09-30-2008, 08:38 AM
Crushed/Melted crank Sensor??
The other day at the track my buds bike kept getting slower and slower but seemed to be running fine from what he said. On his last run he did a warm up burn out and the bike just died. Turned over but would not fire. Error codes revealed Crank Position Sensor. Pulled it out to find it broke. Looks melted.
He replaced it and the bike seems ok but I'm worried something else is wrong. Pic is attached below.
Bike specs are:
06 night train
Axtell 124" kit..... 4.125 x 4.625
S&S crank trued & pro plugged by Hoban.
Balancers removed
Timken bearing.
He beats the snot out of it.
Any ideas why this happened?
09-30-2008, 03:14 PM
Bike specs are:
06 night train
Balancers removed
Timken bearing.
We seen 'em fail.
Reason?
Scott
09-30-2008, 03:44 PM
yuck! for **** and giggles, i would make sure thae magnets are still in the alternator.
09-30-2008, 03:50 PM
Premium octane member
Seen a couple of the guys up the street on the CVO site with the same problems.......
Hows the crank runout? Be surprized if it was out of spec being hobaned..........
TTS tuned by Jd's Cycleworks
Black Boarzilla
Wood's TW9FG cams
09-30-2008, 09:41 PM
how strong is the Timken? Could it fail after several launches at the track?
10-01-2008, 12:32 AM
MaxHeadflow
Man,
I'd check the runout. Bruce
10-01-2008, 05:44 AM
mine has not, probably over 100 passes. heavy bike and 1.60 60's
 107" axtel terrorist
thundertek cylinder heads
cams= not woods....
super "D"
loud d&d
10-01-2008, 05:52 AM
Welded crank
The run-out issue is the very first thing that came to my mind,(seen runout do it) but Chris said that the crank took a trip to Hoban Bros. So I ruled that out. Was is welded,(?) as that insures no movement.
We have seen 'em "cook" on untuned oem builds, but as I said, really do not know the reason, unless excess heat/poor quality component.
10-01-2008, 07:34 AM
Looks like you have time for a coffee and a pastry of choice..
Blue and Silver Triglide: Fuel Moto Jackpot Head Pipe SE255 Cams
10-01-2008, 09:26 AM
MaxHeadflow
Scott,
While no expert here, I've have a little bit of a problem with the motor overheating at the track, unless it's 110 out and the guy is lettin' the motor run while waiting for his turn.. Something might have come loose and wacked the sensor then got wedged in the sump tray like a piece of piston skirt, cylinder sleeve, oiler... Something on the crank itself might have failed.
Bruce
10-01-2008, 10:04 AM
I told him to check the runout also before running it again.
Also, maybe the primary comp nut is out of propert torque?
as far as temps, it was a cool day at the track and dont think he let it run long.
we'll check it out and report back what it was.
Thanks!!
10-01-2008, 07:45 PM
Originally Posted by Bruce Woltz
Scott,
Bruce
Bruce,
You very well could be right.
We are all only shootin' from the hip.
Scott
