SEH 203 Cams? : V-Twin Forum: Harley Davidson Forums
Old 05-05-2008, 05:01 PM   #1 (permalink)
mainmusic's Avatar
mainmusic wants to know Dino or Syn?
SEH 203 Cams?
Can anyone tell me the difference in the SEH 203 and SE 203 cams
2003 Road King Classic
98" Jugs
Screamin Eagle Mod. Heads Cleaned up
Custom JE Forged Pistons
Woods tw7G Cams
S&S Gear Drive
Crank Trued and Welded
B Lifters
Baker 6 Speed Overdrive
Rinehart True Duals
3:37 Primary
Thundermax
2008 Road Glide
107 CI
Woods 777 cams
Heads by WFO Larry
30 tooth Trans Sprocket 68 Tooth Rear
Rinehart True Duals
Thundermax
mainmusic is offline   Reply With Quote Quick reply to this message
Old 05-06-2008, 09:37 PM   #2 (permalink)
aka_Matt wants to know Dino or Syn?
where did u see this SEH designation?? i've never heard of it...
aka_Matt is offline   Reply With Quote Quick reply to this message
Old 05-06-2008, 09:58 PM   #3 (permalink)
Seasoned Wrench
razorsedge's Avatar
razorsedge wants to know Dino or Syn?
just a guess but I'll say that they are the cams for the 06 up Dyna or 07 up big twins that have the hydralic chain tensioners
2014 Streetglide Special
Stage 5 Tire Shredder 110"
2003 Softail Deuce
95" SE Flat Tops 9.8:1 comp
Woods TW6G w/ Torrington bearings
SE Performance Heads by GMR
(80cc) (.030 Cometic) (190 CCP)
Tech Cycles 1.4kW Starter
02 guage SUMAX cables
10/84 Evolution Industries Ring/Pinion Gears
LMR-2 Baisley Spring
V/H HS Propipe
DTT ignition (custom map)
SE Coil
HD Oil Cooler
S&S Super E (28 intermediate & 72 main)
I refuse to tiptoe through life only to arrive safely at death.
razorsedge is offline   Reply With Quote Quick reply to this message
Old 05-06-2008, 10:16 PM   #4 (permalink)
mainmusic's Avatar
SEH @93 is stamped on the cams just like the SE 203 and they are the pre 06 cams
98" Jugs
Woods tw7G Cams
S&S Gear Drive
B Lifters
Rinehart True Duals
3:37 Primary
Thundermax
2008 Road Glide
107 CI
Woods 777 cams
Heads by WFO Larry
Rinehart True Duals
Thundermax
Old 05-06-2008, 10:17 PM   #5 (permalink)
mainmusic's Avatar
Sorry that's SEH 203
98" Jugs
Woods tw7G Cams
S&S Gear Drive
B Lifters
Rinehart True Duals
3:37 Primary
Thundermax
2008 Road Glide
107 CI
Woods 777 cams
Heads by WFO Larry
Rinehart True Duals
Thundermax
Old 05-07-2008, 07:55 AM   #6 (permalink)
KingofCubes's Avatar
KingofCubes wants to know Dino or Syn?
Yes, that stands for Screamin Eagle Helpless.
King Of Cubes
515-266-6381
www.kingofcubes.com
KingofCubes is offline   Reply With Quote Quick reply to this message
Old 01-08-2016, 02:41 PM   #7 (permalink)
Gary307 wants to know Dino or Syn?
SEH-203 cams are Screaming Eagle Harley (SEH) cams made for the 99-06 twin cam with spring tensioners. .510/.483 lift. These are the Stage II cams. Excellent low to mid range torgue.
Gary307 is offline   Reply With Quote Quick reply to this message
Old 01-09-2016, 10:43 AM   #8 (permalink)
Don Dorfman's Avatar
Just a SE203
It was an EVO cam (timing) more or less then moved to twin cam
Andrews EV27, SE3, SE203
