Originally Posted by skidmark316
1/4 = 100-120 inch lbs blue loctite
5/16 = 14-18 ft lbs no loctite on any rocker plate bolts.
Head bolts depend on gasket, S&S or Cometic? Cometic gives you the torque sequence with their gaskets.
Thanks for the quick reply.
I will be using a Cometic head gasket.
So no loctite on any of the 5/16 rocker plate bolts, hum. I didnt know that. I wonder why that is?
Thanks again.
