Diamond Bar ChoppersMotorcycle.com Classifieds!BikeBanditPowerstar Sparkplugs
Dan Vance RacingProCharger.com
Old 11-21-2008, 03:01 PM   #1 (permalink)
sovereignty and secession
jrafter's Avatar
jrafter is on a distinguished road
center screw on k&n filter
the center of the filter is broken and i cant get the cover off the change the filter....it just spins....any ideas.
jrafter is offline   Reply With Quote
Old 11-21-2008, 04:13 PM   #2 (permalink)
Ol' Salt
ShakyJake is on a distinguished road
Try sliding the end of a slot screwdriver under the nut and apply pressure upwards. sometimes that will be enough to get the threads back to where they will catch. That would be my first choice prior to "more drastic measures"...JMHO
IT TAKES MORE THAN SPENDING 20 GRAND AND RIDING 200 MILES TO MAKE ONE A BIKER
ShakyJake is offline   Reply With Quote
Old 11-21-2008, 04:16 PM   #3 (permalink)
jim t is on a distinguished road
filter
Are you talking about the oil filter? If so, a large pair of chanel locks[slip joint pliers] should do the job. It will crush the filter but who cares. It isn't easy but it works. An other way is to drive a screwdriver all the way through the filter. Messy but it works. When tightening the new filter, tighten by hand and not too tight. When the engine is run they tend to tighten up from expantion so it will take more pressure to get it off than you exert to put it on. If it's the air filter, you may have to drill it out or grind it. I just read ShakeyJakes answer and you could have a buddy grab both sides of the cover and pull outward as you try to unscrew the bolt.
99 FXDX modified
jim t is offline   Reply With Quote
Old 11-21-2008, 04:23 PM   #4 (permalink)
0043--Licensed to Doof!
Geezer-Glide's Avatar
Geezer-Glide is on a distinguished road
The air filter center nut? Well, since it's ruined anyhow, start ripping the filter element apart, see if you can reach inside with a long nose pair of pliers to hold the nut.
Question? Why are you "changing" a K&N filter? Just clean them and they're lifetime. Of course you need to remove them to clean, and there in lies your current problem!
I Doof, therefore I am.
D.F.F.D
Geezer-Glide is offline   Reply With Quote
Old 11-21-2008, 05:25 PM   #5 (permalink)
jrafter's Avatar
yes its and airfilter.....and the whole cover is just flopping around....theres threads in the center of the filter that the screw for the cover goes into .....ive tryed jamming something under the screw...didnt work.
cant get anything behind the cover.......thinking i might have to cut the cover off
Old 11-21-2008, 05:59 PM   #6 (permalink)
if you do not space the outer cover, you get broken weld on the K&N, as well as any filter. problem is when you add the heavy cover, and you tighter the allen screw, vibration kills the center nut weld. a small nylon washer between the filter and cover cures the problem.
claydbal is online now   Reply With Quote
Old 11-21-2008, 06:24 PM   #7 (permalink)
jrafter's Avatar
well i had the thicker rubber gasket i was told went on it.......i could really uses some help getting it off.
Old 11-21-2008, 06:38 PM   #8 (permalink)
use an allen bit on impact. when you hit the trigger on the impact, pull gently on the cover, it should come right off. if not, drill or grind centerbolt off and then you can unscrew the filter from the studs.
hoping this helps.
Old 11-21-2008, 06:40 PM   #9 (permalink)
y2kflhr's Avatar
y2kflhr is on a distinguished road
worst case scenario cut it off, I have one sitting in a box from my road king its collecting dust if you know what I mean.
2009 Black Ice/Blue Ice Ultra Classic
y2kflhr is offline   Reply With Quote
Old 11-21-2008, 06:55 PM   #10 (permalink)
jrafter's Avatar
i already started drilling out the bolt......wish had a grinder then i could grind the head off.
this will be my last K&N.
lots of better filters out there now.
i stopped into a shop today who makes there own filter
Old 11-21-2008, 07:38 PM   #11 (permalink)
its K&N fault? please share with us the name of the shop that claims to make their own filter.
we will raise the bullshit flag in a minute if bad info is given.
Old 11-21-2008, 07:56 PM   #12 (permalink)
jrafter's Avatar
im in myrtle beach and there more custom shops here than youve ever herd of....there called wimmer performance
www.wimmermachine.com
and its been a problem with K&N filters for sometime now that the threads in the filter break.
K&N isnt the be all of filters.......but you hall out your flag because it doesnt seem like you have anything else to say
Old 11-21-2008, 08:14 PM   #13 (permalink)
If you come here asking for advice there are many that will be willing to help you. Folks come here with some of the most simple problems that would be laughed at on other forums. Yours is not a complicated problem. A little respect would be in order here. Jim
99 FXDX modified
Old 11-21-2008, 08:20 PM   #14 (permalink)
jrafter's Avatar
who did i disrespect.......wtf
Old 11-21-2008, 08:27 PM   #15 (permalink)
y2kflhr's Avatar
I don't think you disrepected anyone, but read your post, and you may rethink it, I for one offered you a new (used) filter for free, I understand your frustration, I had the one on my low rider strip out and I jb welded a nut behind it and fixed it. Its a memory now.
