"king Of Cubes" Monster 131" : V-Twin Forum: Harley Davidson Forums
Closed Thread
Old 11-19-2007, 02:27 PM   #1 (permalink)
1711tab wants to know Dino or Syn?
"KING OF CUBES"
THESE THINGS ROCK, THE KING OF CUBES / HYPERFORMANCE and R&R CYCLES DEVELOPED THIS PACKAGE A COUPLE OF YEARS AGO WITH THE R&R CYCLES / HYPERFORMANCE OVAL PORT-ANGLED VALVED-SHOW POLISHED BILLET HEADS... EXCELLANT HP & TQ WITH GREAT FUEL MILEAGE! WILL HAVE A 131" IN PRESCOTT, ARIZONA....
RANDY TORGESON "THE KING OF CUBES" / HYPERFORMANCE AND R&R CYCLES ARE BUILDING A R&D MONSTER 131" FOR MY 2004 ROAD GLIDE.....
HYPERFORMANCE R&D CUSTOM MACHINED 85,000 PSI DUCTILE IRON CYLINDERS WITH EXTERNAL OIL LINES
HYPERFORMANCE R&D CASES MACHINED FOR CYLINDER BASE BOLTS
HYPERFORMANCE R&D CUSTOM MACHINED PISTONS "KOC"
HYPERFORMANCE R&D CUSTOM MACHINED OVAL PORT INTAKE MANIFOLD
HYPERFORMANCE R&D CRANK BEARING & SEAL LOCK (ORIGINAL DESIGNER)
HYPERFORMANCE R&D CUSTOM MACHINED TAPERED CHROME-MOLY PUSHRODS
HYPERFORMANCE R&D CUSTOM MACHINED PUSH ROD COVERS INTER & OUTER
HYPERFORMANCE REWORKED S&S 4 5/8" CRANK- PLUGGED-WELDED-TRUED-BALANCED
HYPERFORMANCE TIMKEN CONVERSION
HYPERFORMANCE CASE BORING
HYPERFORMANCE SET COMPRESSION RATIO AT 11.7:1
HYPERFORMANCE SET SQUENCH AT .035
HYPERFORMANCE - R&R CYCLES CUSTOM DESIGNED D&D BOARZILLA 2 1/8" ID - 2 1/4" OD 2n1 EXHAUST
HYPERFORMANCE - R&R CYCLES 6.22 INJECTORS YELLOW BAND
R&R CYCLES SHOW POLISHED, BILLET, RAPED APE OVAL PORT, ANGLED VALVE HEADS WITH 4 COMP. RELEASES
R&R CYCLES ULTRA PRO STREET BILLET CAM SUPPORT PLATE, FLUTED WITH CHROME COVER
R&R CYCLES R&D 620 CAMS
R&R CYCLES FORGED ROLLER ROCKER ARMS
R&R CYCLES SERT BREAK-IN DOWNLOAD BY BRANDON
R&R CYCLES MACHINED FORGED ROCKER ARM SUPPORTS
DYNO TUNED BY DANIELS PERFORMANCE OF LAS VEGAS, NEVADA (MIKE DANIELS)
BAKER OD6 BLACK POWDER COATED CASE, "R" RATIO 2:82 FIRST, 2:08 SECOND, :80 FINAL OVERDRIVE
BAKER BLACK POWDER COATED + 1 OIL PAN
BAKER FUNCTION FORMED CHROME BILLET FL OIL SPOUT AND STAINLESS STEEL LINES
BAKER HIGH HP & TQ 1 PIECE SEALED MAIN SHAFT TRANSMISSION BEARING
BAKER SPEEDO CALIBRATER (DIRECT PLUG IN)
JOKER MACHINE CHROME BILLET FLAMED CLUTCH RELEASE COVER
JOKER MACHINE CHROME BILLET FLAMED DERBY COVER
