Hammer, yes it takes into account the intake close. ejk's ccp number assumes sea level. If you assume 420', which is roughly Augusta's elevation, if you were actually at 10.6, your ccp would be 193.5 psi. When you correct to 185 psi, it says your actual static compression is 10.24.
