98" Tuning Help after Dyno
Got the bike dyno’ed – not tuned - last Friday. We did 10 pulls and charge was $45.00 so pretty good price for dyno time.
Build consists of the following:
Rev. Performance 98”; CP 10.5:1 pistons; OEM heads ported; .030” head gasket; the .615/.585 cam; Mikuni HSR 45mm; Crane Hi4-TC ignition; Fueling pump and cam plate; homemade air cleaner with Doherty backing plate; RB Racing LSR; 3.37 primary gearing.
650 miles on this build and CCP at 190psi front and 185psi rear. No leak down test performed yet.
Settings:
Crane at Mode 0; Offset 0; Initial +2; Advance +5
Mikuni at 170 main, #70 accel pump, #25 pilot, #97 needle at middle clip.
O2 sniffer in rear header pipe.
I have attached 3 charts showing the following: 1) 4th gear SAE at WOT 2) 4th gear SAE at ¾ throttle 3) 4th gear SAE at ½ throttle.
I am looking for tuning help from the forum board since there is no one local that can do this type of work. My plans are to change main jet from 170 to 180, raise needle up one slot, and replace #70 accel pump with a #50 since at the dip it is getting too rich. I may also try +1 initial and +6 advance on the ignition.
What else can I try to help that dip????
Thanks,
DEVILDOG
