The way I was taught, a light tan indicates there is a little fuel left unburnt, which pre-emmissions was a good thing. It meant there was enough fuel to produce as much power as possible. A white plug means all the fuel is being burnt, you just want to make sure there are no dark specks which could be little pieces of your piston melting off and adhearing to the plug.
"The memories of a man in his old age, are the deeds of a man in his prime" - PF
Make memories while you can!
2008 FLHTCU - ABS / Dark Blue Pearl
Rear Lowered 3/4"
Nightrider XIEDs
FullSac TD w/CVO Mufflers (Silent Blue Fellow)