JOKER MACHINE CHROME BILLET FLAMED INSPECTION COVER
KEWLMETALS CUSTOM MACHINED OUTER PRIMARY COVER (VENTED TO COOL PIMARY BELT DRIVE STEUP)
KEWLMETALS CUSTOM MACHINED TC VENTED DERBY COVER (VENTED TO COOL PRIMARY BELT DRIVE SETUP)
KEWMETALS SKULL & CROSSBONES MEDALION (THANKS BIG JOE)
CHUBBY WILD ONE II 1 1/4" HANDLE BARS
3GUYZ 630 O-RING CHAIN KIT 22T STAINLESS FRONT SPROCKET, 46T POLISHED STAINLESS REAR SPROCKET (ANDY)
RIVERA PRO CLUTCH (THANKS TO JOHN VENTRIGLIA)
RIVERA TPP VARIABLE PRESSURE CLUTCH ASSIST (THANKS TO JOHN VENTRIGLIA)
RIVERA BRUTE FORCE III EXTREME (THANKS TO JOHN VENTRIGLIA)
RIVERA 66 TOOTH RING GEAR (THANKS TO JOHN VENTRIGLIA)
RIVERA 9 TOOTH PINION GEAR (THANKS TO JOHN VENTRIGLIA)
S&S GEAR DRIVE
S&S GEAR DRIVE INSTALLATION KIT
S&S LIFTERS
COMETIC GASKET SET
FEULING SUPER OIL PUMP WITH STAINLESS HARDWARE
FEULING OIL TANK BREATHER KIT # 3080 STAINLESS STEEL REWORKED BY ME TO FIT
SPURGIN OIL COOLERS SHOW POLISHED WITH STAINLESS LINES AND FITTINGS
P&N OIL FILTER / COOLER
K&N CHROME OIL BREATHER CYLINDER WITH STAINLESS FITTINGS
HORSEPOWER INC MAX FLOW II OVAL PORT BILLET 62MM TB WITH STAINLESS HARDWARE
HORSEPOWER INC MAX FLOW II ELIMINATOR CHROME AIR CLEANER COVER
HORSEPOWER INC MAX FLOW II ELIMINATOR AIR CLEANER WITH K&N FILTER
PINGEL ELECTRIC SHIFT NEW DESIGNED MODEL
SUMAX THUNDERBOLT-50 10.4 MM PLUG WIRES
SUMAX EXTREME DUTY 2 GA. BATTERY CABLES WITH GROUND STRAP
DAKOTA DIGITAL FLUSH MOUNT GEAR INDICATOR
DAKOTA DIGITAL HIDDEN ANTENNA
GARMIN ZUMO 550 BLUETOOTH
KURYAKYN FUEL TANK LID MOUNT FOR GPS (SPECIAL THANKS TO GREG "BABY COON")
KURYAKYN DRIVING LIGHTS FOR FLTRI
KLOCK WERKS SMOKE/CHROME HEADLIGHT BEZEL WITH TURN SIGNALS & RUNNING LIGHTS (THANKS TO LAURA KLOCK)
KLOCK WERKS WORLDS FASTEST BAGGER FRONT FENDER (THANKS TO LAURA KLOCK)
KLOCK WERKS CHROME BILLET FENDER BLOCKS (THANKS TO LAURA KLOCK)
KLOCK WERKS FLUSH 1'' FRONT AXLE (THANKS TO LAURA KLOCK)
KLOCK WERKS 12" TINTED FLARE WINDSHIELD (THANKS TO LAURA KLOCK)
BITUBO WMT SHOCKS WITH NITROGEN RESERVIOR FROM TRAXXION DYNAMICS
TRAXXION DYNAMICS AK-20 AXXION CARTRIDGE FORK KIT
ARLEN NESS OIL PRESSURE GAUGE MOUNT WITH ACCEL MECHANICAL OIL PRESSURE GAUGE
ARLEN NESS CHROME BILLET RADIUS LIFTER BLOCKS
ARLEN NESS LAYDOWN LICENSE PLATE FRAME
