Old 03-21-2007, 02:38 PM   #1 (permalink)
Rather be ridin'
AmarilloDano is on a distinguished road
Throttle position sensor w/PCIII
I installed a 95" flat top kit, A/C, open mufflers, PCIII USB, with stock cams on my '99 twin cam. Everything is working well, except a bit of an erratic idle. When I was in the PCIII to zero the throttle position, I noticed the numbers were fluctuating with the key on, engine off. I understand the throttle position sensor to be basically a potentiometer. If my assumption is correct, I would think the position would be rock steady with the engine off. Do I need to replace the TPS?
AmarilloDano is offline   Reply With Quote
Old 03-21-2007, 02:55 PM   #2 (permalink)
HARLEYMANIAC's Avatar
HARLEYMANIAC is on a distinguished road
Hi,
This values may vary 0-3777 = 0 Volt
this is normal don't need to change the TPS
just set it for 0 and 100 % that ist
look at this http://www.powercommander.com/powerc...downloads.aspx
10. how to set the throtle position
Fred
HARLEYMANIAC is offline   Reply With Quote
Old 03-22-2007, 10:41 AM   #3 (permalink)
Rather be ridin'
Thanks!
Thanks! I was setting zero and full throttle when I noticed this. I'm sure glad I don't have to spend $ for a new TPS. After all, $1 is about 14 miles worth of gas!
