Dan Vance RacingCustom Dynamics Fuel MotoProCharger.comMotorcycle.com
SportbikeTrackGearBikeBandit
Old 07-10-2007, 07:36 PM   #1 (permalink)
redplexi is on a distinguished road
Best Cams for 96 C.I. Ultra Classic.
Who has experience with Cams in Big Dressers.
96 Inch , 6 Speed. Rinehart True Duals, S.E. Stage I Kit w/Breather. Power Commander. Now I need a Cam.
I want to Keep up with my other Buddies Light to Light, as well as Touring.
Thanks in advance.
redplexi is offline   Reply With Quote
Old 07-10-2007, 07:52 PM   #2 (permalink)
roofeditor is on a distinguished road
Under warranty
Or not?
Then there is the "Dealer warranty" like my dealer who will warranty SE cams, pistons, etc for one year parts and labor as long as he installs it. He does mention that you may have warranty issues with other dealers while traveling. However how would another dealer know you have a 203/204/251 cam in there other than opening up things?
I think the dealer warranty may actually be better than the factory warranty that I hear you have to fight to get covered on most things.
roofeditor is offline   Reply With Quote
Old 07-10-2007, 08:03 PM   #3 (permalink)
bikernut is on a distinguished road
did a 103 and a 37....happy for now
bikernut is offline   Reply With Quote
Old 07-11-2007, 04:01 AM   #4 (permalink)
nidan's Avatar
nidan
I just did a 103 on my 07 FLHX , and the dealer would warranty the 255 and that was about it. THe cam is better than stock , pulls very linear and nice about 3000, but when the warranty runs out , I'll be looking at at least a 251 or the Redshift .575 or T-man .590 with heads.
nidan is offline   Reply With Quote
Old 07-11-2007, 05:11 AM   #5 (permalink)
Thanks in advance.
Redplex you might want to consider head work an the bigger bore before a cam is selected. If you just want a cam for now and no head work then a Andrews 26 in your motor will deliver 80 hp and 90 tq. If you go with a a partial port, big bore (103'') and like a TW6 .510 lift or Andrews 37 .510, or Red Shift .510 you will be well over 105/110. If you go bigger cams (.550 and above) roller rockers will be required.
Good luck
Old 07-11-2007, 06:07 AM   #6 (permalink)
Good luck
I will add to the above by stating that the Bob Wood TW-6-6, will hit on the very bottom, and continue out, where as the 37 will nose over .
Old 07-11-2007, 06:24 AM   #7 (permalink)
Old 07-11-2007, 10:32 AM   #8 (permalink)
foddlefadel is on a distinguished road
Doc...what is the minimum compression ratio that works with the TW6-6.
thanks
Dave
foddlefadel is offline   Reply With Quote
Old 07-11-2007, 10:56 AM   #9 (permalink)
KingofCubes's Avatar
R&R has a new cam for little or no head work called the RR525 cam that will turn it into into a torque bike. It is designed to be used with chain or gear but you will have to use either their cam plate or cam plate/ cam cover.
King Of Cubes
515-266-6381
www.kingofcubes.com
Old 07-11-2007, 11:03 AM   #10 (permalink)
thanks
Dave
I wouldn't go below 9.8:1.
Old 07-11-2007, 02:15 PM   #11 (permalink)
Doc
Dave