RODGER MCEWAN MECHANICAL OIL TEMPERATURE GAUGE
BIKETRONICS SONY RADIO CONVERSION FROM MARK @ CYCLE ACCESSORY STORE IN FRANKLIN, NORTH CAROLINA
J&M SPEAKERS NEW DESIGN WITH 2 -SUB-WOOFER GRILLS PER SPEAKER ( THANKS ANDY FROM J&M )
RENEGADE LEDGEND SERIES 18" X 3.5" FRONT WHEEL & 18" X 4.5" REAR WHEEL (THANKS TO WENDELL SMITH)
METZLER ME880E 140 X 70 X 18 FRONT TIRE & 150 X 70 X 18 REAR TIRE
NITROGEN FILLED TIRES
DYNAMIC WHEEL BALANCING BEADS FRONT & REAR WHEELS
POLISHED STAINLESS STAR FLOATING ROTORS FRONT & REAR
LYNDALL Z+ BRAKE PADS FRONT & REAR "NEW DESIGN"
GOODRIDGE STAINLESS BRAKE LINES, BRAKE BLOCK & FITTINGS
ARMOR COAT STAINLESS THROTTE / IDLE CABLES
ARMOR COAT STAINLESS CLUTCH CABLE
LENALE ENGINEERING CHROME FAN (205 CFM)-HORN COMBO
POLISHED STAINLESS FRONT MOTOR MOUNT
POLISHED STAINLESS UPPER & LOWER MOTOR MOUNTS
NEW DESIGNED TRUE-TRACK SWING ARM STABILIZER (THANKS TO RON & KAY)
STA-BO SWING ARM BUSHINGS
HD-BILLET CONTROLS
HD-ROCKER BOXES
HD-PIZZA BOX TOUR PACK
HD-LED SADDLEBAG SPOILERS
HD-LED TOUR PACK SPOILER
HD-CHROME HANDLE BAR CONTROLS
HD-CHROME MASTER CYLINDER
HD-CHROME REAR MASTER CYLINDER
HD-MATCHING LOWERS
HD-CVO OIL COOLER
HD-NOSTALGIC FLOOR BOARDS
HD-NOSTALGIC BILLET BRAKE LEVER
HD-NOSTALGIC BRAKE LEVER PAD
HD-NOSTALGIC SHIFTER PAD
HD-BILLET SHIFTER LEVER
HD-ESCORT RADAR DETECTOR
HD-FLTRI RADAR DETECTOR MOUNT
HD-BILLET MIRRORS
HD-BILLET SADDLE BAG SUPPORT COVERS
CNC'D BILLET CHROME TOUR-PAC HINGES
EGLIDES GLOVEBOX DOOR LOCKS
EGLIDES SEALED LOWER'S GLOVE BOX DOORS AND LOCKS
HOPPE INDUSTRIES "AIR-MAX 2" LOWER AIR DAMS
VIVID BLACK WITH BLUE PEARL GHOST FLAMES
CORBIN DUAL TOURING SADDLE WITH RIDER BACKREST
DIGITAL GUARD DAWG SECURITY SYSTEM
HORNET ELECTRONIC CHROME DEER ALARM
AUTOLITE 4265 SPARK PLUGS ".40 GAP"
TORCO 60 WT OIL WITH MPZ
MILLER CUSTOM POWDER COATING "GLOSS BLACK" CASES, CYLINDERS
HPC "JET HOT COATING" INSIDE & OUT D&D BOARZILLA 2 1/4" EXHAUST (OKLAHOMA CITY, STEVE DEKKER / MUSH)
[/B]
SAE CORRECTED DYNO NUMBERS ARE 156.91 HP & 159.98 TQ ON 87 OCTANE PUMP GAS
STANDARD DYNO NUMBERS ARE 163.72 HP & 166.31 TQ ON 87 OCTANE PUMP GAS
1711tab is offline   Quick reply to this message
Old 11-19-2007, 02:39 PM   #2 (permalink)
fatboyskip wants to know Dino or Syn?
