02-10-2008, 09:57 PM
131 thread
What is up with this 131 thread. It would take 2 monitors to follow it . I have been trying to follow it by dates and it impossible. Is the motor done? Is it in the frame? Show it off cant find anything on the original thread!!!
02 Ultra (Dirty Pearl)
couple 4.125 AXTELL Cylinders
couple worked over heads (R&R)
worked over crank
Pair Woods cams
Baker 6 speed
Rineharts
TMAX
02-11-2008, 07:45 AM
Axe Man
Brief summary, original 124 build problematic, never did find out exact problems, Randy of KOC, one hell of a machinist, Also found out what he looks like in the morning ,noon, and night, new 131 , awesome looking motor, motor shipped, going to be installed and tuned at Dynojet. Moral of the story, No talent or mechanical ability needed, just a fat wallet.
2007 Ultra
Woods 7H cams
Heads ported by BigBoyz
D&D Fatcat, SE/AC
1982 FXRS
Scratched paint
Rotten tires
Bad brakes
Sticky clutch
Still runs like a champ!!
02-11-2008, 08:54 AM
Let er rip!
Selecting the "last page" really comes in handy.
R&R St. V cast heads
R&R 615/585's
R&R Cam plate
R&R Roller Rockers
02-11-2008, 09:21 AM
It's pretty well documented. Motor is done, a lot of R&D went into it, not your tipical bolt together build that BVBOB is used to.. It took HYPERFORMANCE 3 months to machine all the parts, fit them and build the motor. I received the motor last Wednesday at 6pm. Changing the trans to Baker OD6 then installing motor. Still waiting on D&D Borzilla 2 1/8" exhaust, have no idea when I'll get it. Even after I receive the exhaust I have to weld it together, it comes in pieces. Once welded I have to have it powder coated inside and out. It's still along way off before I fire it up.
Brief summary, original 124 build problematic, never did find out exact problems. It's all spelled out in detail for those of you that can read..
(Moral of the story, No talent or mechanical ability needed, just a fat wallet.)
BVBOB is a very resentful and envious individual. (jealous)
I striped the motor down prior to sending the bare cases to HYPERFORMANCE. I'm changing out everything else, building the exhaust etc. There is a hell of a lot of mechanical ability being used. I won't appoligize for sending money for something I want.
I don't think BVBOB has a clue to what has or has not been done. Can you say sour grapes...
02-11-2008, 09:42 AM
Let er rip!
Is that a sales pitch?
R&R 615/585's
R&R Cam plate
R&R Roller Rockers
02-11-2008, 09:44 AM
Sounds like BVBOB'S seal of approval to me...
02-11-2008, 09:56 AM
Enjoying life
Hey Tab, it's not too late to say enough is enough and give that engine a real home.....ME, ME, ME!
All kidding aside, hopefully it will all get straighten out soon and you will have that puppy fired up.
05 FLSTNI 107ci
11:1,T-Man Stage 3 Heads, Baisley Roller Rocker arms, SE Forged Stroker-worked by Darkhorse Cranks, T-Man TR-662 roller driven cams, HD-B Lifters, Feuling Camplate, Superpump and Adjustable Pushrods, Wiseco Pistons, Cometic .030", HPI 51mm Throttle Body, SE Bullet Breather, AIM Lockup Clutch and easy pull ramp
V&H Propipe 2-1, THUNDERMAX w/AT, Legend Air, Zumo 550
02-11-2008, 09:59 AM
The Finished MASTER PIECE....
02-11-2008, 10:00 AM
MaxHeadflow
"Brief summary, original 124 build problematic, never did find out exact problems. It's all spelled out for those of you that can still read and write.."
Well,
Let's hope the problem was in the motor and not in the fuel management/igntion system. Sounds like you replaced everything else..
Bruce
02-11-2008, 10:05 AM
Well,
Bruce
Here we go again Bruce... Three rebuilds for 3 different failures does not equate to fuel management. Ignition was and is stock. 3 times the roller rockers ate themselves apart.
02-11-2008, 10:12 AM
It's pretty well documented. [/b]
well now the word "understatement" will be stuck in my head for the rest of the day
02-11-2008, 10:15 AM
Printer ole pal I'm glad someone out there can still read. Thank you...
02-11-2008, 02:28 PM
MaxHeadflow
"Here we go again Bruce... Three rebuilds for 3 different failures does not equate to fuel management. Ignition was and is stock. 3 times the roller rockers ate themselves apart."
I'm sorry, I miss understood. While the rollers and cylinders were one of the reasons for the thing coming apart, I thought you told me that it couldn't be tuned.. Bruce.
Reason: typo
02-11-2008, 05:11 PM
Axe Man
Wow, interesting ,500 posts in the other thread and we finally find out the major problem on the original motor. Yup, pretty much used to bolt together builds although when you pay attention to detail there really is no such thing as a "bolt together" Jealous?, harldy, if I thought a 131 build was in the best interest for the type of riding I do I could just as easily pull the trigger(aka, write the check) on it as the next guy, but you can bet the assembly would be done by me. Resentful?, not really sure why you would say that, if the guy that built the original motor (124)and took a beating here on the forum for it is not resentful than I certainly am not. I really wish you the best of luck with your new motor, looks like Randy did a hell of a job on it and covered every detail. But hey, glad to have you back, you keep things interesting, in a strange way, but interesting nonetheless, and btw, if you happen to run into newguy54, say hi to him for me, seemed like a good guy, wonder why they banned him permanently and brought you back, go figure.
2007 Ultra
Woods 7H cams
D&D Fatcat, SE/AC
1982 FXRS
Scratched paint
Rotten tires
Bad brakes
Sticky clutch
02-11-2008, 06:29 PM
BVBOB--"sour grapes"....whats the back story here that many of us don't know.....would love to hear more about it. Hell--we have to suffer through every little detail of the new 131 build...including pics of t-shirts and all other kinds of crap that is irrelevant....so --Might as well fill us in on the history behind the failed 124 and the new "131 R&D" build by the "innovators not imitators"......inquiring minds want to know....
