05-10-2008, 04:25 PM
Which Air Filter Upgrade to Purchase
I have an 07 FLHP Police Road King with a factory 103" and want to know opinions on air filters. Screamin Eagle, Hyper Charger, K&N..
I installed screamin eagle pipes and a thunder-max tuner.
I pretty sure I dont want a super sucker style. I dont just ride in dry weather. I sometimes get caught at work in the rain.
I like the looks of the hyper charger but dont know anything about it. Any info or comments would be greatly appreciated.
Gozzie
05-10-2008, 04:52 PM
I paid.........did you??
Check out www.dohertymachine.com
They have some very nice setups, a little pricey, but well worth it.
Steve
95" Powered by Big Boyz Heads, Woods Cams, Doherty PowerPacc w/ Powervents,
TTS Mastertune, D&D Fatcat w/ Quiet Baffle, Hillside 46.5mm TB, & Cometic Gaskets
Built by Me, Tuned by Bean
05-10-2008, 05:00 PM
mooooving out!
You don't need anything bigger than the SE rated CFM unless you are running a hot 117.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
HPI bored throttle body
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
05-10-2008, 06:45 PM
A second for the Doherty kit - superb workmanship is in a class by itself IMO. And it's MADE IN USA!!
VicW.
'02 Ultraglide:
SE 1550 Cast FT Pistons
'06 Deweys 'Pro Street' heads
Andrews 54N Camset
Doherty PowerPac W/Vents
Zippers Filter Conversion
D & D Fatcat Exhaust
Energy One Clutchpak
SE Clutch Spring
83T VPC
3.37 Gearing
TTS
05-10-2008, 11:31 PM
Premium octane member
Like others said, Doherty is a nice piece. But if not in the budget, get a S/E from HD and get the zippers filter upgrade...
TTS tuned by Jd's Cycleworks
Black Boarzilla
Wood's TW9FG cams
05-11-2008, 01:27 AM
2007 1200 Roadster
I like the NHRS Hurricane back-plate with a K&N air filter because I gained
10-12 horsepower along with Khrome Werks 3" hp slip on mufflers and the SERF on a '07 1200 Sportster
05-11-2008, 11:19 AM
hypercharger
I have been told that a hypercharger makes a whistleing noise when at highway speeds.I went with the arlen ness big sucker,you can use the factory ac cover with it.
05-11-2008, 08:17 PM
it's like the tv show on the speed channel, two guys garage at the end of the show when they drive either a ferrari, z06 vette, or some sort of exotic high performance car and they say do a need this car? no. do i want this car? yes it would look good in my garage.
so ask yourself, do i need the doherty power pac? no. do i want the doherty power pac? i say yes, if it's within the budget. it is twice the cost as the other's, but you do get what you pay for in this instance.
06-13-2008, 04:41 PM
Went with Sreamin Eagle
Thanks for the responses.
I went with the Screamin Eagle stage 1 kit. It was a a very simple install and allowed me to keep my stock cover. So far so good.
Thanks again for the help,
Gozzie
06-13-2008, 04:56 PM
Winter SUCKS!
 Good solid advice...........
2009 Street Gilde - Fully customized
Yes, it has a 200 mm rear tire
06-13-2008, 10:49 PM
Doherty Powerpacc, very nice.
06-13-2008, 11:17 PM
Gozzie
That was the cheapest way out... It should work just fine...
06-16-2008, 07:31 AM
Thread Ender
What is the Zipper's filter upgrade? Is it just a reusable K&N element to take the place of the paper one?
2007 Street Glide
Obama - raised taxes and likes providing terrorists with lawyers -
10-27-2008, 04:40 PM
I use the K & N filter on the SE intake. No problemo
10-28-2008, 06:02 AM
About 5/8" thicker.
But when you really start pulling on the carb/throttle body, then you can run past it pretty darn quick, as we have witnessed power losses on even strong 95" with that element.
They still offer an EVO, 8" round unit the does not hold much power back. But the best out there, are the Dorherty, or the Bob Wood 325 cfm units.
This is info we have found on out Dynojet.