I wanna job like you got.................and the paycheck! Can't even imagine how tight you will have to hold on! Hope it turns out to be a real blast..........how could it not.
r/ George
HARLEY DAVIDSON and The United States Navy---The Two Greatest Symbols of AMERICAN FREEDOM!!!
2002 FatBoy
95" CP Flat Tops, Cometic .030
GMR CNC Ported Heads
Andrews 37G Sticks
SE Clutch Spring
V&H Pro Pipe w/mods
GMR Lifters & Pushrods
DTT Ignition
2004 XL 883
Terminal Velocity A/C
Samson Big Guns
Mini Apes
Lowered 2 "
fatboyskip is offline   Quick reply to this message
Old 11-19-2007, 02:46 PM   #3 (permalink)
Premium octane member
TXCHOP's Avatar
1711, what kind of bike is this going in, your bagger that had the 124?
S&S T124
TXCHOP is offline   Quick reply to this message
Old 11-19-2007, 02:53 PM   #4 (permalink)
YES, 2004 ROAD GLIDE............
Old 11-19-2007, 03:18 PM   #5 (permalink)
Let er rip!
oh1deuce's Avatar
oh1deuce wants to know Dino or Syn?
SICK!!!!
What comp range are you doing with those cams?
oh1deuce is offline   Quick reply to this message
Old 11-19-2007, 03:21 PM   #6 (permalink)
Originally Posted by oh1deuce
SICK!!!!
11.7:1 comp.............
Old 11-19-2007, 03:49 PM   #7 (permalink)
dennish's Avatar
dennish wants to know Dino or Syn?
Seems like there is another story in this....
dennish is offline   Quick reply to this message
Old 11-19-2007, 03:57 PM   #8 (permalink)
Story ?
OHHHHHHHHHHHHH what would that be?
Old 11-19-2007, 04:34 PM   #9 (permalink)
rdking2005's Avatar
rdking2005 wants to know Dino or Syn?
Just curious... Are you ever happy with what you have? All your post are about how bitchen your motor is or was? Again, just curious...
R&R TC BILLET 131"
640 STICKS, 10:5 COMP, BASSANI B-1 MEGA PIPE
4-3/8 X 4-3/8 5-PC CRANK, 62MM HPI
RD PORT BILLET HEADS
TUNED ON 89 OCTANE BY GMR PRESCOTT AZ
143/143 SQUARE= LOT'S OF FUN!!!
rdking2005 is offline   Quick reply to this message
Old 11-19-2007, 04:40 PM   #10 (permalink)
WEINERDOGBONE's Avatar
WEINERDOGBONE wants to know Dino or Syn?
It sounds great. Can I ride it?
WEINERDOGBONE is offline   Quick reply to this message
Old 11-19-2007, 05:12 PM   #11 (permalink)
Let er rip!
oh1deuce's Avatar
[QUOTE=1711tab]11.5:1 comp.............
You are one sick puppy! ! !
I'd think more than 160 with the comp that high.
Old 11-19-2007, 05:28 PM   #12 (permalink)
1) I have NEVER stated my motors were as you stated bitchen (is or was), I only stated what I've done or had done.
2) The Original Mastermind behind the MONSTER 131" [/U][/B]who also did your cylinders & pistons(Randy Torgeson) "King Of Cubes" and HYPERFORMANCE is building my motor!!!!
Old 11-19-2007, 05:32 PM   #13 (permalink)
Come on out when it's done and give it a go.............
Old 11-19-2007, 05:37 PM   #14 (permalink)
Speed Addict
darktrainer's Avatar
darktrainer wants to know Dino or Syn?
Congrats. Sounds like a real fun ride. Keep the rubber side down.
darktrainer is offline   Quick reply to this message
Old 11-19-2007, 05:39 PM   #15 (permalink)
Thank you, coming from you that means alot......
Closed Thread
