Powerstar Sparkplugs
ProCharger.comMotorcycle.com Classifieds!BikeBanditCycleGear.comOriginal Bike SpiritsSportbikeTrackGearDiamond Bar Choppers
Leslie Kay's
Old 03-25-2009, 08:38 AM   #1 (permalink)
merc1100sc
who's run'n an unbalanced "B"
how much stroke and how bad is it?
merc1100sc is offline   Reply With Quote
Old 03-25-2009, 10:09 AM   #2 (permalink)
CaptVic's Avatar
CaptVic is on a distinguished road
I don't yet, but am getting build by KOC now, with 5 piece crank and it will be a 117.
O7 FLSTC & 2010 FLHTCUSE
http://i221.photobucket.com/albums/d...c/P2050019.jpg
CaptVic is offline   Reply With Quote
Old 03-25-2009, 10:10 AM   #3 (permalink)
jonny oz's Avatar
jonny oz is on a distinguished road
do you mean removing the balancer system from a B?
2006 Night Train
V&H Hi Lo Straightshots, black heat wrapped
Ness Big Sucker
PC3
homemade paint (flat/gloss flame job)
*waiting for tools*
07 style camplate, pump, tensioners etc.
Andrews 26N conversion cams
Hippo VPC
SE quick install adjustables
can't wait!
jonny oz is offline   Reply With Quote
Old 03-25-2009, 10:12 AM   #4 (permalink)
1711tab is on a distinguished road
SEDELUXE had his balancers removed for his 120" build... He said very little vibration...
1711tab is offline   Reply With Quote
Old 03-25-2009, 10:30 AM   #5 (permalink)
merc1100sc
Yes,
Removing them from a "B".
I just spoke w/ Hoban's.
I think i'm all set now.
Thanks fre replying guys.
Old 03-25-2009, 10:48 AM   #6 (permalink)
Yes,
If you talk with John Hoban again he did George's... He'd know the crank by mentioning JD'S Cycle Works...
Old 03-25-2009, 11:04 AM   #7 (permalink)
merc1100sc
Thanks Tab.
I was calling Jphn about having balancers put back into a bike, but, after speaking w/ him I found out he never actually touched the crank in this bike, in which I was told he did.
Just a can of worms I prob shouldnt open here.
Old 03-25-2009, 03:39 PM   #8 (permalink)
They put them in for a reason. You may not like the feel without them.
Ron
Old 03-25-2009, 03:48 PM   #9 (permalink)
merc1100sc
From what i'm told, if the crank is balanced correctly, the vibration w/out them is minimal.
Not so in this case.
Old 03-25-2009, 04:54 PM   #10 (permalink)
wmossy is on a distinguished road
SE Deluxe
He is SE on another forum. I believe a few months ago he said he would not take them out again. I could be wrong but search for his thread.....
Below is the quote from SE
Re: Softail Crank Balancers or not?
« Reply #9 on: January 15, 2009, 06:09:05 PM » Quote
if the motor is put together correctly and the balancers were removed and then crank work was done by hoban or any qualified crank work guy there should be no relibility issues.
i run my bike with out balancers and yes i know the blown headlight at nite situation all too well.......i keep spares in my little pouch on the swingarm...
i would not run without them again for what extra power it creates in my opinion it does not matter.
its a personell choice.
WMOSSY
2001 FATBOY 117" Axtell cyls, Axtell Pistons, R&R Stage V heads, RR615 cams, R&R Rollers, R&R internal Cam plate & New HO OEM pump, ADJ pushrods, SE CVO 4 3/8 crank worked by DARKHORSE, Zippers 54mm TB & 1.8 Manifold, 2001 VROD injectors, K&N open Filter, D&D 2:1 with perf baffle, Rivera Pro Clutch, basket & TPP, TMAT Map 514, HD PREM Oil cooler, BAKER DD6
wmossy is offline   Reply With Quote
Old 03-25-2009, 05:09 PM   #11 (permalink)
fx98stroker
balancers
I pulled them out of an 05 springer for a friend and had the crank welded and balanced.He is happy and has very little if any vibration at 70mph.Stock 4' stroke.
Tom
2004 Fatboy
Thundermax A/T ecm
2006 throttle body,25*injectors
screamin eagle A\C
4 3/8" stroker crank SE counterbalancers
Andrews 26G Cams
Crane lifters S.E. adjustable push rods
Big Boyz 83cc heads,.030 cometic head gaskets
S&S gear drive
feuling oil pump,feuling cam plate,baisley spring
de-baffled slip-ons
fx98stroker is offline   Reply With Quote
Old 03-25-2009, 05:49 PM   #12 (permalink)
Counterbalancers take out the vertical shake that happens naturally from the power strokes of the engine. No amount of voodo crank balancing can remove that. It will make the engine smoother that is rubber mounted or counterbalanced but it's not a direct substitute for either smoothing method. Just think of the money moco could save if they could get away without them.
Ron
