I never worked on a Harley before installing my Andrews 26 cams in my 07 EG. I started 2 days prior to 4000 mile trip. Every thing went well. I aligned the pump basically the way the fueling oil site says. I used the stock rods. Just remember that your air flow through engine changes. Ignition timing needs adjustment as well as you fuel map.
2007 Electra Glide Classic
Tmax Autotune
SE Stage 1 Air Kit
Modded Stock Exhausts
Andrews 26 Cams
