SportbikeTrackGearStainless Ride Specialty AccessoriesOriginal Bike SpiritsMotorcycle.com Classifieds!Dan Vance RacingPowerstar Sparkplugs
Old 11-22-2008, 07:06 PM   #1 (permalink)
Roadhog96 is on a distinguished road
Looking for low to midrange cam....EVO
I have an 80 evo with Screamiing Eagle heads with .575 lift. Im looking for a cam that pulls in the low to strong midrange - I want to take advantage of the lift of the heads - looking for suggestions. Its going into a 96 roadking modified CV, Crane HI 4e ign. Samsons slipons, going to change those pipes later. Looked at the EVL 5005. Also looked at the HQ-25 but then I could not find it on their website - not sure if it is still around. Im sure someone has some good suggestions
Thanks Roadhog96
Roadhog96 is offline   Reply With Quote
Old 11-22-2008, 07:20 PM   #2 (permalink)
GoFast!
skidmark316's Avatar
skidmark316 is on a distinguished road
If you're looking for more low-midrange, those SE heads aren't going to do you any favors with those big intakes. A friend had 'em and after a couple 3 cam changes, settled on the Crane 290H for the most low end.
http://i5.photobucket.com/albums/y168/skidmark316/MC/sigpic3.jpg
98 FXD S&S 123.62cc
Stage 3.1416 engine work
Stage 7 exhaust
Stage 29 intake
Stage 4,386 spark plugs
skidmark316 is offline   Reply With Quote
Old 11-22-2008, 07:38 PM   #3 (permalink)
yep, want low end? work stock heads and run EV3.
claydbal is online now   Reply With Quote
Old 11-23-2008, 06:24 AM   #4 (permalink)
..........or if you are at 9.5:1 or better, a Wood 6.
Old 11-23-2008, 06:25 AM   #5 (permalink)
Someone around here suggested the 290H a while back to me. Im running the EV3 now. As far as the heads go - Im in it now and I would loose money anyway trying to get rid of them. I know I want to send the heads off and have them CC,ed and cleaned up a little - Would I benefit with this cam by milling the heads to give a slight compression boost?
Old 11-23-2008, 06:35 AM   #6 (permalink)
That cam will also jump to life, again, at 9,5:1 or better.
Old 11-23-2008, 09:04 AM   #7 (permalink)
Just another Hog Jocky
mtnmotorrider's Avatar
mtnmotorrider is an unknown quantity at this point
If those are the same SE evo heads I ran on my Softail (1.90 intakes, 72 cc), I got great results with 10.1 CR and both the Red Shift .559 and Andrews EV 5 cams. This was on an 88" motor with RB Racing 2-1 pipe. As I recall, 88 HP, 92 FPT. Red Shifts came on earlier then the EV 5, but gave up sooner. I liked them better though, for quicker accelleration. They are noisy, but you get use to it. I had to shim the stock SE valve springs to 175# seated pressure, as recommended by Zippers. They love those cams and use them in their 80/80 package.
My friends like me; everyone else thinks I'm an asshole. What's that say about my friends?
'07 Road Glide, 103 ci, Big Boyz "Bigger Valve" Street Port 85 cc heads, .030 quench for 10.2:1 cr, SE flat tops, Wood TW 6-6's, K&N air filter, Cobra/Fat Cat bastardized two-into-one exhaust, TMAT ECM with Auto-Tune.
mtnmotorrider is offline   Reply With Quote
