JardineProducts.comLeslie Kay'sMotorcycle-CommunicationDan Vance RacingJekillandHyde.eu
Motorcycle.com Classifieds!
RRcycles.com
Custom Dynamics
Old 01-05-2009, 12:08 PM   #16 (permalink)
ejk_dyna is on a distinguished road
i have used them and they are a little bit noisier.
if you adjust your lifters by bottoming out and then backing off a turn...and you have top end clearances a little on the tight side...high rpm valve float will not be good to you...the limiters help there.
ejk_dyna is offline   Reply With Quote
Old 01-05-2009, 12:23 PM   #17 (permalink)
pwmorris is on a distinguished road
Agreed-
There are alot of riders that see 6k rpm plus when they hot rod around once in a while and need a stable valve train. I am going to be running hydrosolids now as an insurance policy as well as to pick up a couple ponies.
For those that just put put around and cruise the roads they are not needed.
Limiters and Hydrosolids are for the rest of us.
FORMER STREET RACER
MULTIPLE HARLEY RACE WINNER
8 TIME DYNO SHOOTOUT WINNER
2 TIME BEST OF SHOW WINNER
pwmorris is offline   Reply With Quote
Old 01-05-2009, 05:49 PM   #18 (permalink)
sulconst2 is on a distinguished road
i'm in also. have my 2KI set at 6400 with jims rollers and limiters in my S&S tappets so they stay on the 640 cam at high rpm's.
needed? maybe.
for 20 bucks? OK.
sulconst2 is offline   Reply With Quote
Old 01-05-2009, 07:25 PM   #19 (permalink)
rdking2005's Avatar
rdking2005 is on a distinguished road
Originally Posted by Mo-Dog View Post
I am running them in Harley B lifters to help with hot starting issues on my 117 and they helped significantly...no more hot start issues... yes, they are slightly noisier when starting the engine when cold...BTW, thanks to Tim for the idea...and a lot of other good ideas...
going to the stock HD lifters this weekend. Might have a slight issue with the jims right now. Taking them out to be sure. Going to be a shop grunt at GMR this weekend...
R&R TC BILLET 131"
640 STICKS, 10:5 COMP, ROAD RAGE 2-1
4-3/8 X 4-3/8 5-PC CRANK, 62MM HPI
RD PORT BILLET HEADS
TUNED ON 89 OCTANE BY GMR PRESCOTT AZ
143/143 SQUARE= LOT'S OF FUN!!!
rdking2005 is offline   Reply With Quote
Old 01-05-2009, 08:16 PM   #20 (permalink)
Handfiler's Avatar
Handfiler is on a distinguished road
I've tried them and I didn't care for the noise. I'll stick with the B lifters and what works for me.
Bottoming the plunger and then shortening the push rod by 0.060"is not a whole lot different than lengthening the push rod 0.140" - 0.160" from zero lash. Similar results, different approach.
99' Lowrider
95" HTCC 10.5:1 pistons
HTCC CNC heads
S&S roller rocker arms
S&S gear drive
Wood's TW408G cams
45mm Mikuni carb
D&D Fatcat
S.E. programmable ignition
Barnett Scorpion clutch
115.2HP/112.7TQ
Handfiler is offline   Reply With Quote
