Dan Vance RacingProCharger.comOriginal Bike SpiritsMotorcycle.com Classifieds!Stainless Ride Specialty AccessoriesMotorcycle.comFuel MotoSportbikeTrackGear
Old 03-29-2009, 04:31 PM   #1 (permalink)
jam65's Avatar
jam65 is on a distinguished road
HPI fitment issue
This is not my day.First,my VPC install needs a death grip to pull lever.
So I move on to the throttle body install and this is not going to happen.Bolt holes don't line up and it seems that runners are not quite lined up. Anyone face this type of problem? TIA
jam65 is offline   Reply With Quote
Old 03-29-2009, 04:38 PM   #2 (permalink)
Faast Ed is an unknown quantity at this point
Did you shave your heads and use a thinner head gasket on your build? If so the TB needs to be trimmed. A block of wood and some sandpaper works.
What spring are you using with your VPC? My grandma could pull my clutch lever easily.
Faast Ed is offline   Reply With Quote
Old 03-29-2009, 04:39 PM   #3 (permalink)
SLPER's Avatar
SLPER is on a distinguished road
Flanges
What's the heads and flanges??
Cheers
Feel free to stand in front!
SLPER is offline   Reply With Quote
Old 03-29-2009, 04:47 PM   #4 (permalink)
dont pi$$ off your granma,
claydbal is online now   Reply With Quote
Old 03-29-2009, 04:48 PM   #5 (permalink)
jam65's Avatar
Stock heads and cylinders.Stock throttle body goes back in just fine. Barnett spring replaced OEM.
Old 03-29-2009, 04:51 PM   #6 (permalink)
you have a problem! why was TB removed?
Old 03-29-2009, 04:52 PM   #7 (permalink)
Average Dude
YankeeBob's Avatar
New TB may be wider than the stock TB. You may have to shave it evenly on both sides until it fits. Not a big deal.
Deut. 23:12-13
YankeeBob is online now   Reply With Quote
Old 03-29-2009, 04:56 PM   #8 (permalink)
Sounds like you can get away with a lighter clutch spring.
Old 03-29-2009, 05:13 PM   #9 (permalink)
jam65's Avatar
This is all on a 107" build going with a bigger throttle body and more clutch.
Old 03-29-2009, 05:16 PM   #10 (permalink)
And you didn't shave your heads or use a thinner head gasket? Lowering your heads will make the TB sit lower in the "V", which is narrower than it used to be.
Old 03-29-2009, 05:17 PM   #11 (permalink)
im easily confused! i read stock heads and jugs?
wut they said on sanding to fit and stock cluth spring.
Old 03-29-2009, 08:26 PM   #12 (permalink)
jam65's Avatar
Sanded in more figure eights than i care to think about,but it finally is in. Thanks everyone.
