07-04-2008, 10:21 AM
Cam help
Hello all,
I have an 07 Ultra with a 103 kit,Wisco flattop fordged pistons, stock TB, Gerolomy stage 2 heads with VH clasic round slip on exhaust. A friend of mine has a Crane 304-2 cam that he is willing to give me but I do not know anything about this cam. Was just wondering if anyone had any experience with this cam. I like good low to mid torque but would like my cam to al least have some legs on the upper end. I would be interested in looking at a dyno on this cam if anyone has one.
07-04-2008, 10:47 AM
Moneygreen
The guys are going to ask you more questions.Like,how much compression are you currently running?
Craig G.
BB & Baisley Hybrid Heads with man/Comp releases
Axtell Pistons & Cylinders set with high comp,Big CCP
Woods A/C kit & Lifters
T-Man gear crank set
Lenale cooling fan
Jagg 10 row oil cooler
K&P engineering oil filter
To much more to list!!!!!!
07-04-2008, 11:58 AM
Fastest Chkn N the South!
I don't have experience with the cam but from looking at the specs it's going to be pretty top-end oriented. You'll want around 10.7-11.2:1 static CR with that cam. Doesn't sound like it fits what you're looking for so well, IMO.
'01 Deuce
GMR 124"
4.125" x 4.625"
CV51 carb/intake/AC
R&R Stage IV heads
10.8:1 CR
JE -10cc pistons
S&S 640 cams
Axtell cylinders
JIMS/Darkhorse crank
Rivera Pro Clutch
DTT ignition
Hooker Troublemaker pipes
137/134 STD 134/130 SAE
07-04-2008, 01:59 PM
I am running 10/1 static right now but will chane the head gastek and the rest to get what I need for CR. It looks to me as if this is more of a top end cam and I am not sure what the manners are at low RPM
07-04-2008, 02:10 PM
Moneygreen
In the 10 to 1 comp range i would probably look at a cam that had around a 40-45 degree intake close,if you want low end tq & midrange.I'm not an expert,but others will chime in if i'm wrong.
Craig G.
Lenale cooling fan
07-04-2008, 02:11 PM
I am not against running a big cam as long as it has decent manners at low RPM(if that is possible)
07-04-2008, 02:38 PM
Infidel
Greg, I'd be willing to bet you would HATE that cam on a bagger. Unless you only ride 1-up, on flat ground, and love upshifting go another route...the low-mid RPM manners will be way soft unless you REALLY step on the compression. To be a decent cam for a bagger you would need more CID than 103".
John Levanger
07-04-2008, 03:03 PM
What about the woods TW7h, the Andrews Tw60 or the Se251, or even the Woods Tw6-6?
07-04-2008, 04:26 PM
Infidel
Throw out the Andrews 60...then in this order 1.) TW6 2.) TW7 3.) SE251...anyone of these would be much better in a bagger than the Crane IMHO, if the other parts compliment them. The TW6H may be a very good choice too! I assume you're running SE255's now?
John Levanger
07-04-2008, 06:29 PM
couldnt agree more. so many people fall for the numbers game and wind up with a bagger that takes 15 seconds to make power.
greg1140, find a builder, go through the interview process and believe what he says! if you cant find a local builder you trust, look several hrs. drive. its still better and cheaper than doing it twice.
07-04-2008, 06:31 PM
No actually I have a SE204 in there now and knew I was going to have to change but got a great dealon the parts. The valvetrain is VERY noisy right now but I got 11tq/99hp with it. Pulls strong on the bottom but dies out on top a little too soon for me
07-04-2008, 06:33 PM
with those numbers, lets talk pipes and heads.
07-04-2008, 06:47 PM
Ok I can do that but first the valvetrain noise has to go. It is very loud and I am not sure if it still needs adjustment or if it is the combination of parts. I was thinking about getting a set of RH tru duals at a later date but maybe sooner if needed.
07-04-2008, 11:59 PM
"Jane you ignorant slut!"
If you're wanting to get rid of valve noise, watch out for the Woods cams, there known for noisy top end. Also the SE251's are the same way and was also my experience. Even though the really perform well if set up right.
I'm also suprised you're getting noise with the SE 204's, some thing else may be going on. If so, you could end up changing cams and still have the noise.
Chris
07-05-2008, 12:29 AM
I think I am going to have to check the valve lash again. It is only noisy when it gets hot. Sound like a puhrod is trying to come through the motor.
| Sponsored Links |
