Will do. Still in the planning stage as a R&R 155 in a dyna will be a rocket ship. Spoke to Reggie Jr today and he is not aware of any one that has done one. There are some issues with the way a dyna is set up from factory. So that is where the taller back bone with a dropped neck comes, as well using the FLT style trans set up. Open primary, chain drive ( as if the belt would hold ) I am thinking a vid cam with a GPS to see where the monster tops out at will be a E- TICKET ride.
Carlos Mencia-
Newest issue of American Cycle-
R&R 155"....
__________________ Member-S&S 9 Second Club. Daily Driven Street Harleys who can run 9 Seconds or less in 1/4 mile with no Bar, Boost, or Spray.
8 Time Dyno Shootout Winner
Multi Harley Race Winner
Carlos Mencia-
R&R 155"....
got a link all I can find is his 115 ci
Saw him in concert last year 3 1/2 hrs he just wouldnt quit!
07 ULTRA
SE 120R
T-man 662-2 cams
RH/TD's
WFO Larry hand ported. CNC MVA heads
S&S roller rockers
HPI 58/62 T/B
Green A/C
Glide Pro engine and suspension kit
Bitchin Bagger Brace
GARMIN 2610
3 GAL. AUX FUEL CELL
IBA# 31913
BBG
1566 MI 23 HR'S
If you point your oxygen-acetylene cutting torch
at a temperature sensor and adjust it for the highest temp you have found stoichiometric
Ron Dickey
Friends dont let friends ride closed loop
Dog is yours the street or street strip engine?? Frame will be a chopper guys fxr style pro street. Baker monster trans. goal is 200/200
I went with the street version because of the torque deliver,140 lb ft in at 2500 rpm to over 180 lbft.Most of the street business I conduct is over very quickly.The street version delivers big time once I reined in the wheel spin. I The other reason,this thing is smooth relatively speaking.200/200 goal? you will be knocking on the door hard with a 155".My trans is a Zippers modified HD 5 speed,double mainshaft bearings both sides and backcut gears.Rear 1 1/2" Kevlar belt,unbreakable,the rear tire does not stand a chance.
06 RK,155" R&R TwinCam
02 RK,124" S&S Evo
00 Boss Hoss, 427" sbc/w Nos
Dog ,where did you purchase that belt from????Your running a 155ci Twin cam motor right??
Craig G.
BB & Baisley Hybrid Heads with man/Comp releases
Axtell Pistons & Cylinders set with high comp,Big CCP
Woods A/C kit & Lifters
T-Man gear crank set
Lenale cooling fan
Jagg 10 row oil cooler
K&P engineering oil filter
To much more to list!!!!!!
07 ULTRA
SE 120R
T-man 662-2 cams
RH/TD's
S&S roller rockers
HPI 58/62 T/B
Green A/C
GARMIN 2610
IBA# 31913
BBG
1566 MI 23 HR'S
Ron Dickey
I believe off Ebay(3 yrs ago) It's the Gates Kevlar belt.Yes a TwinCam.
Do they have a website?? I found a Gates website ,but it makes no mention of them making belts for V-twin motorcycles!!!
Craig G.
Lenale cooling fan
I'm lookin' at those head breathers turned upward. Do you think threre's any problems doing it this way. I get a little blowby and if I can turn them upward , would probably eliminate what little I get.
Any thoughts?
