10-12-2008, 08:25 PM
#31 (permalink)
just roll along bout 15mph in 1st gear wick it and thats all there is to it.. but i has to be a good surface or it just boils the tire asphalt is what it takes to get it done.
Originally Posted by Fixuntilbroke
how many of you can do wheelies with no clutch action a roll on wheelie i always hear of these cheating clutch drop wheelies
10-12-2008, 08:28 PM
#32 (permalink)
Maybe I slipped the clutch a little?
10-12-2008, 08:31 PM
#33 (permalink)
slow joe is the ****in man, those are the wheelies i want to be doing on my bagger..anyone know what size engine he is running
10-12-2008, 08:47 PM
#34 (permalink)
Originally Posted by 10secondharley
I've seen all Slow Joes wheel stands and his donuts. The man is the man and he'll always get props from me. He is the one in which to measure ones wheelie skills by.
Does a Road Glide good!!
'09 FLTRI, Vivid Black, ABS.
Pri: Amsoil Syn ATF. Trans: Redline Heavy ShockProof. Crank: Rotella T 15W40
117tq/108hp
'05 FLTRI, totaled 10/17/08.
105tq/107hp
'00 FLHRCI, sold.
Proverbs 3:5-6
Fruit of the Spirit
10-12-2008, 09:56 PM
#35 (permalink)
Slojoefrisco rides a 2000 Roadglide with a motor built by Ken Peifer of Boulder Choppers in Henderson NV. It has a 95" that makes 120hp 119lb last I heard but thought he was doing something else with the motor? Not sure...but it goes like hell and he rides the bags off it. Literally!
I've seen pictures of the holes he wore through the rear corners of the bags from scraping them. Now he has skid plates there to keep the rash minimal.
10-12-2008, 10:02 PM
#36 (permalink)
Way to go. I like that -- a 95" that makes 120's (close enough). I mean, anyone can add cubes to get to 120's, but few can make it happen with a 95" motor.
117tq/108hp
105tq/107hp
'00 FLHRCI, sold.
Proverbs 3:5-6
Fruit of the Spirit
10-13-2008, 05:15 AM
#37 (permalink)
155" R&R TwinCam
Both of my bikes will pull the front wheel off the ground,with or without the clutch.Just can't seem to get motavated to do it any more.I get more satisfaction from smelling smoke.Years ago I found out what coming down too hard will do to the front fender when it bottoms out on the crash bar.Now that sucked a big one!! Have fun I still enjoy watching you outlaws!
06 RK,155" R&R TwinCam
00 Boss Hoss, 427" SB2 sbc/w Nos
05 RK project bike
Whizzer motorbike
10-13-2008, 07:52 AM
#38 (permalink)
Axe Man
Originally Posted by Hillsidecycle.com
Alibi's 124" would do a power wheelie with stock gearing.
I know that for a fact.
Now that's odd, He always told us he had a 117 and his buddy had a 124.
2007 Ultra
114 CI
SE cases
Woods 8 cams
Reworked 110 heads by nw guy
Thayer 3 stage oil pump
V&H true duals trapp mufflers
103.. on the workbench
1982 FXRS
Scratched paint
Rotten tires
Bad brakes
Sticky clutch
Still runs like a champ
10-13-2008, 08:28 AM
#39 (permalink)
Bob Ali's first build was a 117" then Hillside rebuilt the same motor into 124"...
Ali's wife told him to sell the bike, she was afraid he'd get hurt on it according to what he told Scott Palmer... Ali bought a 09 that is a stock 96"...
10-13-2008, 09:38 AM
#40 (permalink)
Bike Builder
Do we have to talk about him???
10-13-2008, 10:59 AM
#41 (permalink)
We did 3, 98", engines this year, that rolled out those numbers.
I just don't post that stuff anymore.
10-13-2008, 11:10 AM
#42 (permalink)
Booggerbe just ripped approx 120 hp from his 98".
Way to go Booggerbe!!!!
booggerbe dyno Results 98"
Ok gang . 119.46 HP/108.01 TQ. The results are done. First and formost i want to thank Randy(Hyperformance) and Reggie(R&R Cycles) for their imput and combination to make these numbers happen. The dyno was done in a 5th gear pull. I have only a 5 speed.also i had the stock gearing in 3:15. The results are in true time. Also the altitude was 1,720 above sea level. I have done all things in real time and real results and if you understand these conditions. The motor still has more. All comments are welcome and thinking of going to Fla. to get even better numbers. after the final dyno . Wayne (Speeds Performance) did back up runs and still the same numbers. Wayne thinks that there is more in the motor but the air was not good enough to get more. Hope all can see the curve and the dang motor pulled to 6,400 RPM.Ok the motor is done and now off to get the paint on. Thanks booggerbe
10-15-2008, 04:47 PM
#43 (permalink)
I would like a class from one of the wheelie masters here. My bike should do it ok with a 120 Jims, I just am not sure how to.
06 flhtc, Jims 120 built by T-Man performance in Kernersville NC. 137/138
10-15-2008, 05:40 PM
#44 (permalink)
learn where the tire breaks loose, then dont go there. a 591 dunlop will help.
11-16-2012, 09:04 PM
#45 (permalink)
My ultra power wheelies pretty easy on a 130 metzeler. I have to have my rear shocks set soft(like i do when solo riding). If my shocks are set stiff or i hit the clutch and throttle to hard it just bakes the tire. No idea on hp or tq numbers but i think its more than 60.
| Sponsored Links |
