it uses longer rods or not???? I'm sure Randy will chime in!!!!
T-Man gear crank set
Jagg 10 row oil cooler
K&P engineering oil filter
To much more to list!!!!!!
Old 04-15-2009, 10:35 PM   #5 (permalink)
SVD999's Avatar
SVD999 wants to know Dino or Syn?
i am guessing its a twincam. the pinion shaft is intigrated in the flywheel (1 piece) and can not be replaced.why do you think it needs to be replaced? the connecting rods, crankpin set can be rebuilt with a new crank pin and oversized rollers. , sometimes there can be a problem when taking a welded crank aprart i would call john at darkhorseand talk to him about redoing it. it would probally be less than half of that 1600
SVD999 is offline   Reply With Quote Quick reply to this message
Old 04-15-2009, 10:37 PM   #6 (permalink)
The crank is a twincam in an of 05 ultra. I was on the freeway rolling about 70mph and heard the sound of lifters ticking just as I was getting off freeway then bike died. Found both exhaust valves stock open. Pulled cam cover to find four teeth broken off cam gear and timing slipped, problely what stuck valves when hit pistons. Cam plates shreaded and 0.042 runout. This engine only had 1100 miles on it. And I also inspected complete valve train to make sure that nothing went thru it. I was told by one shop that S&S cranks off the shelf are OK but the crank pin is not set up as tight as it could be. So now I'm at the crossroads of do I get a Jims Darkhorse crank with 18 month warranty on it and sell the S&S on Ebay.
Old 04-16-2009, 12:55 AM   #7 (permalink)
firehog383's Avatar
firehog383 wants to know Dino or Syn?
Who built your motor?
07 FLHX, 114CI S&S 4-3/8 crank darkhorsed, timken conversion JE 20 degree pistons 10.3:1 HTCC CNC heads Jarzs modified set up for 20 deg. pistons, Wood TW-8G gear drive cams, fueling cam plate and oil pump, S/E roller rockers,Wood corrected geometry billet rocker supports,S&S tuned induction air cleaner, S/E 50 mm TB reworked, Fatcat 2into1 big bore baffle, riverra pro clutch,baker +1 and truetrak Jarz built and tuned 130TQ / 125 HP
firehog383 is offline   Reply With Quote Quick reply to this message
Old 04-16-2009, 01:37 AM   #8 (permalink)
FlyingGasCan's Avatar
FlyingGasCan wants to know Dino or Syn?
If it was welded and balanced one would think it should not be out unless there is an underlying issue. Was the runout measured upon build and what was the end play set at. Also did the case have a Timken kit installed. Sucks having it let go at 1100 miles especially if it was balanced and welded. Curious as to who did the build, dealer, self or indy shop? Feeling your pain here.
FlyingGasCan is offline   Reply With Quote Quick reply to this message
Old 04-16-2009, 08:35 PM   #9 (permalink)
Money Pit's Avatar
Money Pit wants to know Dino or Syn?
Oh yeah, I second the "feel your pain"...
Money Pit is offline   Reply With Quote Quick reply to this message
Old 04-16-2009, 11:02 PM   #10 (permalink)
hightop's Avatar
hightop wants to know Dino or Syn?
The S&S press together cranks (all TC and 124" & up EVO) all need work before hard use. Darkhorse can put in a .001" pin, rebuild the rods, etc, & weld and pro-plug it, and you should be fine.
Just taking them out of the box from S&S and using them is asking for trouble down the road IMO
hightop is offline   Reply With Quote Quick reply to this message
Old 04-17-2009, 05:25 AM   #11 (permalink)
We seen S&S, Jims, and OEM slip.
Seems welding takes care of the crank from slipping, at least for us.
Old 04-17-2009, 08:31 AM   #12 (permalink)
KingofCubes's Avatar
KingofCubes wants to know Dino or Syn?
This makes an R&R 5 piece rebuildable crank look awefully good at $1,475.00. They won't slip. Looking at rebuilding that S&S crank even makes buying the R&R a no brainer like O1 said.
King Of Cubes
515-266-6381
www.kingofcubes.com
KingofCubes is offline   Reply With Quote Quick reply to this message
Old 04-17-2009, 11:47 AM   #13 (permalink)
pwmorris is reading this now saying WTF is this?
I am running both the S&S forged crank on my street bike and the S&S Pro Stock 1.5 crankpin Crank on my racebike and haven't had issues with either-(knockin' on wood here) and I lean on em' pretty hard...
pwmorris is offline   Reply With Quote Quick reply to this message
Old 04-19-2009, 07:47 AM   #14 (permalink)
155" R&R TwinCam
dog155's Avatar
dog155 wants to know Dino or Syn?
I too have an S&S 124" that gets leaned on quite often.Still going strong since 02.
dog155 is offline   Reply With Quote Quick reply to this message
Old 04-19-2009, 03:28 PM   #15 (permalink)
At 198 hp/173 ft/lbs I'd say that it get's "leaned on".
I will also say again, that more 1/4 mile and Bonneville motorcycle records have been established, and then broken, with S&S crank-equipped bikes than ALL others combined. S&S has been manufacturing(and were the inovators) stroker crank assemblies since the early seventies, and the Moco had them under contract to design the bore/stroke combination for the 80" Shovel, which laid the foundation for the 80" Evo. We all know the worth of that engine, and it's abilities.
So with that knowledge, make mine S&S.
Scott
