Idle Air Control valve : V-Twin Forum: Harley Davidson Forums
Old 04-21-2008, 07:26 AM   #1 (permalink)
RK05's Avatar
RK05 wants to know Dino or Syn?
Don't know if this is the right spot so move if needed.
Is there a way to check the IAC valve without having the SE race tuner on a bike? I get fluctuations in idle sometimes when I come to a stop and would like to see if it may be sticking or something else wrong? Possibly hook up a DMM and watch the changes?
05' FLHRI
95", 9.8:1 W/Heads by BigBoyz, 37G's, Arlen Ness A/C, PC USB, Supertrapp Supermeg 10-disc open cap
RK05 is offline   Reply With Quote Quick reply to this message
Old 04-21-2008, 09:20 AM   #2 (permalink)
Discarded Crew Member
ktwillys's Avatar
ktwillys wants to know Dino or Syn?
The simplest way it to have the stealer check it for you... really not a good option due to cost.
The next is to take to an Indy and have them check.. much better deal.
since the equipment needed to hook up to the HD system probably cost more than a SERT.... well..
No real easy way to check....
You can always remove the A/C and take a little carb cleaner and a soft rag and clean the area around the butterfly. Not much else you can do without the diagnostic equipment...
To be old and wise,
Here's to old and stupid....
Orthopedic Motto
DisCarded Crew
04 FLTRI
SE Welded/Balanced Flywheel
103 CI
CP Hi-Comp Pistons
Andrews 54G Gear Drive Cams
S&S Hi-Lift Valve Springs
Timken Conversion
Baisley SuperSTock Heads
V&H True Dual Headers
Bassani Slip-on Mufflers
T-Max Ignition System
Feuling Oil Pump
Custom Feuling Cam Plate
ktwillys is offline   Reply With Quote Quick reply to this message
Old 04-21-2008, 12:10 PM   #3 (permalink)
RK05's Avatar
Wasn't sure if it put out a voltage signal to the ecm or what. I can build a test harness to plug into it if needed. I would rather Not take it to a dealer and I don't know if any indy's mess with that. I guess I need to do some more searching on how it communicates.
05' FLHRI
Old 04-21-2008, 02:24 PM   #4 (permalink)
Totenkopf is reading this now saying WTF is this?
it is commanded by the number of steps needed. iirc, during the power up sequence it zeros out the stepper motor and then from the map in the ecu based on temp (iirc) counts the # of steps to be at for the conditions.
real easy to see with SERT in the Data Mode real time.
Totenkopf is offline   Reply With Quote Quick reply to this message
Old 04-21-2008, 03:12 PM   #5 (permalink)
rtb
03 Heritage
rtb's Avatar
rtb wants to know Dino or Syn?
The Daytona Sensors LLC twin scan II records IAC (idle air control) motor steps and TPS (Throttle Position Sensor) voltage. I have the older twin scan 88 model and I used it the adjust the TPS when I had to replace my throttle body.
rtb is offline   Reply With Quote Quick reply to this message
Old 04-21-2008, 03:25 PM   #6 (permalink)
RK05's Avatar
I guess I need to see if anyone close has one that I can borrow. It is not that big of a deal (yet). The idle just wants to drop sharply when I pull the clutch in coming to a stop but then climes back up.
05' FLHRI
Old 04-21-2008, 05:54 PM   #7 (permalink)
it may be simple as a speed sensor that is dirty.
Old 04-21-2008, 06:29 PM   #8 (permalink)
Axe Man
BVBOB's Avatar
Keep in mind that any SERT will read your ecm in data mode, just have to find someone/anyone with a SERT that will let you use it.
1982 FXRS
80 inch
Drag pipes
SU carb
Andrews A cam
2002 Ultra Classic
127 cubic inch
Rush Wrath
custom cams
152 hp 155 tq
2016 Ultra limited.
Old 04-21-2008, 08:52 PM   #9 (permalink)
03GLIDE_'s Avatar
03GLIDE_ wants to know Dino or Syn?
They do get sticky. I had bad idle problems that I couldn't cure until one day I sprayed a bunch of Sea Foam into the hole on the top of the throttle body looking at it with the air cleaner off. It has idled pefect ever since.
03GLIDE_ is offline   Reply With Quote Quick reply to this message
Old 04-22-2008, 06:42 AM   #10 (permalink)
RK05's Avatar
I'll see if I know anyone who has the SERT on a laptop that I can use.
04Glide, what is Sea Foam some kind of cleaner?
05' FLHRI
Old 04-22-2008, 07:16 AM   #11 (permalink)
03GLIDE_'s Avatar
Sea Foam is a cleaner/lubricant. It's right with the carb cleaners in the auto parts store. It's safe for throttle bodys. It comes in a spray can and a pour top can for adding to your fuel tank.
