07-09-2008, 12:57 PM
Infidel
Feuling Lifters
Are the Feuling lifters for a TC any good? They state on their website that they're designed to be run with their oil pump but is it okay to run them with the stock oil pump? Would I be better off with the HD "B" lifters?
John Levanger
07-09-2008, 03:36 PM
IMO use the HD-B lifters... I know Randy (KOC) and Scott Palmer agree...
07-09-2008, 03:41 PM
Premium octane member
Run the same in all builds as well.
117ci.
07-09-2008, 04:26 PM
Infidel
I probably didn't state my question very well. Let's say I got a set of the Feuling lifters way cheaper than I could buy a set of the "B" lifters...would they be okay to use with a stock oil pump and are they as good or as reliable as the "B's"? I've got a buddy who has a new set in the box and he'll let me have them for $35.00.
John Levanger
07-09-2008, 06:59 PM
I have a set that I haven't used and a set of B lifters and I wanted to see the difference between the two. I took both apart and measured everything side-by-side and there was not one difference between them. The only thing I didn't measure or look at was the bypass ball and spring.
07-09-2008, 09:30 PM
Feuling lifters
They are not worth 35 dollars in my opinion.They make more noise than any lifter I have ever used.I also run a feuling super which is doing good.Use the harley lifters more consistant results.
07-10-2008, 01:58 AM
semi-retired
I' got about 20k on them in a mild 95" w/ a stock oil pump.
I can't means I won't!
07-10-2008, 02:22 AM
I have a set on the shelf with about 300 miles on them that did the same thing... Noisy when HOT, coll they were okay... Not Hot... I went to the Harley "B" lifters and they are quiet....
07-10-2008, 09:46 PM
AMS Lifters
Has anyone tried the AMS Hylift Lifters
Cheers
07-10-2008, 09:55 PM
I have a set of AMS lifters that will go in this weekend. I can post when I ride them.
In all honesty, though, the stock 'B' lifter seem to be the prefered choice here, and less $ I think. I just want to see what the AMS lifters are all about.
'04 Brilliant Silver FLHRSI
07-10-2008, 10:09 PM
AMS Lifters
[QUOTE=hdmarsh77;1385617]I have a set of AMS lifters that will go in this weekend. I can post when I ride them.
In all honesty, though, the stock 'B' lifter seem to be the prefered choice here, and less $ I think. I just want to see what the AMS lifters are all about.[/QUOTE
Would be great to hear or not hear how they perform...I talked with Steve there today about why he believes them to be superior..
Let me know.
Cheers
07-11-2008, 09:22 PM
I had about 40,000 miles on the feulings lifters on a mild build with stock oil pump and no problems. I changed them out to b lifters and they sound the same to me. I also took them apart and no difference. The oil hole is slightly bigger. two buddies using the AMS lifters and out of the 8 lifters two have failed. They would not pump up. AMS replaced them but it did cause down time on the builds. I think in most applications 2 failures out of 8 would not be considered acceptable.
07-12-2008, 08:30 AM
HYPERFORMANCE and R&R CYCLES both use either HD-B or S&S lifters for there builds. They will install what ever you want, there choice are the two listed above...
07-14-2008, 06:07 PM
I find that the Feuling lifters are quite noisy when the oil temperature gets to warm and hot values. Any experience with the Jims lifters?
Do it slowly, it's faster!
2001 FLSTCI
Heads ported and 95 CI BB by BigBoyz
48mm throttle body reworked by HorsePowerInc
Wood's TW6G cams
07-14-2008, 07:17 PM
Jims lifters
I have used jims in several Evo builds no problems.Used in a couple T/C builds no problems quiet operation.I have a buddy do a T/C build with a .630 lift woods cam and had a roller failure wiped out cams and pump so I have steered clear of them since
| Sponsored Links |
