Dan Vance RacingProCharger.comOriginal Bike SpiritsMotorcycle.com Classifieds!Stainless Ride Specialty AccessoriesMotorcycle.comFuel MotoSportbikeTrackGear
Old 02-17-2009, 11:42 PM   #1 (permalink)
Lance03's Avatar
Lance03 is on a distinguished road
07' throttle body question
What size is the throttle body on a 07' Street Glide? One of the guys at the shop that is doing my 103" build, suggested the Screamin' Eagle Pro 50mm EFI, P/N 27623-05. will I get any gain. Is it worth the $400.00
Lance03 is offline   Reply With Quote
Old 02-17-2009, 11:46 PM   #2 (permalink)
stix68 is on a distinguished road
OEM t/body is 46mm I believe.
stix68 is offline   Reply With Quote
Old 02-17-2009, 11:46 PM   #3 (permalink)
double post, sorry. The 50mmm SE t/body would be okay to use on the 103, other t/bodies out there, I'm sure others will tell ya. Are you doing head work also.?
Old 02-18-2009, 12:41 AM   #4 (permalink)
Lance03's Avatar
Yes, head work, ported, flowed, bigger valves, S&S 570 gear drive cams,new tappets, adj. push rods, clutch spring. Already had Rinehart t/d, Forcewinder intake and SERT.
Baseline dyno showed 73.4hp and 84tq
Old 02-18-2009, 01:22 AM   #5 (permalink)
robby dmax's Avatar
robby dmax is on a distinguished road
call dan baisely he will do your stock one up just rite and will get better flow that the s/e one mine looks great
robby dmax is offline   Reply With Quote
Old 02-18-2009, 03:30 AM   #6 (permalink)
uniondog's Avatar
uniondog is on a distinguished road
Just a question - Why gear drive cams on a 2007? Did you have bottom end redone?
Also no expert here but SE 50mm not the best choice and depending on your build, how your going to ride - it might not be needed any way - HPI 51 now thats a throttle body for a stout 103
UD
uniondog is offline   Reply With Quote
Old 02-18-2009, 05:19 AM   #7 (permalink)
Moneygreen
arealinvestor is an unknown quantity at this point
Your better off going with the HPI!!! If your stock TB is a 46mm,I would go with the HPI 48mm if your heads are good flowing!!!! You can also send the HPI 48mm to Mr.Baisley and have him match it up to your heads & intake!!!
Craig G.
arealinvestor is online now   Reply With Quote
Old 02-18-2009, 08:29 AM   #8 (permalink)
Lance03's Avatar
UD
No, bottom end work done. Do you see a disadvantage to running gear drive cams on a 07'?
Old 02-18-2009, 08:43 AM   #9 (permalink)
The existing hydraulic cam-chain set-up is absolutely fine.
No need to spend the extra loot.
Old 02-18-2009, 09:00 AM   #10 (permalink)
I agree with Robby ,Dan Baisley does a wonderful job with the stock TB and it flows better than the SE 50mm too.
The biggest disadvantage to the SE 50mm is the clamps crack OFTEN and create intake leaks....I've seen this several times. The SE Tuning class at the MoCo removed all the SE 50mm TB's from the class bikes because of the ongoing problem with the stainless clamps cracking causing too much downtime in the class room.
Old 02-18-2009, 10:21 AM   #11 (permalink)
Lance03's Avatar
Other than the cost, any other problems that I may encounter?
Old 02-18-2009, 10:25 AM   #12 (permalink)
Lance03's Avatar
Does anybody make clamps that don't crack as often? and why are they cracking? is it the hardness of the stainless or un-even torquing during install.
Old 02-18-2009, 10:34 AM   #13 (permalink)
The clamps are super thin (weak) at to top closest to the rocker boxes.
Yes they crack with uneven torque, vibration, and improper installation.
Old 02-18-2009, 10:45 AM   #14 (permalink)
1711tab is on a distinguished road
Your stock TB will work on your build but if you are going to go bigger, IMO buy the HPI 51mm TB... If you ever bump the size again you won't have to replace the TB...The Hpi TB is a quality product and you can get it for cruise control equiped bikes... HPI TB'S show real world results...
1711tab is offline   Reply With Quote
Old 02-18-2009, 10:47 AM   #15 (permalink)
Moneygreen
If your crank wheels are not true you could do other damage running gear cams.If your not sure about crank run out, or your not going to address it, I would stick with the chain!!!
Craig G.
